UHP252012NF-100M
UHP252012NF-100M
    TAI-TECH(台庆)
    SMD,2.5x2mm
    功率电感 10µH ±20% 492mΩ IND_2.5X2MM_SM
UHP252012NF-100M 数据手册
P2 TAI-TECH Power Inductor UHP252012NF-SERIES 1. Features 1. This specification applies Low Profile Power Inductors. 2. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 2. Dimension Halogen Pb Halogen-free Pb-free B A D E D C Series A(mm) UHP252012NF 2.5 -0.1/+0.3 B(mm) C(mm) D(mm) E(mm) 2.0 -0.05/+0.35 1.2 max. 0.85 ref. 0.80 ref. Units: mm 3. Part Numbering UHP 252012 NF A B - 4R7 M D E C A: Series B: Dimension C: Lead Free Material D: Inductance E: Inductance Tolerance 4R7=4.7uH M=±20% Y=±30% 4. Specification TAI-TECH Part Number Inductance Tolerance (uH) (%) Test Frequency (Hz) DCR (Ω) ±20% I sat (A) typ. I sat (A) Max. I rms (A) typ I rms (A) Max. 0.028 4.00 3.60 3.70 3.35 UHP252012NF-R47Y 0.47 ±30% 0.1V/1M UHP252012NF-R68Y 0.68 ±30% 0.1V/1M 0.036 3.00 2.70 3.30 3.00 UHP252012NF-1R0Y 1.0 ±30% 0.1V/1M 0.049 2.70 2.45 2.60 2.30 UHP252012NF-1R5Y 1.5 ±30% 0.1V/1M 0.063 2.30 2.05 2.20 1.95 UHP252012NF-2R2M 2.2 ±20% 0.1V/1M 0.080 2.15 1.95 1.85 1.65 UHP252012NF-3R3M 3.3 ±20% 0.1V/1M 0.120 1.70 1.50 1.45 1.30 UHP252012NF-4R7M 4.7 ±20% 0.1V/1M 0.176 1.50 1.35 1.20 1.05 UHP252012NF-6R8M 6.8 ±20% 0.1V/1M 0.250 1.15 1.00 1.00 0.90 0.75 0.65 UHP252012NF-100M 10 ±20% 0.1V/1M 0.410 0.85 0.75 UHP252012NF-150M 15 ±20% 0.1V/1M 0.540 0.63 0.56 0.60 0.54 UHP252012NF-220M 22 ±20% 0.1V/1M 0.850 0.56 0.50 0.50 0.45 Note: www.tai-tech.com.tw P3 TAI-TECH UHP252012NF-R68 0.75 0.9 Inductance(uH) 1.2 0.5 0.25 0.6 0.3 0 0 0 1 2 3 4 5 0 1 DCcurrent(A) 1.6 2 Inductance(uH) 2.5 1.2 0.8 4 1.5 1 0.5 0 0 0 0.6 1.2 1.8 2.4 0 3 0.5 1 1.5 2 2.5 DCcurrent(A) DCcurrent(A) UHP252012NF-2R2 UHP252012NF-3R3 3.5 6 2.8 4.8 Inductance(uH) Inductance(uH) 3 UHP252012NF-1R5 2 0.4 2.1 1.4 0.7 3.6 2.4 1.2 0 0 0.5 1 1.5 2 0 2.5 0 DCcurrent(A) 0.4 0.8 1.2 1.6 2 DCcurrent(A) UHP252012NF-6R8 UHP252012NF-4R7 8 10 6.4 8 Inductance(uH) Inductance(uH) 2 DCcurrent(A) UHP252012NF-1R0 Inductance(uH) Inductance(uH) UHP252012NF-R47 1 4.8 3.2 1.6 6 4 2 0 0 0.3 0.6 0.9 DCcurrent(A) 1.2 1.5 0 0 0.3 0.6 0.9 DCcurrent(A) www.tai-tech.com.tw 1.2 1.5 P4 TAI-TECH UHP252012NF-150 25 12.8 20 Inductance(uH) Inductance(uH) UHP252012NF-100 16 9.6 6.4 15 10 5 3.2 0 0 0 0.2 0.4 0.6 0.8 0 1 UHP252012NF-220 30 Inductance(uH) 25 20 15 10 5 0 0 0.1 0.2 0.3 0.4 0.5 0.2 0.4 DCcurrent(A) DCcurrent(A) 0.6 DCcurrent(A) www.tai-tech.com.tw 0.6 0.8
UHP252012NF-100M
PDF文档中包含的物料型号为UHP252012NF系列,是低剖面功率电感器。
以下是该系列电感器的详细信息:
- 器件简介:UHP252012NF系列电感器是低剖面功率电感器,符合RoHS标准,无铅和无卤素。
- 引脚分配:文档中未提供具体的引脚分配图,但通常这类电感器会有明确的引脚标识。
- 参数特性: - 尺寸:A=2.5mm ±0.1/+0.3,B=2.0mm ±0.05/+0.35,C=1.2mm max.,D=0.85mm ref.,E=0.80mm ref. - 系列编号:UHP252012NF - 电感值:如4R7表示4.7uH,后面的字母表示电感值的容差,如M=20%,Y=30%。
- 功能详解:文档中未提供具体功能详解,但通常这类电感器用于电源管理,提供能量存储和滤波功能。
- 应用信息:适用于低剖面应用的功率电感器,具体应用场景未在文档中详细说明。
- 封装信息:文档提供了电感器的尺寸参数,但未提供封装类型或封装材料的详细信息。
如果需要更详细的信息,建议访问TAI-TECH的官方网站或联系制造商获取完整的技术规格书和应用指南。
UHP252012NF-100M 价格&库存
很抱歉,暂时无法提供与“UHP252012NF-100M”相匹配的价格&库存,您可以联系我们找货
UHP252012NF-100M
    • 10+0.15752
    • 100+0.12642
    • 300+0.11087
    • 2000+0.08856
    • 4000+0.07922
    • 10000+0.07452
    库存:64
    UHP252012NF-100M
    • 20+0.17962
    • 200+0.16788
    • 500+0.15614
    • 1000+0.14440
    • 3000+0.13853
    • 6000+0.13031
