TMPC1707HP-220MG-D
TMPC1707HP-220MG-D
    TAI-TECH(台庆)
    IND_16.9X16.9MM_SM
    功率电感 22µH ±20% 1707 7.00mm 17.60 x 16.90mm 26.5mΩ 12A
TMPC1707HP-220MG-D 数据手册
TAI-TECH P2 SMD Power Inductor TMPC1707HP-Series(G)-D 1. Features 1. Carbonyl Powder. 2. Compact design. Halogen 3. High current,low DCR,high efficiency. 4. Very low acoustic noise and very low leakage flux noise. Halogen-free 5. High reliability. 6. 100% Lead(Pb)-Free and RoHS compliant. 7. Operating temperature -40~+125℃(Including self - temperature rise) 2. Applications Note PC power system,incl. IMVP-6 DC/DC converter . 3. Dimensions A A` D 330 1930 L E H B Recommend PC Board Pattern C G Series A(mm) A’(mm) B(mm) C(mm) D(mm) E(mm) TMPC1707HP 17.6±0.4 16.9±0.3 16.9±0.3 6.7±0.3 2.1±0.3 11.9±0.3 4. Part Numbering TMPC 1707 HP A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: Code - 330 MG D E - L(mm) G(mm) H(mm) 18.5 12.2 12.5 Note: 1. The above PCB layout reference only. 2. Recommend solder paste thickness at 0.17mm and above. D F BxC HP:H:Carbonyl Powder,P:PAD broaden. 330=33.0uH M=±20% Marking: Black.330 and 1930(19 YY,30 WW,follow production date). TAI-TECH P3 5. Specification Part Number Inductance L0 (uH)±20% I rms ( A ) Typ I sat 1 ( A ) Typ I sat2 ( A ) Typ DCR (mΩ) Typ. @25℃ DCR (mΩ) Max. @25℃ TMPC1707HP-R45MG-D 0.45 62.0 85.0 125.0 0.8 0.96 TMPC1707HP-R47MG-D 0.47 62.0 80.0 123.0 0.95 1.03 TMPC1707HP-1R0MG-D 1.00 52.0 60.0 70.0 1.6 2.0 TMPC1707HP-1R3MG-D 1.30 49.0 54.0 67.0 1.7 2.3 TMPC1707HP-1R5MG-D 1.50 47.0 52.0 65.0 2.0 2.5 TMPC1707HP-1R8MG-D 1.80 45.0 49.0 63.0 2.1 2.5 TMPC1707HP-2R2MG-D 2.20 43.5 47.0 62.0 2.4 2.7 TMPC1707HP-3R3MG-D 3.30 28.0 45.0 54.0 3.5 3.9 TMPC1707HP-4R7MG-D 4.70 25.0 41.0 50.0 4.8 5.5 TMPC1707HP-5R6MG-D 5.60 21.0 40.0 45.0 5.8 7.05 TMPC1707HP-6R8MG-D 6.80 19.0 32.0 39.0 8.4 9.2 TMPC1707HP-7R4MG-D 7.40 18.5 27.0 34.0 8.8 9.7 TMPC1707HP-8R2MG-D 8.20 18.0 25.0 31.0 9.6 10.8 TMPC1707HP-100MG-D 10.0 16.5 24.0 29.0 11.8 13.0 TMPC1707HP-150MG-D 15.0 12.5 23.0 27.0 17.8 20.5 TMPC1707HP-220MG-D 22.0 12.0 18.0 23.0 25.1 26.5 TMPC1707HP-330MG-D 33.0 10.7 15.0 20.0 38.0 44.0 TMPC1707HP-390MG-D 39.0 9.2 11.0 18.0 40.0 48.0 TMPC1707HP-470MG-D 47.0 8.7 9.5 16.0 48.0 55.0 TMPC1707HP-560MG-D 56.0 7.8 9.0 15.0 54.0 62.0 TMPC1707HP-680MG-D 68.0 7.0 8.0 13.0 68.0 80.0 TMPC1707HP-820MG-D 82.0 5.7 7.0 12.0 87.0 100.0 TMPC1707HP-101MG-D 100 5.3 6.5 12.0 102.0 118.0 Note: 1. Test frequency : L/Q: 100KHz /1.0V. 2. All test data referenced to 25℃ ambient. 3. Testing Instrument : L/Q: HP4284A,CH11025,CH3302,CH1320 ,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER. 4. Heat Rated Current (Irms) will cause the coil temperature rise approximately Δt of 40℃. 5. Saturation Current (Isat1) will cause L0 to drop approximately 20%. Saturation Current (Isat2) will cause L0 to drop approximately 30%. 6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 7. Special inquiries besides the above common used types can be met on your requirement. TAI-TECH 10. Typical Performance Curves P8 TAI-TECH P9
TMPC1707HP-220MG-D 价格&库存
很抱歉,暂时无法提供与“TMPC1707HP-220MG-D”相匹配的价格&库存,您可以联系我们找货
TMPC1707HP-220MG-D
  • 1+8.19250
  • 30+7.91000
  • 100+7.34500
  • 500+6.78000
  • 1000+6.49750
