Negative Temperature Coefficient Thermistor (NTC Series)
Negative Temperature Coefficient Thermistor (NTC)
Data Sheet
Feature
■Wide operating voltage range from φ5 to φ20
■Operating Temperature
Style
Operating Temperature Range
φ5
-40℃~155℃
Φ7/φ9/φ11
-40℃~175℃
Φ13/φ15/φ20
-40℃~200℃
■Storage Temperature: 15℃~35℃
Applications
■Suitable for power supply, electronic motors, transformers, adapters, projectors, halogen machines,
LED drive circuits, etc.
Applicable Standard
Approval
Organization
Safety Standards
Certificate No.
China
CQC
GB/T 6663.1
CQC15001128226
USA
Canada
UL
UL 1434
E474052
Revision: 2018-04-29
1
Email: info@songtian.cn
Website: http://songtian.cn
Part Number Code
MF
05
Songtian
MF:NTC
100
X8
M
Zero Power
Resistance
0R5:0.5Ω
080:8Ω
100:10Ω
121:120Ω
3
B
X7
B
Inner
Management
Encapsulation material
Environmental Standard
S:Silicone+RoHS
P:Phenolic Resin+RoHS
F:Phenolic Resin +Halogen free
R:Phenolic Resin + Halogen free
Foot Type
1:Long straight
2:Outside Crimped
3:Short Straight
4:Inside kink lead
8:Vertical Crimped
Maximum Steady State
Current
X1:0.1A
S5:1.5A
03:3.0A
10:10A
S
Package
B: Bulk
T:Tape
Pitch
B:5.0mm
E:7.5mm
D:10.0mm
Tolerance
M:±20%
Core Diameter
05:5mm
20:20mm
C
Lead Material
F: Tinned copper clad steel wire
C:Copper wire
Lead Length
S0~S9:1.0~1.9mm
X0~X9:2.0~2.9mm
A0~A9:3.0~3.9mm
B0~B9:4.0~4.9mm
C0~C9:5.0~5.9mm
D0~D9:6.0~6.9mm
E0~E9:7.0~7.9mm
Lead Length
F0~F9:8.0~8.9mm
G0~G9:9.0~9.9mm
H0~H9:10.0~10.9mm
J0~J9:11.0~11.9mm
K0~K9:12.0~12.9mm
L0~L9:13.0~13.9mm
M0~M9:14.0~14.9mm
Lead Length
M0~M9:14.0~14.9mm
N0:16~27.0mm(Bulk)
H0=16.5(Taped)
Taping
PO:17.0mm
Q0:20.0mm
Electrical Characteristics
□D-5 Series
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
5D-5
5
1
0.353
2500
<20
>6
-40℃~155℃
10D-5
10
0.7
0.771
2600
<20
>6
-40℃~155℃
15D-5
15
0.6
1.53
2600
<20
>6
-40℃~155℃
20D-5
1.253
2600
<20
>6
-40℃~155℃
22D-5
22
0.6
2.06
2600
<20
>6
-40℃~155℃
30D-5
30
0.4
2.227
2600
<20
>6
-40℃~155℃
2
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
33D-5
33
0.4
1.324
2600
<20
>6
-40℃~155℃
50D-5
50
0.4
2.653
2800
<18
>6
-40℃~155℃
60D-5
60
0.3
1.878
2800
<18
>6
-40℃~155℃
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
5D-7
5
2
0.283
2600
<30
>10
-40℃~175℃
8D-7
8
1
0.539
2600
<28
>9
-40℃~175℃
10D-7
10
1
0.616
2800
<27
>9
-40℃~175℃
12D-7
12
1
0.816
2800
<27
>9
-40℃~175℃
16D-7
16
0.7
1.003
2800
<27
>9
-40℃~175℃
20D-7
1.102
2800
<27
>9
-40℃~175℃
22D-7
22
0.6
1.108
2800
<27
>9
-40℃~175℃
30D-7
30
0.5
3.7059
2800
<28
>10
-40℃~175℃
33D-7
33
0.2
1.485
2800
<28
>10
-40℃~175℃
50D-7
50
0.5
1.653
2800
<28
>10
-40℃~175℃
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
3D-9
3
4
0.120
2600
<35
>11
-40℃~175℃
4D-9
4
3
0.190
2600
<35
>11
-40℃~175℃
5D-9
5
3
0.210
2600
<34
>11
-40℃~175℃
6D-9
6
2
0.315
2600
<34
>11
-40℃~175℃
7D-9
7
2
0.3265
2800
<34
>11
-40℃~175℃
8D-9
8
2
0.400
2800
<32
>11
-40℃~175℃
10D-9
10
2
0.458
2800
<32
>11
-40℃~175℃
12D-9
12
1
0.652
2800
<32
>11
-40℃~175℃
16D-9
16
1
0.802
2800
<31
>11
