B5818W
B5818W
    JINGDAO(晶导微电子)
    SOD-123
    SOD123 3A
B5818W 数据手册
山东晶导微电子有限公司 B5817W THRU B5819W Jingdao Microelectronics SCHOTTKY BARRIER RECTIFIERS FEATURES PINNING • Metal silicon junction, majority carrier conduction PIN DESCRIPTION • Guarding for overvoltage protection 1 Cathode • Low power loss, high efficiency 2 Anode • High current capability 2 • low forward voltage drop • High surge capability 1 Top View Marking Code: B5817W---SJ B5818W---SK B5819W---SL • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications Simplified outline SOD-123 and symbol MECHANICAL DATA • Case: SOD-123 • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight:16mg 0.00056oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Symbols B5817W B5818W B5819W Units Maximum Repetitive Peak Reverse Voltage V RRM 20 30 40 V Maximum RMS voltage V RMS 14 21 28 V Maximum DC Blocking Voltage V DC 20 30 40 V Maximum Average Forward Rectified Current I F(AV) 1 A Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed On Rated Load (JEDEC method) I FSM 9 A at 1 A at 3 A VF Parameter Maximum Instantaneous Forward Voltage 0.45 0.75 0.55 0.875 0.6 0.9 V Maximum Instantaneous Reverse Current at TA = 25°C Rated DC Reverse Voltage TA = 100°C IR 1 10 mA Typical Junction Capacitance Cj 110 pF T j , T stg -55 ~ +125 °C Storage and Operating Junction Temperature Range 2016.08 SOD123-S-B5817W~B5819W-1A40V Page 1 of 3 山东晶导微电子有限公司 B5817W THRU B5819W Jingdao Microelectronics Fig.2 Typical Reverse Characteristics Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 10 3 T J =125°C 10 2 T J =75°C 10 1 T J =25°C 10 0 0 Case Temperature (°C) Fig.3 Typical Forward Characteristic 60 80 100 Fig.4 Typical Junction Capacitance 500 5° C =2 TJ 12 5°C 0.5 Junction Capacitance ( pF) 1.0 TJ = Instaneous Forward Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) 0.2 0.1 0 0.1 0.2 0.3 0.4 0.5 0.6 200 100 50 20 10 0.7 0.1 1 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 30 8.3 ms Single Half Sine Wave (JEDEC Method) 25 20 15 10 05 00 1 10 100 Number of Cycles at 50Hz 2016.08 www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 B5817W THRU B5819W Jingdao Microelectronics PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123 A D b E A1 C ∠ALL ROUND L1 E1 SOD-123 mechanical data A C D E E1 L1 b A1 max 1.3 0.22 1.8 2.8 3.9 0.45 0.7 0.2 min 0.9 0.09 1.5 2.5 3.6 0.25 0.5 max 51 8.7 71 110 154 18 28 min 35 3.5 59 98 142 10 20 UNIT ∠ mm 9° 8 mil The recommended mounting pad size Marking Type number 2.0 (79) 1.2 (47) Marking code B5817W SJ B5818W SK B5819W SL 1.2 (47) 1.2 (47) Unit: mm (mil) 2016.08 609062A8 Page 3 of 3
B5818W 价格&库存
很抱歉,暂时无法提供与“B5818W”相匹配的价格&库存,您可以联系我们找货
B5818W
    • 50+0.12306
    • 600+0.09950
    • 1200+0.09801
    • 3000+0.08643
    库存:5800
