- 规 格 书 -
产品型号:
MHR-10
产品名称: 旋转编码开关
SM SWITCH CO.,LTD
Add
:江苏省无锡市新吴区弘毅路8号金帛座706室
韩国京畿道富川市三鹊路22号富川科技园103-506栋
TEL
:+86-510-8591-9217
E-mail:SMSWITCH@SIMAOKJ.COM
Web
:WWW.SIMAOKJ.CN
ROTARY DIP SWITCH
SPECIFICATION
Rev. A
P:1/4
1. Style:
This specification describes "Rotary Switch"mainly used as signal switch of
electric devices with the general requirements of mechanical and electrical
characteristics.
1.1 Operating / Storage Temperature Range : -40℃ ∼ +85℃
2. Current Range:
2.1 None-Switching : 200mA, 42V
2.2 Switching
: 150mA, 42V
3. Type of Actuation : Rotating
4. Test Sequence
ITEM
DESCRIPTION
TEST CONDITIONS
REQUIREMENTS
There shall be no defects
E
L
E
C
T
R
I
C
P
E
R
F
O
R
M
A
N
C
E
1
Visual
Examination
By visual examination check without
that affect the
any out pressure & testing.
serviceability of the
product
① To be measured between the two
terminals associated with each
2
Contact
Resistance
switch pole
② Measurements shall be made with a
80mΩ max
1kHz shall current contact resistance
meter
3
Insulation
Resistance
Dielectric
4
withstanding
Voltage
250V DC, 1minute ±5seconds
250V AC(50Hz or 60Hz)shall be applied
between all the adjacent terminal and
between the terminal and the frame For
1 minute
100㏁ min
There shall be no
breakdown or
flash over
Applied in the direction of operation
5
Operation
700gf/cm. max
Force
SM SWITCH CO., LTD.
ROTARY DIP SWITCH
SPECIFICATION
Rev. A
P: 2/4
Measurements shall be made following the test
M
A
C
H
I
N
P
E
R
F
O
R
M
A
N
C
E
6
Operation
Life
set forth below:
1)150mA, 42V DC resistive load
2)Rate of operation: 15∼20 cycles/ minute
3)Step of operation: 10,000 steps
1)As shown in item 3,4
2)Contact Resistance:
200mΩ max
3)Final-after test
Following the test set forth below the
Resistance
7
Low
Temperature
sample shall be left in normal temperature
and humidity conditions for an hour
before measurements are made:
As shown in item 2∼5
1)Temperature: -40℃ ±3℃
2)Time: 96 hours
Resistance
8
High
Temperature
1)Temperature: 85℃ ±2℃
1)As shown in item 3∼5
200mΩ max
2)Time: 96 hours
9
Resistance
Humidity
1)Temperature: 40℃ ±2℃
2)Relative humidity: 90∼95%
3)Time: 96 hours
SM SWITCH CO., LTD.
1)As shown in item 4
200mΩ max
3)Insulation Resistance:
10㏁ min
ROTARY DIP SWITCH
SPECIFICATION
Rev. A
P: 3/4
5. Wave Soldering Conditions:
6. manual Soldering
: Max. 350℃ Max. 3sec
7. This item is "ROHS" Compliant
SM SWITCH CO., LTD.
ROTARY DIP SWITCH
SPECIFICATION
Rev. A
P: 4/4
8. Part List
NO
PART NAME
Q'TY
1
COVER
1
MATERIALS
TREATMENT
REMARK
Print:Black
PA66
2
BASE
1
3
ACTUATOR
1
POM
CONTACT AND
4
CONTACT &
TERMINAL
TERMINAL
1
PHOSPHOR BRONZE
PLATING: GOLD
PLATING OVER
Au0.03μm Min
Ni0.1μm Min
NICKEL
5
PCB
1
EPOXY
6
O-Ring
1
SILICONE
PLATING: GOLD
SM SWITCH CO., LTD.
PLATING
Au0.05μm Min
很抱歉,暂时无法提供与“MHR-10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+9.23400
- 10+7.58214
- 50+6.66900
- 100+5.64300
- 500+5.18130
- 1000+4.97610
- 国内价格
- 1+9.24640
- 10+7.75500
- 30+6.11950
- 100+5.96540
- 300+5.26950
- 1000+4.97120