-40℃~175℃
□D-7 Series
□D-9 Series
3
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
20D-9
0.864
3000
<30
>11
-40℃~175℃
22D-9
22
1
0.950
3000
<30
>11
-40℃~175℃
30D-9
30
1
1.022
3000
<30
>11
-40℃~175℃
33D-9
33
1
1.124
3000
<30
>11
-40℃~175℃
50D-9
50
1
1.252
3200
<30
>11
-40℃~175℃
60D-9
60
0.8
1.502
3200
<31
>11
-40℃~175℃
80D-9
80
0.8
2.010
3200
<30
>11
-40℃~175℃
120D-9
120
0.8
3.015
3200
<30
>11
-40℃~175℃
200D-9
200
0.5
5.007
3400
<32
>11
-40℃~175℃
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
2.5D-11
2.5
5
0.095
2600
<43
>13
-40℃~175℃
3D-11
3
5
0.100
2600
<43
>13
-40℃~175℃
4D-11
4
4
0.150
2600
<44
>13
-40℃~175℃
5D-11
5
4
0.156
2800
<45
>13
-40℃~175℃
6D-11
6
3
0.240
2800
<45
>13
-40℃~175℃
7D-11
7
3
0.2824
2800
<45
>13
-40℃~175℃
8D-11
8
3
0.255
2800
<47
>14
-40℃~175℃
10D-11
10
3
0.275
2800
<47
>14
-40℃~175℃
12D-11
12
2
0.462
2800
<48
>14
-40℃~175℃
15D-11
15
2
0.468
2800
<50
>14
-40℃~175℃
16D-11
16
2
0.470
2800
<50
>14
-40℃~175℃
20D-11
0.512
3000
<52
>15
-40℃~175℃
22D-11
22
2
0.563
3000
<52
>15
-40℃~175℃
25D-11
25
2
0.623
3000
<52
>15
-40℃~175℃
30D-11
30
1.5
0.667
3000
<52
>15
-40℃~175℃
33D-11
33
1.5
0.734
3000
<52
>15
-40℃~175℃
47D-11
47
1.5
1.002
3200
<52
>15
-40℃~175℃
50D-11
50
1.5
1.021
3200
<52
>15
-40℃~175℃
□D-11 Series
4
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
60D-11
60
1.5
1.215
3200
<52
>15
-40℃~175℃
80D-11
80
1.2
1.656
3200
<52
>15
-40℃~175℃
120D-11
120
1.1
2.253
3000
<50
>15
-40℃~175℃
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
1.3D-13
1.3
7
0.062
2600
<60
>13
-40℃~200℃
1.5D-13
1.5
7
0.073
2600
<60
>13
-40℃~200℃
2.5D-13
2.5
6
0.088
2600
<60
>13
-40℃~200℃
3D-13
3
6
0.092
2600
<60
>14
-40℃~200℃
4D-13
4
5
0.120
2800
<67
>15
-40℃~200℃
4.7D-13
4.7
5
0.1469
2800
<67
>15
-40℃~200℃
5D-13
5
5
0.125
2800
<68
>15
-40℃~200℃
6D-13
6
4
0.170
2800
<65
>15
-40℃~200℃
7D-13
7
4
0.188
3000
<65
>15
-40℃~200℃
8D-13
8
4
0.194
3000
<60
>15
-40℃~200℃
10D-13
10
4
0.206
3000
<65
>15
-40℃~200℃
12D-13
12
3
0.316
3200
<65
>16
-40℃~200℃
15D-13
15
3
0.335
3200
<60
>16
-40℃~200℃
16D-13
16
3
0.338
3200
<60
>16
-40℃~200℃
18D-13
18
3
0.356
3200
<60
>16
-40℃~200℃
20D-13
0.372
3200
<65
>16
-40℃~200℃
22D-13
22
3
0.625
3200
<65
>16
-40℃~200℃
25D-13
25
2.5
0.422
3200
<65
>16
-40℃~200℃
30D-13
30
2.5
0.517
3200
<65
>16
-40℃~200℃
33D-13
33
2.5
0.592
3200
<65
>16
-40℃~200℃
47D-13
47
2
0.810
3200
<65
>17
-40℃~200℃
50D-13
50
2
1.161
3200
<65
>13
-40℃~200℃
120D-13
120
1.2
2.124
3400
<65
>17
-40℃~200℃
□D-13 Series
5
□D-15 Series
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
1.3D-15
1.3
8
0.048
2600
<68
>18
-40℃~200℃
1.5D-15
1.5
8
0.052
2600
<69
>18
-40℃~200℃
2.5D-15
2.5
7
0.065
2800
<76
>18
-40℃~200℃
3D-15
3
7
0.075
2800
<76
>18
-40℃~200℃
4D-15
4
6
0.1985
2800
<76
>18
-40℃~200℃
5D-15
5
6
0.112
3000
<76
>20
-40℃~200℃
6D-15
6
5
0.155
3000
<80
>20
-40℃~200℃
7D-15
7
5
0.173
3000
<80
>20
-40℃~200℃
8D-15
8
5
0.178
3000
<80
>20
-40℃~200℃
10D-15
10
5
0.180
3200
<75
>20
-40℃~200℃
12D-15
12
4
0.250
3200
<75
>20
-40℃~200℃
15D-15
