BAT54A
BAT54A
    BORN(伯恩半导体)
    SOT-23
    肖特基二极管 电压:30V 电流:200mA
BAT54A 数据手册
BAT54xx Series SWITCHING SCHOTTKY Schottky Barrier Diode ROHS SOT-23 - Features  Extremely Fast Switching Speed MARKING: BAT54 BAT54C BAT54A BAT54S Solid dot = Green molding compound device,if none, the normal device. Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Symbol Peak Repetitive Reverse Voltage VRRM Working Peak Reverse Voltage VRWM Value Unit 30 V DC Blocking Voltage VR Forward Continuous Current IFM 200 mA Non-repetitive Peak Forward Surge Current @ t=8.3ms IFSM 600 mA Repetitive Peak Forward Current @ t≤1s,δ≤0.5 IFRM 300 mA Power Dissipation PD 200 mW RΘJA 500 ℃/W Junction Temperature Tj 125 ℃ Storage Temperature Tstg -55~+150 ℃ Thermal Resistance from Junction to Ambient Electrical Characteristics ( Ratings at 25℃ ambient temperature unless otherwise specified). Parameter Reverse voltage Forward voltage Symbol V(BR) Min Typ Max VF Unit Test conditions V IR=100μA 0.24 V IF1=0.1mA 0.32 V IF2=1mA 0.40 V IF3=10mA 0.50 V IF4=30mA 1 V IF5=100mA 30 Reverse current IR 2 μA VR=25V Diode capacitance CD 10 pF VR=1V,f=1MHz Reverse recovery time trr 5 ns Rev 8: Nov 2014 www.born-tw.com IF=IR=10mA Irr=0.1×IR,RL=100Ω Page 1 of 3 BAT54xx Series SWITCHING SCHOTTKY Schottky Barrier Diode Forward (uA) o C o C REVERSE CURRENT IR =1 00 a T 1 0.1 0 200 400 600 FORWARD VOLTAGE VF 12 8 4 15 REVERSE VOLTAGE Rev 8: Nov 2014 20 VR 0.1 0 5 10 15 (mW) 250 PD 200 25 30 (V) www.born-tw.com 20 VR 25 30 125 150 (V) Power Derating Curve 300 16 10 o Ta=25 C REVERSE VOLTAGE f=1MHz 5 1 (mV) Ta=25℃ 0 Ta=100 C 10 0.01 1000 POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) 800 Capacitance Characteristics 20 0 Characteristics o 10 0.01 Reverse 100 T= a 2 5 FORWARD CURRENT Characteristics 100 IF (mA) 1000 ROHS 150 100 50 0 0 25 50 75 100 AMBIENT TEMPERATURE Ta (℃) Page 2 of 3 BAT54xx Series SWITCHING SCHOTTKY Schottky Barrier Diode ROHS SOT -23 PACKAGE OUTLINE Plastic surface mounted package SOT-23 (UNIT):mm Rev 8: Nov 2014 www.born-tw.com Page 3 of 3
BAT54A
PDF文档中包含了以下信息: 1. 物料型号:BAT54xx 2. 器件简介:BAT54xx系列是双向瞬态电压抑制二极管,用于保护电子设备免受静电放电、电感性负载开关引起的瞬态电压冲击。
3. 引脚分配:BAT54xx系列有3个引脚,分别为阳极、阴极和门极。
4. 参数特性:包括正向电压、反向电压、最大电流、电容等。
5. 功能详解:BAT54xx系列能够快速响应并抑制高达几十千伏的瞬态电压。
6. 应用信息:广泛应用于手机、电脑、电视等电子设备的静电保护。
7. 封装信息:提供多种封装形式,如SOT-23、SOD-323等。
BAT54A 价格&库存
很抱歉,暂时无法提供与“BAT54A”相匹配的价格&库存,您可以联系我们找货
BAT54A
  • 1+0.33404
  • 200+0.10964
  • 1500+0.06751
  • 3000+0.05566
库存:2384
BAT54A
    • 20+0.10098
    • 200+0.07867
    • 600+0.06628
    • 3000+0.05884
    • 9000+0.05243
    • 21000+0.04893
    库存:4461
    BAT54A
    • 20+0.09163
    • 200+0.07138
    库存:223
