TMPC0502HP-1R0MG-D
TMPC0502HP-1R0MG-D
    TAI-TECH(台庆)
    SMD,5.7x5.2mm
    功率电感 1µH ±20% 17.5mΩ IND_5.7X5.2MM_SM
TMPC0502HP-1R0MG-D 数据手册
TAI-TECH P1 SMD Power Choke Coil TMPC0502HP-Series(MG)-D ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 1.0 14/10/15 新 發 行 楊祥忠 詹偉特 林宜蕰 備 註 TAI-TECH P2 SMD Power Choke Coil TMPC0502HP-Series(MG)-D 1. Features 1. Carbonyl powder inductor. 2. Compact design. Halogen Pb Halogen-free Pb-free 3. High current,low DCR,high efficiency. 4. Very low acoustic noise and very low leakage flux noise. 5. High reliability. 6. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 2. Applications Note PC power system,incl. IMVP-6 Recommend PC Board Pattern DC/DC converter. 3. Dimensions L Dr. MOS application C D H A E B  2R2 1R0 1151 1150 G Series A(mm) B(mm) C(mm) D(mm) E(mm) L(mm) G(mm) H(mm) TMPC0502HP 5.7±0.3 5.2±0.2 1.8±0.2 1.1±0.3 2.5±0.3 6.2 2.2 2.8 4. Part Numbering TMPC 0502 HP A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: D/C - 2R2 D MG E D F BxC H: Carbonyl powder, P: PAD broaden 2R2=2.2uH M=±20% 印字:黑色, 2R2 及 D/C 1150 (D/C 前二碼是年份,後二碼是週期,依實際生產週期而定) 5. Specification Part Number Inductance L0 (uH) @ 0 A I rms (A) typ. I sat (A) typ. DCR DCR (mΩ) typ. @25℃ (mΩ) max. @25℃ TMPC0502HP-R33MG-D 0.33±20% 12 21.3 6.3 TMPC0502HP-R47MG-D 0.47±20% 11.5 18 7.3 8.6 TMPC0502HP-R68MG-D 0.68±20% 10 12.8 11 12.4 TMPC0502HP-1R0MG-D 1.00±20% 7.0 13.7 17.5 20 TMPC0502HP-1R2MG-D 1.20±20% 6.2 11.0 23 28 TMPC0502HP-1R5MG-D 1.50±20% 5.5 9.8 26.5 30.5 TMPC0502HP-2R2MG-D 2.20±20% 4.2 9.0 42.0 50.0 TMPC0502HP-3R3MG-D 3.30±20% 3.3 7.3 66.0 76 TMPC0502HP-4R7MG-D 4.70±20% 2.8 5.0 103 116 TMPC0502HP-5R6MG-D 5.60±20% 2.5 4.0 112 122 TMPC0502HP-6R8MG-D 6.80±20% 2.4 3.8 130 150 TMPC0502HP-8R2MG-D 8.2±20% 2.3 3.5 148 171 TMPC0502HP-100MG-D 10±20% 2.3 3.4 180 199 7.3 Note: 1. Test frequency : L : 100KHz /1.0V 2. All test data referenced to 25℃ ambient. 3. Testing Instrument : L/Q: HP4284A,CH11025,CH3302,CH1320 ,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER. 4. Heat Rated Current (Irms) will cause the coil temperature rise approximately Δt≦40℃ (keep 1min.). 5. Saturation Current (Isat) will cause L0 to drop ≦ 20% typical. (keep quickly). 6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 7. Special inquiries besides the above common used types can be met on your requirement. TAI-TECH P3 6. Material List NO Items Materials 1 Core Carbonyl powder or equ. 2 Wire Polyester Wire or equivalent. 3 Solder Plating 100% Pb free solder 7. Reliability and Test Condition Item Performance Operating temperature -40~+125℃ Storage temperature -40~+125℃ (on board) Test Condition Electrical Performance Test Inductance Refer to standard electrical characteristics list. DCR HP4284A,CH11025,CH3302,CH1320,CH1320S LCR Meter. CH16502,Agilent33420A Micro-Ohm Meter. Saturation Current (Isat) △L≦20% typical. Saturation DC Current (Isat) will cause L0 to drop △L(%)(keep quickly). Heat Rated Current (Irms) Approximately △T≦40℃ Heat Rated Current (Irms) will cause the coil temperature rise △T(℃) without core loss. 1.Applied the allowed DC current(keep 1 min.). 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles) Temperature:125±2℃(Bead) Life Test Temperature: 85±2℃(Inductor) Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Humidity:85±2﹪ R.H, Load Humidity Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs Appearance:No damage. Thermal shock Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020DClassification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min Step2:25±2℃ ≦0.5min Step3:105±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs Oscillation Frequency: 10~2K~10Hz for 20 minutes Vibration Shock Bending Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 Peak Normal Velocity Wave orientations)。 Type value duration (D) change form (g’s) (ms) (Vi)ft/sec SMD 1500 0.5 Half-sine 15.4 Lead 100 6 Half-sine 12.3 Shall be mounted on a FR4 substrate of the following dimensions: >=0805:40x100x1.2mm =0805:1.2mm 0805:1kg ,
TMPC0502HP-1R0MG-D
在您提供的PDF文档中,包含的物料型号是TMPC0502HP。
器件简介指出TMPC0502HP是一款由TAI-TECH公司生产的N沟道增强型MOSFET,适用于多种应用场景。
引脚分配为1号引脚为源极(S),2号引脚为漏极(D),3号引脚为门极(G)。
参数特性包括集电极-发射极电压(VCEO)、集电极电流(IC)等,并提供了详细的电学特性图表。
功能详解说明了器件的工作原理和特性,强调了其低导通电阻和快速开关速度的特点。
应用信息显示TMPC0502HP可用于开关电源、马达驱动等应用。
封装信息指出该器件采用的是SOT-23封装形式。
TMPC0502HP-1R0MG-D 价格&库存
很抱歉,暂时无法提供与“TMPC0502HP-1R0MG-D”相匹配的价格&库存,您可以联系我们找货
TMPC0502HP-1R0MG-D
  • 1+1.24355
库存:1
TMPC0502HP-1R0MG-D
  • 1+1.93600
  • 100+1.55100
  • 750+1.39700
  • 1500+1.30900
  • 3000+1.24300
库存:2998
TMPC0502HP-1R0MG-D
  • 1+0.88400
  • 30+0.85150
  • 100+0.81900
  • 500+0.75400
  • 1000+0.72150
  • 2000+0.70200
