ABS8
ABS8
    SK(時科)
    ABS
    0.8A表面贴装玻璃钝化桥式整流器 VR=600V IR=5μA ABS
ABS8 数据手册
0.8A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER FEATURES: • Glass Passivated Chip Juntion • Reverse Voltage - 100 to 1000 V • Forward Current - 0.8 A • High Surge Current Capability • Designed for Surface Mount Application MECHANICAL DATA • Case: ABS/LBF • Terminals: Solderable per MIL-STD-750, 750, Method 2026 • Approx. Weight: 88mg 0.0029oz Maximum Ratings and Electrical characteristics Ratings at 25℃ ambient temperature unless otherwise specified.Single phase half-wave wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 1.3mm2 copper pad. 1 of 3 2 of 3 PACKAGE OUTLINE Plastic surface mounted package; 4 leads ABS/LBF 3 of 3
很抱歉,暂时无法提供与“ABS8”相匹配的价格&库存,您可以联系我们找货
ABS8
    • 5000+0.09504
    库存:3000
    ABS8
    • 20+0.13861
    • 100+0.12601
    • 500+0.11761
    • 1000+0.10921
    • 5000+0.09912
    • 10000+0.09492
    库存:3809
    ABS8
      • 5000+0.09504
      库存:9000
      ABS8
      • 20+0.23219
      • 200+0.18438
      • 600+0.15780
      • 5000+0.12609
      • 10000+0.11225
      • 20000+0.10486
      库存:4365
