WT588F02B-8S
WT588F02B-8S
    WT(唯创知音)
    SOP8_150MIL
    有写程序,WT588F211207-33-V1.34 效验码:E150F326 一线串口 PWM,16位DSP语音芯片,32Mhz
WT588F02B-8S 数据手册
广州唯创电子有限公司 MP3 录音模块 WT588F02B-8S 语音芯片说明书 V1.05 免责申明: 深圳唯创知音电子有限公司申明;说明书以官网资料为准,如若资料内容有更新,不会一一进行通知。如若使用 IC 时 导致侵犯到第三方专利或其他权利,不承担任何责任。如若使用我司 IC,在航空卫星军事设备,人身安全等领域,造成了重大 财产损失或生命伤害,甚至生命死亡,我司不承担任何责任。 深圳唯创知音电子有限公司 WT588F02B-8S使用说明书 目录 说明书以官网和业务员提供为准...................................................................................................................................... 1 版本记录:.......................................................................................................................................................................... 1 1.概述:.................................................................................................................................................................................. 3 2.功能简述:.......................................................................................................................................................................... 3 3.管脚描述:....................................................................................................................................................................... 4 4.极限参数:....................................................................................................................................................................... 4 5. 电气特性:..................................................................................................................................................................... 5 6.一线串口通讯:............................................................................................................................................................... 5 7.两线串口通讯:............................................................................................................................................................... 8 8.程序范例......................................................................................................................................................................... 11 10. 客户在线下载器...................................................................................................................................................... 