BST23Cxx2V
Transient Voltage Suppressors
ROHS
Features
250 watts peak pulse power (tp = 8/20μs)
ESD Protection > 40 kilovolts
Protects one bidirectional line or two unidirectional lines
Working Voltages: 5V, 12V, 15V, 24V and36V
Low clamping voltages
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Mechanical Characteristics
Applications
JEDEC SOT23 package
RS-232, RS-422 & RS-485
Molding compound flammability rating: UL
Cellular Handsets and Accessories
94V-0
Control & Monitoring Systems
Marking: Marking Code
Portable Electronics
Packaging: Tape and Reel per EIA 481
Set-Top Box
RoHS/WEEE Compliant
Servers, Notebook, and Desktop PC
Wireless Bus Protection
Circuit Diagram
Schematic & PIN Configuration
1
1
3
3
2
2
SOT-23 (Top View)
1/5
BST23Cxx2V
ROHS
Absolute Maximum Rating
Rating
Symbol
Value
Units
PPP
250
Watts
Lead Soldering Temperature
TL
260(10sec)
°C
Operating Temperature
TJ
-55 to + 125
°C
TSTG
-55 to +150
°C
Peak Pulse Power(tp=8/20μs)
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
Parameter
I
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRW M
IR
VBR
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
VC VBR V RWM
IT
IR
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
IR
IT
VRWM VBR VC
V
IPP
Electrical Characteristics(T=25℃)
BST23C052V
Parameter
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
5
V
VBR
IT=1mA
IR
VRWM=5V,T=25°C
1
μA
Peak Pulse Current
IPP
tp =8/20μs
17
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
9.8
V
Maximum Clamping Voltage
VC
IPP=18A, tp=8/20μs
16.7
V
Junction Capacitance
Cj
Cj
Pin 2 to 3
VR = 0V, f = 1MHz
Pin 1 to 3 and Pin 2 to 3
VR = 0V, f = 1MHz
6
V
100
pF
100
pF
2/5
BST23Cxx2V
ROHS
BST23C122V
Parameter
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
12
V
VBR
IT=1mA
13.3
IR
VRWM=12V,T=25°C
1
μA
Peak Pulse Current
IPP
tp =8/20μs
12
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
19
V
VC
IPP=12A, tp=8/20μs
25
V
Cj
Cj
Pin 1 to 2
VR = 0V, f = 1MHz
VR = 0V, f = 1MHz
V
30
pF
50
pF
BST23C152V
Parameter
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
15
V
VBR
IT=1mA
16.7
IR
VRWM=15V,T=25°C
1
μA
Peak Pulse Current
IPP
tp =8/20μs
10
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
24
V
VC
IPP=10A, tp=8/20μs
30
V
Cj
Cj
Pin 1 to 2
VR = 0V, f = 1MHz
VR = 0V, f = 1MHz
V
25
pF
40
pF
BST23C242V
Parameter
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
24
V
VBR
IT=1mA
IR
VRWM=24V,T=25°C
1
μA
Peak Pulse Current
IPP
tp =8/20μs
5
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
43
V
VC
IPP=5A, tp=8/20μs
60
V
Cj
Cj
Pin 1 to 2
VR = 0V, f = 1MHz
VR = 0V, f = 1MHz
26.7
V
pF
30
pF
3/5
BST23Cxx2V
ROHS
BST23C362V
Parameter
Symbol
Conditions
Minimum
Typical
Maximum
Units
36
V
VRWM
VBR
IT=1mA
40
V
IR
VRWM=36V,T=25°C
1
μA
Peak Pulse Current
IPP
tp =8/20μs
4
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
60
V
VC
IPP=4A, tp=8/20μs
75
V
Cj
Pin 1 to 2
VR = 0V, f = 1MHz
pF
Cj
VR = 0V, f = 1MHz
26
pF
Typical Characteristics
Peak Pulse Power vs. Pulse Time
Power Derating Curve
110
100
1,000
% of Rated Power or IPP
Ppp–Peak Pulse Power–Watts
10,000
250W 8/20µs
Waveform
100
90
80
70
60
50
40
30
10
0.1
1
10
100
1000
10000
50
75
100
125
td–Pulse Duration–µs
Pulse Waveform
ESD Pulse Waveform (Per IEC 61000-4-2)
110
Waveform
Paramters
tr=8µs
td=20µs
100
90
Percent of
Ipp
80
70
e-t
60
50
40
30
td=Ipp/2
R1
10
15
Time (µs)
150
Ambient Temprature -TA(°C)
25
30
35
Ref1 500mV 10.0ns
4/5
BST23Cxx2V
ROHS
Outline Drawing – SOT-23
PACKAGE OUTLINE
D
SOT-23
3
DIMENSIONS
E1 E
0.25
θ
1
b
e
A
INCHES
MIN
MAX
MIN
MAX
0.900
1.150
0.035
0.045
A1
0.000
0.100
A2
0.900
1.050
0.035
0.041
D
2.800
3.000
0.110
0.118
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
A1
MILLIMETER
A
L
2
A2
SYMBOL
0.000
0.950 BSC
0.004
0.037 BSC
L
0.300
0.500
0.012
0.020
θ
8○
8○
Notes
b
DIMENSIONS
M
Z
C
e
e1
Marking Codes
Part Number
BST23C052V
DIM
INCHES
MILLIMETERS
M
0.088
2.20
C
0.0058
0.15
Z
0.093
2.35
e
0.037 BSC
0.95 BSC
e1
0.074 BSC
1.9 BSC
b
0.0389
0.35
1. Dimensioning and tolerances per ANSI Y14.5M,
1985.
2. Controlling Dimension: Inches
3. Pin 3 is the cathode (Unidirectional Only).
4. Dimensions are exclusive of mold flash and metal
burrs.
Marking Code
BST23C122V
BST23C152V
5B2
AB2
BB2
BST23C242V
CB2
Package Information
Qty:3k/Reel
5/5
很抱歉,暂时无法提供与“BST23C122V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.62608
- 50+0.51192
- 150+0.45479
- 500+0.41192
- 3000+0.32174
- 6000+0.30456
- 国内价格
- 10+0.55071
- 100+0.45030
- 600+0.36233
- 1200+0.35690
- 3000+0.28300
- 国内价格
- 1+0.52800
- 200+0.34100
- 1500+0.29700
- 3000+0.26180
