G1801DG
G1801DG
    MENTECH(铭普光磁)
    X-FMR18_17X8.5MM_TM
    100/1000 BASE-T 单端口通孔磁性材料
G1801DG 数据手册
100/1000 BASE-T SINGLE PORT THROUGH HOLE MAGNETICS Meets IEEE 802.3 & ANSI X3.263 Standards. RoHS Compliant. 100/1000 Base-T,Through-Hole Type . Operating temperature range: 0 ℃ to +70℃. Electrical Specifications @25°C Part Number OCL(uH) 100KHz,0.1Vrms, With 8mA DC Bias G1801DG 350uH Turns Ratio (±5%) 1CT:1CT Return Loss (dB Min) Insertion Loss (dB Max) Cross talk (dB Min) CMRR (dB Min) 0.5-100MHz 0.5-40MHz 10.1-100MHz 0.5-40MHz 40.1-100MHz 0.5-100MHz -1.1 -18 -18+20*log(f/30) -35 -33+20*log(f/50) -30 HI-POT (Vrms) 1500 MECHANICAL G1801DG 17.0 ∅0.8 8.5 4.8 G18XXDG YYWWX 14.24 SUGGESTED PAD LAYOUT 12.0Max 3.2 0.4 1.78 14.24 4.8 Unless otherwise specified all tolerances are:±0.25 in mm SCHEMATICS 1CT:1CT 18 1 2 17 1CT:1CT 16 3 15 4 5 1CT:1CT 14 13 6 1CT:1CT 7 12 8 11 9 10
