RP01503VBLC
RP01503VBLC
    METZCONNECT
    P=5mm
    接线端子 3Pin(1x3) P=5mm
RP01503VBLC 数据手册
Page 1/6 Data sheet P/N 313491xx xx=number of poles RP015xxVBLC Typ 349 2021/09/15 Version: R Illustrations Dimensional drawing See enlarged drawings at the end of document Product specification • screw type terminal block, pluggable • centerline 5.00 mm, direction of connection vertical 0° • lift system, fittable without loss of poles • color black • wire entry codeable side perpendicular to plug direction Data sheet Page 2/6 RP015xxVBLC Typ 349 P/N 313491xx xx=number of poles 2021/09/15 Version: R Technical Data General Data Tightening torque SEV Tightening torque UL 0.5 Nm min. number of poles 2 max. number of poles 24 Insulating material class CTI 600 clearance/creepage dist. 3.6 mm Protection category IP20 Min. insul. strip length 8 mm Rated current 12 A Overvoltage category III III II Pollution degree 3 2 2 Rated voltage 160 V 400 V 400 V Rated test voltage 2.5 kV 2.5 kV 2.5 kV 4.4 lb-in Anschlussdaten rat.wiring solid AWGmax 0.08 mm² - 2.5 mm² / AWG 28 - AWG 12 rat.wiring strand.AWGmax 0.08 mm² - 2.5 mm² / AWG 28 - AWG 12 Approvals extended wiring UL V / A / AWG approval UL - File No. 2.5 mm² 2 AWG 16-18, or 1 AWG 16 stranded with 1 AWG 18 solid, or 1 AWG 16 stranded with 1 AWG 18 stranded 300 / 16 / 28 - 12 E121004 320 V / 4 kV / 13.5 A Material insulating material PA66 flammability class V0 contact material CuSn Contact surface Sn terminal body thread M3 terminal body material CuZnPb terminal body surface Ni screw thread M3 screw material 8,8 screw surface Zn Cr(VI)-frei/free Glow-Wire Flammability GWFI 960 °C acc. to IEC 60695-2-12 Data sheet Page 3/6 RP015xxVBLC Typ 349 P/N 313491xx xx=number of poles 2021/09/15 Version: R Technical Data Glow-Wire Flammability GWIT 775 °C acc. to IEC 60695-2-13 REACh - substance (SVHC) Lead / 7439-92-1 Climatic Data upper limit temperature 105 °C lower limit temperature -40 °C general Tolerance ISO 2768 -mH Data sheet Page 4/6 RP015xxVBLC Typ 349 P/N 313491xx xx=number of poles 2021/09/15 Version: R Accessories P/N Designation 700025-01-9 Coding star white with a group of 6 coding pins Data sheet Page 5/6 RP015xxVBLC Typ 349 P/N 313491xx xx=number of poles 2021/09/15 Version: R Counterpart P/N Designation 311761 PR065xxHBBN Typ 176 311771 PR065xxVBBN Typ 177 312701 PT175xxVGDN Typ 270 312741 PT165xxVGDN Typ 274 312761 PT165xxHGDN Typ 276 312781 PT105xxVGDN Typ 278 312801 PT105xxHGDN Typ 280 313191 PT115xxVBEC Typ 319 313201 PT115xxVBBN Typ 320 313291 PT115xxHBEC Typ 329 313301 PT115xxHBBN Typ 330 313371 PR075xxHBEL Typ 337 313381 PR075xxHBER Typ 338 314761 PR065xxHBEC Typ 476 314771 PR065xxVBEC Typ 477 Data sheet RP015xxVBLC Typ 349 Page 6/6 P/N 313491xx xx=number of poles 2021/09/15 Version: R Illustrations Dimensional drawing L=(pole size - 1) x centerline + 5 mm [0.197] Powered by TCPDF (www.tcpdf.org)
RP01503VBLC 价格&库存
很抱歉,暂时无法提供与“RP01503VBLC”相匹配的价格&库存,您可以联系我们找货
RP01503VBLC
  • 1+9.15978
  • 10+8.45518
  • 30+8.31426
  • 100+7.89150
