TAI-TECH
P1
SMD Power Inductor
TMPC0605H-Series(G)-D
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
15/06/05
新發行
楊祥忠
詹偉特
何秦芝
備
注
TAI-TECH
P2
SMD Power Inductor
1. Features
1. Carbonyl Powder.
2. Compact design.
3. High current,low DCR,high efficiency.
Halogen
Pb
Halogen-free
Pb-free
4. Very low acoustic noise and very low leakage flux noise.
5. High reliability.
6. 100% Lead(Pb)-Free and RoHS compliant.
2. Applications
Note PC power system,incl. IMVP-6
DC/DC converter .
3. Dimensions
Recommend PC Board Pattern
Dr. MOS application
C
A
D
E
B
1R0
1151
H
L
G
Series
A(mm)
TMPC0605H
B(mm)
7.3±0.3
6.6±0.3
C(mm)
D(mm)
1.8±0.3
4.8±0.2
E(mm)
L(mm)
G(mm)
H(mm)
3.0±0.3
8.4
2.5
3.5
4. Part Numbering
TMPC
0605
H
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F: 印 D/C
1R0
MG
D
E
D
F
BxC
Carbonyl Powder.
1R0=1.00uH
M=±20%
印字:黑色 1R0 及 D/C 1151 (11 年,51 週期)(依實際生產日期而定).
TAI-TECH
P3
5. Specification
Part Number
Inductance
L0 (uH)±20% @ 0 A
I rms (A)
Typ.
I sat (A)
Typ.
DCR
(mΩ) Typ.@25℃
DCR
(mΩ) Max.@25℃
TMPC0605H-R22MG-D
0.22
25
35
1.6
1.9
TMPC0605H-R33MG-D
0.33
25
32
2.5
3.0
TMPC0605H-R40MG-D
0.40
23
31
3.1
3.7
TMPC0605H-R47MG-D
0.47
22
30
3.5
3.9
TMPC0605H-R56MG-D
0.56
3.6
4.2
TMPC0605H-R60MG-D
0.60
19
25
3.8
4.3
TMPC0605H-R68MG-D
0.68
18
24
4.0
4.5
TMPC0605H-R82MG-D
0.82
16.5
22
4.6
4.9
TMPC0605H-1R0MG-D
1.00
15
6.5
TMPC0605H-1R2MG-D
1.20
14
18
6.7
7.5
TMPC0605H-1R5MG-D
1.50
12
16.5
8.6
9.0
TMPC0605H-1R8MG-D
1.80
12
15
9.5
11.0
TMPC0605H-2R2MG-D
2.20
10
14
11.2
12.0
TMPC0605H-3R3MG-D
3.30
8
12
19
20.9
TMPC0605H-4R7MG-D
4.70
6.5
10
28
30.8
TMPC0605H-5R6MG-D
5.60
6.0
9.0
43.5
49
TMPC0605H-6R8MG-D
6.80
5.5
8.5
46
51.5
TMPC0605H-8R2MG-D
8.20
5.0
8.0
56
63
TMPC0605H-100MG-D
10.0
4.0
7.5
60
69
TMPC0605H-150MG-D
15.0
3.5
6.0
81
92
TMPC0605H-220MG-D
22.0
2.5
5.5
140
170
TMPC0605H-470MG-D
47.0
1.9
2.7
290
330
TMPC0605H-560MG-D
56.0
1.6
2.1
342
396
TMPC0605H-680MG-D
68.0
1.2
2.0
386
445
Note:
1. Test frequency : L : 100KHz /1.0V;
2. All test data referenced to 25℃ ambient.
3. Testing Instrument : L/Q: HP4284A,CH11025,CH3302,CH1320 ,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately Δt of 40℃ (keep 1min.).
5. Saturation Current (Isat) will cause L0
to drop
20% typical. (keep quickly).
6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Special inquiries besides the above common used types can be met on your requirement.
TAI-TECH
P4
6. Material List
NO
Items
1
Core
Carbonyl Powder.
Materials
2
Wire
Polyester Wire or equivalent.
3
Solder Plating
100% Pb free solder
7. Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃ (Including self - temperature rise)
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Inductance
Refer to standard electrical characteristics list.
DCR
HP4284A,CH11025,CH3302,CH1320,CH1320S
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
△L≦20% typical.
Saturation DC Current (Isat) will cause L0
to drop △L(%)(keep quickly).
Approximately △T≦40℃
△T(℃) without core loss.
1.Applied the allowed DC current(keep 1 min.).
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through IR reflow for 2
times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles)
Temperature:125±2℃(Bead)
Life Test
Temperature: 85±2℃(Inductor)
Appearance:No damage.
Applied current:rated current
Inductance:within±10% of initial value
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not
Load Humidity
times.( IPC/JEDEC
Humidity:85±2﹪ R.H,
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
Thermal
shock
times.( IPC/JEDEC J-STD-020DClassification
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Step2:25±2℃ ≦0.5min
Step3:105±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Vibration
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Type
Peak
value
(g’s)
Normal
duration (D)
(ms)
Wave
form
Velocity
change
(Vi)ft/sec
SMD
1500
0.5
Half-sine
15.4
Lead
100
6
Half-sine
12.3
Shock
Bending
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805:40x100x1.2mm
=0805:1.2mm
0805:1kg ,
很抱歉,暂时无法提供与“TMPC0605H-100MG-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.79938
- 50+1.78139
- 160+1.74576
- 320+1.69339
- 800+1.62565
- 国内价格 香港价格
- 800+4.43365800+0.57340
- 1600+4.161001600+0.53813
- 2400+4.010022400+0.51861
- 4000+3.828284000+0.49510
- 5600+3.713485600+0.48026
- 8000+3.595918000+0.46505
- 国内价格 香港价格
- 1+8.389931+1.08505
- 10+6.6820510+0.86417
- 25+6.1261425+0.79228
- 50+5.7376050+0.74203
- 100+5.37660100+0.69534
- 250+4.93648250+0.63842
- 国内价格
- 1+1.98299
- 10+1.55434
- 30+1.37063