14 13.封装管脚图................................................................................................................................................................ 17 说明书以官网和业务员提供为准 版本记录: 版本号 修改说明 修改日期 V1.00 原始版本 2020-8-24 V1.01 指令部分说明完善 2020-9-11 V1.02 修改部分说明完善 2020-9-17 V1.03 修改 DAC 部分原理图 2020-10-21 V1.04 将原理图做成独立的文档 2020-11-06 V1.05 修改芯片待机功耗部分说明 2020-11-12 -第 1 页- 全国统一服务热线:4008-122-919 深圳唯创知音电子有限公司 WT588F02B-8S使用说明书 产品简介 语音更新 控制方式 1. 在线更新: 将 bin 文件存入在线下载器,通过 在线下载器连接设备即可更换语音,操作方便快捷, 可用于 PCB 板的语音更换 1. 一线串口控制/两线串口控制 2. 按键功能控制(可据实际情况定制功能) (串口控制和按键控制的主控程序不同,下单时请 联系业务员) 存储方式 操作指令 1. 芯片内部有 220K byte 的存储空间(不包括主 1. 2. 3. 4. 控程序) 2. 芯片主控程序与内部存储空间均可反复擦写 音量调节指令 循环播放指令 播放固定语音指令 播放暂停指令 播放方式 技术规格 1. PWM 输出:16 位 PWM 纯音频输出,可直 1. 供电电压 DC2.0~5.5V 接驱动 8Ω/0.5W 喇叭和蜂鸣器, 2. DAC 输出:14 位 DAC 音频输出,可外接功 2. 工作温度 3. 湿度 -20~75 度 5%~95% 放 3. 支持最大 4 通道 16K 采样率混音 4. 支持最高 16 通道 midi 播放(8K 采样 率); 5. 支持无缝衔接功能(音源需做处理,请与业 务员联系) 应用场景 1. 需频繁更换语音的设备 2. 需更换语音内容的户外设备 (PWM 和 DAC 输出可由 bin 文件设置) 音频采样率 1.语音采样率:支持 6~32Khz; -第 2 页- 全国统一服务热线:4008-122-919 深圳唯创知音电子有限公司 WT588F02B-8S使用说明书 1.概述: WT588F02B-8S 是深圳唯创知音电子有限公司最新研发的一款 16 位 DSP 语音芯片、内部 振荡 32Mhz , 16 位的 PWM 解码。 强大功能让 WT588F02B-8S 成为语音芯片行业中的佼佼者。目前 WT588F02B-8S,较高音质最大可以支持存放 170 秒语音内容(若客户对音质没有要求,最大可以存放 320 秒的语音内容)。WT588F02B-8S 区别于传统 OTP 芯片,最大的突破是客户可以自己通过配套下载器 实现在线更换芯片内部语音内容;并且芯片内置硬件 SPI、UART、IIC、比较器等各类资源,可以 为客户定制各种不同的个性化功能产品。 2.功能简述: 1. 16 位 DSP 语音芯片、32Mhz 内部振荡; 2. 工作电压 2.0~5.5V; 3. 16bit 的 PWM/DAC 输出、可直接驱动 8R 0.5W 喇叭; 4. 支持 6K~32Khz 的 WAV 文件; 5. 客户可以通过配套下载器在线更换芯片内部语音内容; 6. 支持一线串口、两线串口(spi 通讯陆续会出来); 7. 支持最大 4 通道 16K 采样率混音; 8. 支持最高 16 通道 midi 播放(8K 采样率); 9. 支持 224 段地址,有更多需求可以扩展; 10. 具有硬件 SPI 接口、UART 接口、IIC、内置比较器等接口。可以为客户定制各类功能。 11. 芯片内部有 220K byte 的存储空间(不包括主控程序)。 12. 芯片主控程序和内置存储数据均可擦除再烧写。 13. 芯片上电初始化时间大概为 200ms 14. 芯片播放结束后,且 IO 口(DATA 和 CLK)保持电平稳定(高低电平皆可)1S 后,芯片进入休眠 选型注意: 1. 芯片的控制方式与输出方式可由 bin 文件设置,订做芯片时需要和业务员说明应用要求。 2. 如果需要更低待机功耗芯片,请联系我司业务员。 -第 3 页- 全国统一服务热线:4008-122-919 深圳唯创知音电子有限公司 WT588F02B-8S使用说明书 3.管脚描述: 3.1 管脚分布图 Pad Name Pad ATTR. Description 描述 No. PC2/BUSY/CS 1 I/O 忙信号输出/下载器烧写口 PC1/DATA1/CLK2/SO 2 I/O 一线串口数据信号输入端/两线串口时钟信号输入端/下载器烧写口 PI0/DATA2/SI 3 I/O 两线串口数据信号输入端/下载器烧写口 PI1/SCK 4 I/O 下载器烧写口 PWMN 5 out PWM 输出脚 VDD 6 Power PWMP 7 I/O GND 8 Power 电源正极 PWM 输出脚/DAC 电源负极 4.