RH6015D
RH6015D
    RONGHE(融和)
    SOT-23-6
    NMOS开漏输出。 一款内置稳压模块的单通道电容式触摸感应控制开关 IC,可以替代传统的机械式开关 工作电压:2.3V~5.5V• 最高功耗工作电流5.0 uA @3V,低功耗模式工作电流2.5uA@...
RH6015D 数据手册
RH6015-C(D) 单通道触摸感应开关 RH6015-C(D) 规格书 Revision 2.0 2015-07-16 湖南融和微电子有限公司 RH6015_SPEC_Ver2.0 1/10页 07/16/2015 RH6015-C(D) 目 录 1. 简介 .............................................................................................................................................. 3  2. 特点 .............................................................................................................................................. 3  3. Die引脚示意图及坐标 ..................................................................................................................... 4  4. 封装引脚示意图及模式 ................................................................................................................... 5  4.1   引脚示意图 .......................................................................................................................... 5  4.2   默认输出模式 ...................................................................................................................... 5  5. 订购信息 ....................................................................................................................................... 6  6. 功能描述 ....................................................................................................................................... 6  6.1   输出有效电平配置(AHLB) .................................................................................................... 6  6.2   快速/低功耗模式(LPMB) ...................................................................................................... 6  6.3   保持/同步模式(TOG) ........................................................................................................... 6  7. 应用电路图 .................................................................................................................................... 7  8. PCB设计注意事项 .......................................................................................................................... 8  9. 电气参数 ....................................................................................................................................... 9  9.1   最大绝对额定值 ................................................................................................................... 9  9.2   DC电气参数 ........................................................................................................................ 9  10. 封装信息(SOT23-6L) ..................................................................................................................10  湖南融和微电子有限公司 RH6015_SPEC_Ver2.0 2/10页 07/16/2015 RH6015-C(D) 1.