KSD.301-55/103PAK
KSD.301-55/103PAK
    XCFUSE(旭程)
    SW2_33.6X32MM_TM
    温控开关 SW2_33.6X32MM_TM 10A 250V ±3℃ 55℃ 10000Cycles
KSD.301-55/103PAK 数据手册
温控器系列 KSD301 试验报告 Test report of thermostat KSD301 series 客户名称 Customer W.HQ 产品型号 Product model KSD301 温度规格 Temperature specification 生产日期 Date: 样品数量 Sample quantity: 2018-01-24 5pcs 壳体材料 √塑料 PF □陶瓷 Ceramic 120/103PAB/18IB/RTG-WHQ Shell material: □高温塑料 PPS 动作温度 Switching temperature 端子: Tab 120+/-3℃ □4.8mm √6.3mm√180o □90 o □20o □45 o □大铝盖 复位温度 Reset temperature Big Aluminum cap with fixed bracket √小铝盖带活动环 Small aluminum cap with moveable bracket □ 小铝盖不带活动环 Small aluminum cap without movable bracket 特殊要求 Special request: 105+/-5℃ 技术说明 Technology of specification 接触电阻 Resistance of contact ≤50 mΩ 绝缘电阻 Resistance of Insulated Dc 500V >100 MΩ 耐压 Test voltage >AC 1500V/1Min CQC、TUV 参数 EnduranceCycles tested AC250V 10A 100,000 cycles VDE、UL 参数 EnduranceCycles tested AC250V 10A 100,000 cycles 测试数据 Test data 动作温度 (℃) NO. switching temperature 1 复位温度 (℃) 接触电阻 (mΩ) 耐 压 Reset temperature Resistance of contact Test voltage 117-123 100-110 ≤50 mΩ 合格(OK) 2 117-123 100-110 ≤50 mΩ 合格(OK) 3 117-123 100-110 ≤50 mΩ 合格(OK) 4 117-123 100-110 ≤50 mΩ 合格(OK) 5 117-123 100-110 ≤50 mΩ 合格(OK) 结论 conclusion 合格 (OK) 测试设备 Testing Device: 恒温测温桶:Thermostatic temperature measurement barrel; 温度异常时以我方测温为准: It is subject to our test temperature when the temperature anomalies 拟制(Prepared by): 刘春青 审核 (Checked by): 齐俊刚 审批(Approved by):吴斌怀 3.6 0.8 32+/-1 11.8+/-0.5 承认/ SIGNATURE 24+/-0.5 φ16+/-0.2 A 33.6+/-1 3 B120 PM 0.4 核准/ APPROVED BY φ 1.8 技术要求(Technology Specification) 1、电气性能(Electric Performance): 额定电压/电流(Rated Voltage/Current):250V10A 名称/Name 型号/Model Thermostat/温控器 KSD301 (Phenolic) IP-防护等级(Protection Degree): IP00级 寿命(Operation Cycles):CQC、TUV 10000 VDE、UL 100000 接触电阻(Resistance of Contact): ≤50mΩ 绝缘电阻(Resistance of Insulated):≥100MΩ 耐压(Test Voltage):≥1500V/1min (Normality) 2、适用标准(Relevant Standards) UL873,CSA C22.2 NO 24-93 EN 60730-1 2012-10 EN 60730-2-9:2011-07 GB14536.1-2008 idt IEC 60730-1-2008 GB14536.10-2008 idt IEC 60730-2-9-2010 3、证书号码(Certificate No): 自动复位 XC-WK.CP/K3.01-XXXX A/1 图号/Code 版本/Edition 电木 1/1 XC ELECTRONICS (SHENZHEN)CO.,LTD. 旭程电子(深圳)有限公司温控器事业部 页次/Total 材质/Material □ CQC: CQC04002009128 √ TUV: 50035898 □ VDE: 40020934 √  U L: E251340 复位状态/Auto/Manual reset 120+/-3℃ 4、客户代码:W.HQ 动作温度/Open 同 temperature 105+/-5℃ 编码/Part.NO 活动支架/Bracket 6.3*0.8平脚 复位温度/Close temperature 端子尺寸/Terminal size 刘春青 2018-01-23 批准/Approved by 审核/Checked by 设计/Designed by 小铝盖带活动环 6.3 A 向 KSD301 客户签章/ CUSTOMER 日期/Date 技术规格 Technology Specification 1.型号命名 (Type Designation) KSD.301- XXX / XX X X X X 触点 接 触状 态: B常闭 、 K常 开 Contact status:Nomally Closed、 Nomally Open A/C. 6.3x0.8 端子 flat push-on connectors B/D .4.8x0.8 端 子 flat push-on connectors B/C. 陶瓷 壳 体 ceramic material P. 塑 料电 木 壳体PF ( plastic) material S.高 温塑 料 壳体 high-temp material 铝 盖 及安 装 固定 环 Shell and fixed bracket 电 流 (Rated Current)250 V (1-10A )/125V (1-15A ) 动 作 温度 Switching Temperature 产 品 设计 型 号Type Code 0~ 150 ℃ 塑 料电 木 壳体(0 ~ 150 ℃ for KSD301XPZ) 0~ 210 ℃ 陶 瓷壳 体 (0 ~ 210 ℃ for KSD301XCZ) 0~ 180 ℃ 高 温塑 料 壳体﹝0 ~ 180℃ forKSD301XSZ﹞ 2.