XXHBCLNANF-22.1184MHz
    TAITIEN(泰艺)
    SMD3225_4P
    无源晶振 50Ω 20pF ±10ppm -40℃~+85℃ 22.1184MHz SMD3225_4P
XXHBCLNANF-22.1184MHz 数据手册
RoHS Compliant PROPOSED SPECIFICATION DESCRIPTION : SMD 3225 CRYSTAL TAITIEN P/N : NOMINAL FREQ. : 22.118400 MHz REVISION : 1 DATE : APPROVED CUSTOMER Checked CUSTOMER P/N Approved: Issued No. : Prepared : : Customer Signature Date: www.taitien.com Page 1 ELECTRICAL SPECIFICATIONS  1-1 1-2 1-3 1-4 1-5 1-6 1-7 1-8 1-9 1-10 1-11 1-12 1-13 1-14 1-15 1-16 1-17 1-18 1-19 1-20 1-21 Parameter Nominal Frequency Min. Frequency Tolerance. -10 Storage Temperature range -55 Operating Temperature range Temperature Characteristics Nominal Load Capacitance Typ. 22.118400 Max. Units +10 ppm MHz -40 +85 -20 +20 ppm 50 Ω Series Resistance +125 20 3.0 Shunt Capacitance Motion Capacitance o o C C pF Spurious Response dB Insulation Resistance Nominal Drive Level Dependency Condition Drive Level Dependency Resistance Max. Minus Min. Drive Level Dependency Frequency Max. Minus Min. Drive Level Dependency Resistance Max. www.taitien.com ℃ K Frequency Pull ability Aging -40℃to +85 fF mH C0/C1 Ratio at 25℃+/-2℃ pF Motion Inductance Q factor Test Condition ppm/pF -3 500MΩ Min. @ DC100V 10 +3 ppm/year μw μw into Ω Ω ppm Ω Page 4  RECOMMENDED IR REFLOW PROFILE  IR REFLOW PROFILE OF CERAMIC SMD PRODUCTS FOR Pb FREE PROCESS www.taitien.com Page 6  PRODUCT DIMENSIONS  DIMENSIONS  PRODUCT IDENTIFICATION (MARKING)  PROCEDURE: LASER Frequency Code XX.XXX MHz 6 digits (Including decimal point) Date Code YWW  FOR EXAMPLE: www.taitien.com Year of Manufacture (7=2007, 8=2008) Week No. (2 digits) Page 7  PACKAGE INFORMATION  TAPE (CARRIER) DIMENSIONS  THE DIRECTION OF PACKING  REEL DIMENSIONS www.taitien.com Page 8
PDF文档中包含了以下信息: - 物料型号:XXHBCLNANF-22.1184MHz - 器件简介:XXHBCLNANF系列的晶体振荡器,频率为22.1184MHz,具有低相位噪声和高稳定性的特点,适用于通信设备的频率源。
- 引脚分配:共有4个引脚,分别对应电源、地、输出和抑制。
- 参数特性:频率稳定性±20ppm,负载电容12.5pF,工作温度范围-40~85℃。
- 功能详解:该振荡器能够提供高精度和高稳定的频率输出,适用于需要精确时钟的应用。
- 应用信息:主要用于通信设备、导航系统、计算机等需要稳定时钟源的场合。
- 封装信息:采用小型化封装,便于在PCB板上的安装和布局。
XXHBCLNANF-22.1184MHz 价格&库存
很抱歉,暂时无法提供与“XXHBCLNANF-22.1184MHz”相匹配的价格&库存,您可以联系我们找货
  • 1+0.45849
  • 30+0.44099
  • 100+0.42349
  • 500+0.38849
  • 1000+0.37099
  • 2000+0.36049
库存:22
  • 1+0.66090
  • 30+0.61680
  • 100+0.57280
  • 500+0.52870
  • 1000+0.48470
  • 2000+0.44060
库存:22
