S3AB
S3AB
    JINGDAO(晶导微电子)
    SMB(DO-214AA)
    整流二极管 Vr:50V Io:3A Vf:1.1V@3A Ir:5μA@50V
S3AB 数据手册
山东晶导微电子有限公司 S3AB THRU S3MB Jingdao Microelectronics Surface Mount General Purpose Silicon Rectifiers Reverse Voltage - 50 to 1000 V PINNING Forward Current - 3 A PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 2 1 Top View MECHANICAL DATA • Case: SMB • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.055g / 0.002oz Marking Code: S3A~S3M Simplified outline SMB and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols Parameter S3AB S3BB S3DB S3GB S3JB S3KB S3MB Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current I F(AV) 3 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 90 A Maximum Instantaneous Forward Voltage at 3 A VF 1.1 V IR 5 100 μA Cj 35 pF RθJA RθJC 48 16 °C/W T j , T stg -55 ~ +150 °C Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance Typical Thermal Resistance (1) (2) Operating and Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2017.01 SMB-A-S3AB~S3MB-3A1KV Page 1 of 3 山东晶导微电子有限公司 S3AB THRU S3MB Jingdao Microelectronics Fig.2 Typical Instaneous Reverse Characteristics 5.0 4.0 3.0 2.0 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current ( μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 100 T J =150°C T J =125°C 10 T J =100°C 1.0 T J =75°C 0.1 T J =25°C 0.01 0 600 800 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 10 Junction Capacitance ( pF) Instaneous Forward Current (A) 400 200 Instaneous Reverse Voltage (V) Case Temperature (°C) 1.0 100 T J =25°C 10 T J =25°C 0.1 0.4 1 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2017.01 www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 S3AB THRU S3MB Jingdao Microelectronics PACKAGE OUTLINE SMB Plastic surface mounted package; 2 leads L A A1 C A b D E E1 VM A SMB mechanical data UNIT mm mil A1 L C b 5.59 0.20 1.5 0.305 2.2 3.3 5.08 0.05 0.8 0.152 1.9 155 220 7.9 59 12 87 200 2.0 32 6 75 A E D max 2.44 4.70 3.94 min 2.13 4.06 max 96 185 min 84 130 160 E1 The recommended mounting pad size Marking Type number S3AB 2.2 (86) 2.4 (94) 2.8 (110) 2.4 (94) mm Unit : (mil) 2017.01 JD702229B0 Marking code S3A S3BB S3B S3DB S3D S3GB S3G S3JB S3J S3KB S3K S3MB S3M Page 3 of 3
S3AB
物料型号:S3AB至S3MB
器件简介:这些是用于表面贴装的通用硅整流器,具有低剖面封装、玻璃钝化芯片连接、易于拾取和放置,符合欧盟RoHS 2011/65/EU指令的无铅特性。
引脚分配:共2个引脚,1号引脚为阴极,2号引脚为阳极。
参数特性:包括最大重复峰值反向电压(VRRM)、最大RMS电压(VRMS)、最大直流阻断电压(Voc)、最大平均正向整流电流(IF(AV))、峰值正向浪涌电流(IFSM)、最大瞬态正向电压(VF)、最大直流反向电流(IR)、典型结电容(C1)和典型热阻(ROJA ReJc)。
功能详解:提供了正向电流降额曲线、典型瞬态反向特性、典型正向特性、典型结电容和最大非重复峰值正向浪涌电流等图表。
应用信息:适用于单相半波60Hz、电阻性或感性负载,对于电容性负载,电流需降额20%。
封装信息:塑料表面贴装封装,2个引脚,提供了SMB机械数据和推荐安装垫尺寸。
很抱歉,暂时无法提供与“S3AB”相匹配的价格&库存,您可以联系我们找货
S3AB
  • 20+0.19265
  • 300+0.15206
  • 1200+0.15054
库存:715
S3AB
    • 1+0.14650
    库存:5
    S3AB
    • 20+0.20520
    • 200+0.16190
    • 600+0.13770
    库存:1370
    S3AB
    库存:1370