简介 2.特点 RH6015 是一款内置稳压模块的单通道电容式触  工作电压:2.3V~5.5V 摸感应控制开关 IC,可以替代传统的机械式开关。  最高功耗工作电流5.0 uA @3v,低功耗模式工 作电流2.5uA@3v RH6015可在有介质(如玻璃、亚克力、塑料、陶瓷  内置高精度稳压模块 等)隔离保护的情况下实现触摸功能,安全性高。  上电0.5s快速初始化  环境自适应功能,可快速应对触摸上电等类似 RH6015内置高精度稳压、上电复位、低压复位、 应用场景 硬件去抖、环境自适应算法等多种有效措施,大大  可靠的上电复位(POR)及低压复位(LVR)性能 提高自身抗干扰性能。  芯片内置去抖动电路,有效防止由外部噪声干 扰导致的误动作 RH6015可通过外部引脚配置成多种工作模式,可 广泛应用于灯光控制、电子玩具、消费电子、家用 电器等产品中。  通过外部引脚配置快速/低功耗模式、正常/延 时模式、同步/保持模式  可通过外部引脚设置高/低电平有效输出、最 大开启时间、延时时间 RH6015-C,CMOS输出。  封装:SOT23-6L RH6015-D,NMOS开漏输出。 湖南融和微电子有限公司 RH6015_SPEC_Ver2.0 3/10页 07/16/2015 RH6015-C(D) 3.Die引脚示意图及坐标 11 VDD TOG 3 12 AHLB LPM 2 13 DLYB GND 1 14 MOT2 ODO 18 15 MOT1 OUT 17 16 TCH RH6015 ( x,y) 图 1 Die Pad 示意图(970uM x758uM 衬底接 VSS) 表1 Die PAD坐标 NO. PADNAME X Y NO. PADNAME X Y 1 GND 359 31 10 - 2 LPM 359 140 11 VDD -359 241 3 TOG 359 241 12 AHLB -359 136 4 - 13 DLYB -359 31 5 - 14 MOT2 -359 -74 6 - 15 MOT1 -359 -179 7 - 16 TCH -359 -284 8 - 17 OC 359 -179 9 - 18 OD 359 -74 湖南融和微电子有限公司 RH6015_SPEC_Ver2.0 4/10页 07/16/2015 RH6015-C(D) 4.封装引脚示意图及模式 4.1 引脚示意图 2 GND 3 TCH TOG VDD AHLB 6 1 5 2 4 3 OD GND TCH RH6015-D OC RH6015-C 1 6 TOG 5 VDD 4 NC 图 2 RH6015-C / RH6015-D (SOT23-6L)引脚示意图表 表 2 引脚功能描述 管脚名称 RH6015-C RH6015-D I/O 描述 VDD 5 5 P AHLB 4 4 I-PL 输出高/低电平有效配置位 DLYB - - I-PH 延时模式配置位 MOT2 - - I-PH 最大开启时间配置位2 MOT1 - - I-PH 最大开启时间配置位1 TCH 3 3 I/O 触摸输入端口 OC 1 - O OD - 1 OD GND 2 2 P LPMB - - I-PH 快速/低功耗模式配置位 TOG 6 6 I-PL 同步/保持模式配置位 正电源 CMOS输出 NMOS开漏输出 负电源 I-PL/ I-PH :带内部下拉/上拉电阻的CMOS输入 OD:CMOS开漏输出,无保护二极管 O:推挽型CMOS输出 I/O:CMOS输入/输出 P:电源/地 4.2 默认输出模式 表3 封装片默认模式设置 SOT23-6L(RH6015-C) OC 引脚输出高有效 SOT23-6L(RH6015-D) 可配置 OD引脚输出低有效 固定 快速模式 固定 快速模式 固定 8s 最大开启时间 固定 8s 最大开启时间 固定 同步模式输出 正常模式 可配置 固定 同步模式输出 可配置 正常模式 固定 可配置:指该封装上有相应模式的配置管脚引出,具体见6.功能描述。 固定: 配置管脚未引出,芯片内部已固定为一种状态。 湖南融和微电子有限公司 RH6015_SPEC_Ver2.0 5/10页 07/16/2015 RH6015-C(D) 5.订购信息 表 4 订购信息 产品型号 产品封装 包装/数量 产品印章 RH6015C SOT23-6L Tape and Reel / 3000 units RH6015D SOT23-6L Tape and Reel / 3000 units RH6015C Wxxxx RH6015D Wxxxx 6.功能描述 RH6015 可通过外部引脚配置为多种模式(表 4)。外部配置引脚悬空时,配置位自动设置为默认状态。 表 5 模式设置引脚功能 功能模式 模式设置引脚 设置为高电平(1)时 设置为低电平(0)时 默认状态 AHLB OC 引脚输出低有效 OC 引脚输出高有效 0 LPMB 快速模式 低功耗模式 1 关闭最大开启时间 见表 8 TOG 保持模式输出 同步模式输出 0 DLYB 正常模式 延时模式 1 MOT2/MOT1 1/1 注:1指配置为电源电压;0指配置为0V电压 表7 功能配置表2 6.1 输出有效电平配置(AHLB) RH6015 可设置 OC 端输出为高/低电平有效。 表6 功能配置表1 配置引脚 配置引脚 0 1(Default) LPMB 低功耗模式 快速模式 6.3 保持/同步模式(TOG) 0(Default) 1 OC OC TOG=0(默认)且 DLYB=1,设置为同步模式,此时 输出高电平有效 输出低电平有效 OC/OD 引脚的输出状态与触摸响应同步:只有触 注意:此配置位对 OD 输出配置无效,触摸有效时 摸有效时输出响应,当触摸释放时,OC/OD 引脚 OD 输出低电平,触摸无效时输出高阻态。 的输出恢复为初始状态。 6.2 快速/低功耗模式(LPMB) TOG=1 且 DLYB=1,设置为保持模式,此时 OC/OD AHLB 引脚的输出状态在触摸有效时后保持:当触摸释放 设置为快速模式,最大触摸响应时间约80ms; 时继续保持为响应状态,直到下次触摸响应后再重 设置为低功耗模式,最大响应时间约180ms,但功 置 OC/OD 状态。 