15
4
0.268
3200
<85
>21
-40℃~200℃
16D-15
16
4
0.276
3200
<70
>21
-40℃~200℃
18D-15
18
4
0.3375
3200
<70
>21
-40℃~200℃
20D-15
0.288
3200
<86
>21
-40℃~200℃
22D-15
22
4
0.3812
3200
<86
>21
-40℃~200℃
25D-15
25
3.5
0.358
3200
<86
>21
-40℃~200℃
30D-15
30
3.5
0.438
3200
<75
>21
-40℃~200℃
33D-15
33
3
0.571
3200
<86
>21
-40℃~200℃
40D-15
40
3
0.587
3200
<86
>21
-40℃~200℃
47D-15
47
3
0.680
3200
<86
>21
-40℃~200℃
50D-15
50
3
0.734
3200
<86
>21
-40℃~200℃
120D-15
120
1.8
1.652
3400
<87
>22
-40℃~200℃
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
0.7D-20
0.7
11
0.018
2400
<89
>24
-40℃~200℃
1.3D-20
1.3
9
0.037
2600
<88
>24
-40℃~200℃
□D-20 Series
6
Part
Number
Rated Zero
Power
Resistance
@25℃(Ω)
Maximum
Steady
Current
@25℃(A)
Residual
Resistor At
Maximum
Steady Current
@25℃(Ω)
B Value
(K)
±10%
Thermal
Time
Constant
(S)
Heat
Dissipation
Coefficient
(mW/℃)
Operating
Temperature
Range
2.2D-20
2.2
8
0.1292
2800
<88
>24
-40℃~200℃
2.5D-20
2.5
8
0.052
2800
<88
>24
-40℃~200℃
3D-20
3
8
0.055
2800
<88
>24
-40℃~200℃
5D-20
5
7
0.087
3000
<87
>24
-40℃~200℃
6D-20
6
6
0.113
3000
<103
>25
-40℃~200℃
8D-20
8
6
0.142
3000
<105
>25
-40℃~200℃
10D-20
10
6
0.162
3200
<102
>25
-40℃~200℃
12D-20
12
5
0.195
3200
<100
>25
-40℃~200℃
16D-20
16
5
0.212
3200
<100
>25
-40℃~200℃
Dimensions (mm) and Approval
Size (mm)
Part No.
□D-5
□D-7
□D-9
□D-11
□D-13
□D-15
□D-20
D Max.
T Max.
F±0.8
7.0
4.5
9.0
Approval
d±0.05
CQC
cUL
(Canada)
CP
CU
5.0
0.6
0.6
5.0
5.0
0.6
0.6
11.0
6.0
5.0
0.7
0.8
13.0
6.5
7.5
0.7
0.8
15.5
7.0
7.5
0.7
0.8
17.5
7.0
7.5
0.7
0.8
22.5
7.0
10.0
1.0
1.0
7
Lead Configuration
Lead Length
L (mm)
Coating Lead Length
C (mm)
Height
H (mm)
Long Straight
16.0 min
3.0 Max
Short Straight
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
3.0 Max
Outside Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
Not exceed the bend point
5.0mm
Max
Inner Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
6.0mm
Max
Vertical Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
4.0mm
Max
Lead Style
Drawing
8
Taping Specification (mm)
Fig.1
Fig.2
Figure
Fig.1 (P=5.0)
Symbol
P=5.0
P=7.5
P=10.0
Po
12.7±0.3
12.7±0.3
12.7±0.3
P
12.7±1.0
25.4±1.0
25.4±1.0
P1
3.85±0.7
8.95±0.7
7.7±0.7
P2
6.35±1.3
12.7±1.3
12.7±1.3
F
5±0.8
7.5±0.8
10.0±0.8
Δh
0±2.0
0±2.0
0±2.0
W
18.0+1.5/-1.0
18.0 +1.5/-1.0
18.0 +1.5/-1.0
Wo
10.5 Max
10.5 Max
10.5 Max
W1
9.0+0.75/-0.5
9.0+0.75/-0.5
9.0+0.75/-0.5
W2
3.0 Max
3.0 Max
3.0 Max
Do
4.0±0.2
4.0±0.2
4.0±0.2
H
20+1.5/-1.0
20+1.5/-1.0
20+1.5/-1.0
16.5&17.0
16.5&17.0
16.5&17.0
Ho
+1.5/-1.0
+1.5/-1.0
+1.5/-1.0
Straight
Lead
Crimped
Lead
Straight
Lead
Crimped
Lead
Straight
Lead
Crimped
Lead
11.0
Max
9.0
Max
11.0
Max
9.0
Max
11.0
Max
9.0
Max
L
Fig.2 (P=7.5 & 10)
t1
0.5±0.2
0.5±0.2
0.5±0.2
t2
1.7 Max
1.7 Max
1.7 Max
9
很抱歉,暂时无法提供与“MF0908002M4BP0FPT0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39531
- 100+0.31314
- 200+0.30844
- 400+0.27205
- 1000+0.23819
- 国内价格
- 10+0.43125
- 100+0.34161
- 300+0.29679
- 1000+0.25985
- 5000+0.23296
- 10000+0.21946
