Data sheet | Item number: 221-505
Mounting carrier; for 5-conductor terminal blocks; 221 Series - 4 mm²; for
screw mounting; white
www.wago.com/221-505
Color:
Data
Physical data
Width
35 mm / 1.378 inch
Height from the surface
16.9 mm / 0.665 inch
Depth
52.8 mm / 2.079 inch
Mechanical data
Mounting type
Screw mount
Suitable
for 5-wire connectors (4 mm²)
Material data
Note on material data
Information on material data can be found here
Color
white
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Weight
4.8 g
Subject to changes. Please also observe the further product documentation!
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.01.2022 Page 1/5
Weight
4.8 g
Commercial data
eCl@ss 10.0
27-14-11-92
eCl@ss 9.0
27-14-11-92
ETIM 7.0
EC002848
ETIM 6.0
EC002848
PU (SPU)
50 (10) Stück
Packaging type
box
Country of origin
CN
GTIN
4055143640831
Customs tariff number
39269097900
Optional accessories
Marking accessories
Marking strip
Item no.: 210-833
Marking strips; 25 m on roll; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Downloads
Documentation
Bid Text
221-505
2019年2月19日
xml
2.8 kB
Download
2018年1月4日
doc
24.6 kB
Download
pdf
2.2 MB
Download
URL
Download
X81 - Datei
221-505
doc - Datei
Additional Information
Technical Section
Technical explanations
CAD/CAE-Data
CAE data
ZUKEN Portal 221-505
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
07.01.2022 Page 2/5
CAD data
2D/3D Models 221-505
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 221-505
Mounting carrier; for 5-conductor terminal blocks; 221 Series - 4 mm²; for screw
mounting; white
Installation Notes
Inserting a connector into the mounting
carrier.
Removing a connector from the mounting
carrier.
Conductor termination
Inserting a conductor.
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
07.01.2022 Page 3/5
Horizontal screw mounting
Vertical screw mounting
Horizontal mounting via snap-in foot
Vertical mounting via snap-in foot
Strain relief
Use a cable tie to secure the conductors to
the strain relief plate.
The strain relief plate can be removed.
Testing
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
07.01.2022 Page 4/5
Testing a connector mounted on the carrier
via test slot.
Application
Connecting a light to the mains.
Marking
Labeling the mounting carrier.
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
07.01.2022 Page 5/5
很抱歉,暂时无法提供与“221-505”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.41882
- 10+6.84814
- 30+6.73400
- 100+6.39160
- 国内价格
- 10+6.55968
- 100+6.42847