适用标准(Relevant Standards) UL873, CSA C22.2 NO 24-93 EN60730-1 2000+A11 EN60730-2-9:2002 GB14536.1-2008 idt IEC730-1 GB14536.10-2008 idt IEC730-2-9-1992 3.电气性能(Electric Performance): 额定电压(Rated Voltage): AC125V 50~60Hz 额定电流(Rated Current):1-10A/1-15A of Resistive Load 开关类型和单极断开(Switch Type and Number of poles): 1 pole opener IP-防护等级(Protection Degree): IP00 动作类型(Action Type):2C 认证(Approved Symbol):CQC、T¨ V、 VDE、 UL 寿命(Operation Cycles): CQC、T¨ V 10,000 VDE、 UL 100,000 所用绝缘材料 PTI 值(Insulation material PTI value):175V 接触电阻(Resistance of Contact): ≤50mΩ(Original State) 绝缘电阻(Resistance of Insulated):≥100MΩ(DC500V Normality) 耐压( Test Voltage ): ≥ 1250V/1min(Normality) 4.端子应能承受的轴向力(Axis force that tab can endure) 作用于端子的轴向力 1min(如下表)不应有位移和损坏。 Axis force that Tab can endure for 1min, and no deformation and damage. 推力 thrust force(N) 拉力 pull force(N) 扭力 torque (N.m) 80 70 0.2 5.标志 (Marking) 在温控器壳体上应标注商标 , 额定电压 250V/125V(必要时)电流性质交流~,认 证标志(必要时),型号标志 KSD301,动作温度标示应清晰、持久、耐用,应印在主 体及不可拆部体上。 On the thermostat, our trade mark ; voltage rating 250V/125V AC(necessary); approved symbol (necessary).And item No.KSD301 should be carved. Switching temperature should be on the main part of the thermostat or on the part that cannot be torn up. The mark should be clear and durable. 6.环境试验(Ambient test) 6.1 环境应力(Ambient resistance stress) 温控器在-10℃+/-2℃ 24h,+60℃+/-5℃ 4h,塑料件不应开裂、变形,温控器仍能正常工 作。 Under the situation of -10℃+/-2℃ 24h,+60℃+/-5℃ 4h, the plastic parts should be no breaking and deformation, and the thermostat can work normally. 6.2 潮湿试验(Humidity resistance test) 温控器在相对湿度 91~95%温度在 20~30(+/-1℃)潮湿箱内处理 48h 应能承受 AC 1250V,频率 50Hz-60Hz 1min 不应产生闪络或击穿. In the humid box of relative humidity 91-95%, temperature 20~30(+/-1℃)for 48 hours, the thermostat should endure voltage of 1250V AC. When the frequency is 50Hz-60Hz 1min, flashover and bumping is not allowed. 7. 温控器的发热(Heat resistance test) 温控器在比工作温度低 5℃+/-1℃环境条件下,通 10.6A 电流,它的端子温度不大于 230℃. The contact temperature of thermostat is not higher than 230℃ in the circuit of 10.6A, at the temperature of less than 5℃+/-1℃ of working temperature. 8.动作方式(Action Forms) 室温下触点接通(nc),温度上升触点断开,温度降低触恢复接通。 Normal close:Cut out at temperature rise,cut in at temperature decreasing. 室温下触点接通(nc),温度下降触点断开,温度上升触恢复接通。 Normal close:Cut out at temperature decreasing.,cut in at temperature rise. 室温下触点断开(no),温度上升触点接通,温度降低触恢复断开。 Nornal opon:Cut in at temperature rise, cut out at temperature decreasing. 室温下触点断开(no),温度下降触点接通,温度上升触恢复断开。 Nornal opon:Cut in at temperature decreasing, cut out at temperature rise. 室温下触点接通(nc),温度上升触点断开,温度降低手动复位接通。 Normal close:Cut out at temperature rise,manual reset at temperature decreasing. 9.手动复位产品 温控器手动复位产品所受复位力为:14-20N.
KSD.301-55/103PAK 价格&库存
很抱歉,暂时无法提供与“KSD.301-55/103PAK”相匹配的价格&库存,您可以联系我们找货
KSD.301-55/103PAK
  • 5+2.56956
  • 50+2.10406
  • 150+1.89924
  • 500+1.49891
库存:500
KSD.301-55/103PAK
    • 5+2.83176
    • 50+2.31876
    • 150+2.09304
    • 500+1.65186
    • 2500+1.52874
    • 5000+1.44666
    库存:188