耗比快速模式小。 表8 功能配置表3 湖南融和微电子有限公司 配置引脚 0(Default) 1 TOG 同步模式 保持模式 RH6015_SPEC_Ver2.0 6/10页 07/16/2015 RH6015-C(D) 应用电路图 稳压IC VDD R1 100R E1 10uF 2.5~5V VO VO VIN VCC VDD C3 0.1uF GND D1 LED R2 1 1K 2 Rs 3 OD/OC GND TCH 1K RH6015 Q1 S8050 TOG VDD AHLB /NC 6 J1 5 VDD 4 J2 C1 10uF C2 0.1uF Cj 触摸感应电极 配置位 TOG AHL 1 保持模式 低电平有效 0 同步模式 高电平有效 图 3 应用电路图 说明: 1. Cj 指调节灵敏度的电容,电容值范围 1pF~50pF(电容值的增大将导致灵敏度降低)。 2. Rs 指在触摸电极和触摸输入脚之间串联的电阻,用于提高触摸的抗干扰能力。 3. VDD 与 GND 间需并联滤波电容以消除噪声。 4. 外部 LDO 是否增加视具体应用情况而定。如果电源纹波超过了 IC 内部 LDO 的抗纹波范围,则需另 加外部 LDO,否则会引起灵敏度漂移或触摸芯片检测错误,发生误动作或死机。如突然加载大电流负 载、锂电池和外置充电器交叉使用,高频次的开启/关闭 LED 显示时都需注意电源的稳定性。 5. 请参看,以改善实际应用之可靠性。 湖南融和微电子有限公司 RH6015_SPEC_Ver2.0 7/10页 07/16/2015 RH6015-C(D) 7.PCB设计注意事项 1. 触摸感应盘的大小需依照面板介质、面板厚度等参数设计,可参考下表: 表9 穿透介质厚度参考 RH6015 穿透介质厚度参考 触摸感应盘 PCB 设计 触摸盘大小 穿透介质厚度 Top_ Top Bottom_ Cj 亚克力/ABS 普通玻璃 是否覆铜 覆铜间距 是否覆铜 并联电容 (mm) (mm) 直径 15mm 圆形 √ 1mm × 1pF 7.5 11.0 直径 12mm 圆形 √ 1mm × 1pF 6.0 9.0 直径 10mm 圆形 √ 1mm × 1pF 5.0 7.5 直径 8mm 圆形 √ 1mm × 1pF 4.0 6.0 直径 6mm 圆形 √ 1mm × 1pF 3.0 4.5 直径 15mm 圆形 √ 1mm × 10pF 3.5 5.5 直径 12mm 圆形 √ 1mm × 10pF 3.0 4.5 直径 10mm 圆形 √ 1mm × 10pF 2.5 3.5 直径 8mm 圆形 √ 1mm × 10pF 2.0 3.0 直径 6mm 圆形 √ 1mm × 10pF 1.5 2.0 1.以穿透力与直径成正比关系估算穿透介质厚度。 2.触摸管脚并联 10pF 电容时穿透力约为降一半,当电容越小时,同样电容变化量导致的穿透力下降越明显, 反之,则越不明显。 2. 感应线:在PCB 上,触摸感应盘距离IC的触摸输入管脚(感应线)越短越好,感应线应距离覆铜或 其它走线要有1mm以上,线径选0.15mm~0.2mm。 3. 覆铜:若触摸板附近会有无线电信号或高压器件或磁场,请用20%的网状接地铜箔覆铜,为兼顾穿透 力和抗干扰能力,触摸盘下方尽量避免覆铜。覆铜需距离感应触摸盘2mm,距离感应线1mm以上。 4. 覆盖在触摸盘上的介质面板或表面的涂层不能含有导电类材料或金属成分,更不能将整个金属壳作 为感应电极。 5. VDD 及VSS 需并联滤波电容以消除噪声,在布线时滤波电容必须靠近触摸IC放置。 6. 灵敏度调节电容Cj的容量值越小,灵敏度越高,反之,则越低。当电容越小时,同样电容变化量导致 的穿透力下降越明显,反之,则越不明显。。 7. 灵敏度电容Cj必须使用温度系数小且稳定性佳的电容,如X7R、NPO等。对于触摸应用,推荐使用 NPO材质电容,以减少因温度变化对灵敏度产生的影响。在布线时,灵敏度调节电容一定要远离功 率元器件、发热体等。 8. 感应焊盘可以是不规则形状,比如:椭圆形、三角形及其他不规则形状。触摸盘中间允许穿孔,装 饰LED指示灯等用途。若触摸盘无法靠近面板,可用弹簧将感应线牵引到面壳上,弹簧上方需加一金 属片作为感应电极。 9. 一般情况下应在触摸盘上覆盖好介质再上电,如果先上电再覆盖介质,在 8s 内触摸会被误检测到使 输出有效,8s 过后触摸恢复正常,触摸输出被复位为初始状态。 湖南融和微电子有限公司 RH6015_SPEC_Ver2.0 8/10页 07/16/2015 RH6015-C(D) 8.电气参数 8.1 最大绝对额定值 表 5 最大绝对额定值 项 目 符 号 范 围 单 位 工作电压 VDD -0.3~5.5 V 输入/输出电压 VI / VO -0.5~VDD +0.5 V 工作温度 TOPR -20 ~ 85 ℃ 储藏温度 ESD 水平(HBM) T STG VESD -40 ~ 125 >5000 ℃ V 8.2 DC电气参数 表 6 电气参数表 参数 符号 工作电压 VDD 工作电流 IDD 条件 最小值 典型值 最大值 单位 2.3 3.0 5.5 V LPMB=0(低功耗模式) 2.5 uA LPMB=1(快速模式) 5.0 uA IOL VOL=0.3VDD 20 mA IOH VOH =0.7VDD 10 mA OD引脚驱动电流 IOL VOL=0.3VDD 30 mA 响应时间 T RE OC引脚驱动电流 快速模式 80 ms 低功耗模式(仅指第1次触摸时) (注1) 180 ms 若无特别说明,VDD = 3.0V﹐环境温度 = 25℃,芯片输出无负载 注1:低功耗模式下,一旦检测到触摸会从低功耗模式进入快速模式。因此只有第1次触摸响应需要180ms, 后续的触摸响应都是快速模式下的响应时间为80ms。 湖南融和微电子有限公司 RH6015_SPEC_Ver2.0 9/10页 07/16/2015 RH6015-C(D) 9.封装信息(SOT23-6L) 图 4 SOT23-6L封装图 注意: 规格如有更新﹐恕不另行通知。请在使用该 IC 前更新规格书至最新版本。 湖南融和微电子有限公司 RH6015_SPEC_Ver2.0 10/10页 07/16/2015