极限参数: 标识 范围值 VDD~GND 电源电压 -0.5~+5.5 V Vin 输入电压 GND-0.3< Vin 1; -第 11 页- 全国统一服务热线:4008-122-919 深圳唯创知音电子有限公司 WT588F02B-8S使用说明书 B_DATA = S_DATA&0X01; } P_DATA = 1; } 8.2 一线串口控制程序(F3+01+F3+02+F3+03) /*-------------------------------------;模块名称:List_1A_Play_WT588F() ;功 能:实现一线串口连码发送函数 ;入 参: DDATA 为发送数据 ;出 参: ;-------------------------------------*/ Void List_1A_Play_WT588F( void ) { Line_1A_WT588F( F3 ); Delay_1ms(2); //延时 2ms Line_1A_WT588F( 01 ); Delay_1ms(2); Line_1A_WT588F( F3); Delay_1ms(2); Line_1A_WT588F( 02 ); Delay_1ms(2); Line_1A_WT588F( F3 ); Delay_1ms(2); Line_1A_WT588F( 03 ); Delay_1ms(2); } 8.3 二线串口控制程序(单字节指令) #define #define #define UC8 unsigned char CLK_2A P01 P_DATA_2A P00 /*-------------------------------------;模块名称:Line_2A_WT588F(UC8 ;功 能:实现二线串口通信函数 ;入 参:DDATA 为发送数据 ;出 参: ; CLK_2A //时钟线 ; P_DATA_2A //数据线 DDATA) -第 12 页- 全国统一服务热线:4008-122-919 深圳唯创知音电子有限公司 ;-------------------------------------*/ Void Line_2A_WT588F(UC8 DDATA) { UC8 S_DATA,j; bit B_DATA; CLK_2A = 1; //时钟线 P_DATA_2A = 1; WT588F02B-8S使用说明书 //数据线 S_DATA = DDATA; CLK_2A = 0; Delay_1ms(5); //延时 5ms B_DATA = S_DATA&0X01; for(j=0;j>1; B_DATA = S_DATA&0X01; } P_DATA_2A = 1; CLK_2A = 1; } 8.4 二线串口控制程序(F3+01+F3+02+F3+03) /*-------------------------------------;模块名称:List_2A_Play_WT588F( ) ;功 能:实现二线串口连码发送函数 ;入 参: DDATA 为发送数据 ;出 参: ;-------------------------------------*/ Void List_2A_Play_WT588F( void ) { Line_2A_WT588F( F3 ); Delay_1ms(2); //延时 2ms Line_2A_WT588F( 01 ); Delay_1ms(2); -第 13 页- 全国统一服务热线:4008-122-919 深圳唯创知音电子有限公司 Line_2A_WT588F( Delay_1ms(2); Line_2A_WT588F( Delay_1ms(2); Line_2A_WT588F( Delay_1ms(2); Line_2A_WT588F( Delay_1ms(2); WT588F02B-8S使用说明书 F3 ); 02 ); F3 ); 03 ); } 10.客户在线下载器 将 bin 文件存入在线下载器,通过在线下载器连接设备即可更换语音,可用于生产或客户端设备语音的更换,使用方便、 快捷、操作简单,适用于需频繁更换语音的设备。(在线下载器已有视频解说,可联系业务员提供。) 10.1 下载原理图 -第 14 页- 全国统一服务热线:4008-122-919 深圳唯创知音电子有限公司 WT588F02B-8S使用说明书 10.2 下载器使用说明 (1)制作 bin 文件:登陆网页上位机网址后,加载要播放的语音文件或使用文字转换音频功能加载语音后 制作 bin 文件。WT588 网页制作客户登录网址:http://WT588f.waytronic.com:8083/user/register。bin 文件制作步骤可参考《WT588F 网页上位机操作说明 2020-8-31》或视频解说,可联系业务员提供。 (2)存放 bin 文件:通过 USB 连接电脑,会出现一个盘符(第一次使用需格式化),将做好的 bin 文件 存入盘符中,bin 文件名称格式需为 WT588XXX(以 WT588 开头,后面可自行定义)。