泰州福声电子科技有限公司----- 电声产品专业制造商
FUSHENG ELECTRONICS------Acoustic Components Professional Manufacturer
SPECIFICATION OF PRODUCT
承 认 书
CUSTOMER:
DESCRIPTION:
FUSHENG P/N:
Magnetic Buzzer
FUET-5025
CUSTOMER P/N:
DATE:
CUSTOMER
2018-8-28
APPROVER
CHECKER
Yunqing Wu
Bing Yan
泰州福声电子科技有限公司
地址:江苏省泰州市海陵区凤凰西路168 号
电话:0086-523-86219066 传真:0086-523-81601108
邮箱: sales@electronic-tech.cn
网址:www.tzfsdz.com
FST-5025
1. SPECIFICATION 规格
No.
Item
Unit
Specification
Condition
1
Oscillation Frequency
Hz
4000
Vo-p=1/2duty ,square wave
2
Operating Voltage
Vo-p
2~4
3
Rated Voltage
Vo-p
3
4
Current Consumption
mA
MAX. 110
at Rated Voltage
5
Sound Pressure Level
dB
MIN. 80
at 10cm at Rated Voltage
6
Coil Resistance
Ω
12±3
7
Operating Temperature
-20 ~ +70
8
Storage Temperature
-30 ~ +80
9
Dimension
mm
5.0 x 5.0 x H2.5
10
Weight (MAX)
gram
0.6
11
Housing Material
LCP( Black )
12
Leading Pin
Tin Plated Brass(Sn)
13
Environmental
Protection Regulation
RoHS
See appearance drawing
2. APPEARANCE DRAWING 尺寸图
FST-5025
3. TESTING METHOD 测量方式
Standard Measurement conditions
Temperature:25±2℃ Humidity:45-65%
Acoustic Characteristics:
The oscillation frequency, current consumption and sound pressure are measured by the
measuringinstruments shown below
In the measuring test, buzzer is placed as follows:
4. Typical Frequency Response Curve 频率
FST-5025
5. Recommend DrivingCircuit
The base current Ib should high enough so that it saturates the collectorcurrent of the transistor
with the CB load.
6. Soldering Condition
(1) Recommendablereflow soldering condition is as follows
(Reflow solderingis twice)
Note:It is requested that reflow soldering should be executed
after heat of product goes down to normal.
Heat resistant line
(Used when heat resistantreliability test is performed)
(2)Manualsoldering
Manual soldering temperature 350 ºC within 5 sec.
FST-5025
7. RELIABILITY TEST 可靠性测试
NO.
ITEM
1
High Temperature
Test (Storage)
Afterbeingplacedin a chamberwith 80 2ºC for96 hoursand then
beingplacedin normalconditionfor2 hours.
Allowablevariationof SPLaftertest: 10dB.
2
Low Temperature
Test (Storage)
AfterbeingPlacedin a chamberwith-30 2ºC for96 hoursand then
Humidity Test
AfterbeingPlacedin a chamberwith90-95%R.H.at 40 2ºC for96
hoursandthen beingplacedin normalconditionfor2 hours.
3
TEST CONDITION AND REQUIREMENT
The part shall be subjected to 5 cycles. One cycle shall be consist of:
+70ºC
+25ºC
4
Temperature Cycle
Test
5
Drop Test
6
Vibration Test
7
Solderability
Test
8
Terminal Strength
Pulling Test
+25ºC
- 20ºC
Dropon a hardwood boardof 4cm thick,anydirections,6 times,
at theheightof75cm.
Afterbeingappliedvibrationof amplitudeof 1.5mmwith 10 to 55 Hz
band of vibration frequency to each of 3 perpendicular directions for
2hours .
Lead terminals are immersed in rosin for 5 seconds and then
immersedin solderbathof +300 5ºC for3 1seconds .
90%min.leadterminalsshallbewet with solder
(Excepttheedgeofterminals).
Theforceof 9.8N(1.0kg)is appliedto each terminalin axialdirectionfor
10seconds.
No visible damage and cutting off.
TEST CONDITION.
Standard Test Condition
一般测试条件
Judgment TestCondition
争议时测试条件
a) Temperature: +5~ +35℃
a) 温度 : +5 ~ +35℃
a) Temperature : +25 ± 2℃
a) 温度 : +25 ± 2℃
b) Humidity : 45-85%
b) 湿度 : 45-85%
b) Humidity : 60-70%
b) 湿度 : 60-70%
c) Pressure : 860-1060mbar
c) 气压 : 860-1060mbar
FST-5025
8.
PACKING STANDARD 包装
1 Reel : 2500PCS
通孔
A
A
Carton Box
(10 Inner Box)
Inner Box
(1Layer Reel)
Inner Box
330mmx330mmx30mm
1x2500PCS=2500PCS
Carton Box
350mmx350mmx370mm
10x2500PCS=25,000PCS
FST-5025
很抱歉,暂时无法提供与“FUET-5025”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.34000
- 10+2.16000
- 30+2.12400
- 100+2.01600
- 国内价格
- 1+3.05640
- 10+2.39760
- 30+2.11680
- 100+1.77120
- 500+1.52280
- 1000+1.43640