Bin 文件存放后,将 下载器与电脑断开连接。 (3)连接芯片:让单片机释放语音芯片,可将单片机连接语音芯片的 IO 口设置为输入或者浮空;将下载 器的烧写口(即框 4 的 4 个管脚)连接到语音芯片对应的 IO 口(DO-PC1、DI-PI0、CLK-PI1、CS-PC2、 VCC-VCC、GND-GND),客户画板时可在板子上留好下载口,方便下载更换语音。 (4)给下载器供电:框 5 为电源脚,客户板子有供电时可通过 VCC 和 GND 脚给下载器供电;客户板子 没供电的情况下,可以通过 USB(可用适配器或电脑 USB 供电(一般不建议用电脑 USB 供电))给下载 器和芯片供电;如板子有按上面原理图留下载口,可以直接将下载器插到下载口进行烧写。 (5)自动下载:下载器供电 2s 后,下载器会自动将 bin 文件下载到语音芯片里面(故需先连接下载口后 -第 15 页- 全国统一服务热线:4008-122-919 深圳唯创知音电子有限公司 WT588F02B-8S使用说明书 再给下载器供电)。 (6)下载判断:1 电源指示灯、2 拷贝指示灯、3 状态指示灯。 电源指示灯常亮表示该产品已经处于工作状态。 拷贝指示灯平时熄灭,拷贝过程中进行闪烁,拷贝结束后熄灭。 状态指示灯平时熄灭,拷贝成功常亮,拷贝失败熄灭。 (在线下载器已有视频解说,可联系业务员提供。) -第 16 页- 全国统一服务热线:4008-122-919 深圳唯创知音电子有限公司 WT588F02B-8S使用说明书 13.封装管脚图 -第 17 页- 全国统一服务热线:4008-122-919 深圳唯创知音电子有限公司 WT588F02B-8S使用说明书 深圳唯创知音电子有限公司(原名:广州唯创电子有限公司)――于 1999 年创立于广州市天河区, 是一家专注于语音技术研究、语音产品方案设计及控制等软、硬件设计的高新技术公司。业务范围涉及 电话录音汽车电子、多媒体、家居防盗、通信、家电、医疗器械、工业自动化控制、玩具及互动消费类 产品等领域。团队有着卓越的 IC 软、硬件开发能力和设计经验,秉持着「积极创新、勇于开拓、满足 顾客、团队合作」的理念,为力争打造“语音业界”的领导品牌。 我公司是一家杰出的语音芯片厂家,从事语音芯片研究及外围电路开发;同时为有特别需求的客户 制订语音产品开发方案,并且落实执行该方案,完成产品的研发、测试,声音处理,直至产品的实际应 用指导等一系列服务。经过多年的发展,公司形成了一个完善的新品流程体系,能快速研发出新品以及 完善产品。语音芯片系列包含:WT2000、WT2003、WT5001、WT588D、WTH、WTV、WTN 等,每一 款语音芯片我们都追求精益求精、精雕细琢不断开发和完善,以求更佳的品质、为客户实现更多的价值。 产品、模块、编辑软件等的人性化设计,使得客户的使用更方便。于 2006 年成立的北京唯创虹泰分公 司主要以销售完整的方案及成熟产品为宗旨,以便于为国内北方客户提供更好的服务。 不仅如此,还推出的多种语音模块,如 WT2000 录音模块,通过外围电路的扩展,更贴近广大用户 的需求。 我们也是 MP3 芯片研发生产厂家。随着公司的外围技术扩展,在 2004 年开始生产 MP3 芯片,以及 提供 MP3 方案。在同行里面有相当高的知名度,到现在为止更新换代一起出了 8 种 MP3 解决方案,并 且得到市场的广泛认可。其中的 WT2000、WT2003 等芯片以音质表现极其优秀不断被客户所接受并使 用。 在语音提示器方面,我们也从事于语音提示器生产厂家:经过多年的技术储备,开始向语音提示器 领域拓展,并且得到了可喜的成果,成为语音提示器生产厂家里的一员。根据探头的类别:有超声波语 音提示器,红外人体感应语音提示器,光感应语音提示器。同时也针对不同的领域开发了:自助银行语 音提示器,欢迎光临迎宾器,语音广告机,语音门铃等等产品。可以肯定将来会有更多的新产品上市, 来满足广大的用户的需求。让我们的生活更加智能化,人性化。 总公司名称:深圳唯创知音电子有限公司 电话:0755-29605099 0755-29606621 0755-29606993 传真:0755-29606626 全国统一服务热线:4008-122-919 E-mail:WT1999@waytronic.com 网址:http://www.waytronic.com 地址:广东省深圳市宝安区福永镇福安机器人产业园 11 栋 4 楼 分公司名称:广州唯创电子有限公司 电话: 020-85638557 E-mail: 864873804@qq.com 网址: www.w1999c.com 地址:广州市花都区天贵路 62 号 TGO 天贵科创 D 座 409 室 分公司名称:北京唯创虹泰科技有限公司 电话:010-89756745 传真:010-89750195 E-mail:BHL8664@163.com 网址:www.wcht1998.com.cn 地址:北京昌平区立汤路 186 号龙德紫金 3 号楼 902 室 -第 18 页- 全国统一服务热线:4008-122-919
WT588F02B-8S 价格&库存
很抱歉,暂时无法提供与“WT588F02B-8S”相匹配的价格&库存,您可以联系我们找货
