山东晶导微电子有限公司
1N4001W THRU 1N4007W
Jingdao Microelectronics
Surface Mount General Purpose Silicon Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 1 A
PIN
FEATURES
▪For surface mounted applications
▪Low profile package
▪Glass Passivated Chip Junction
▪Ideal for automated placement
▪Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: A1-A7
Simplified outline SOD-123FL and symbol
MECHANICAL DATA
▪Case: SOD-123FL
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪Approx. Weight: 15mg / 0.00053oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols 1N4001W 1N4002W 1N4003W 1N4004W 1N4005W 1N4006W 1N4007W Units
Parameter
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
30
A
Maximum Instantaneous Forward Voltage at 1 A
VF
1.1
V
IR
5
50
μA
Cj
8(TYP.)
pF
RθJA
90
°C/W
T j , T stg
-55 ~ +150
°C
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
Typical Thermal Resistance
(1)
(2)
Operating and Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.01
SOD123FL-A-1N4001W~1N4007W-1A1KV
Page 1 of 3
山东晶导微电子有限公司
Fig.2 Typical Instaneous Reverse
Characteristics
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current ( μ A)
Fig.1 Forward Current Derating Curve
100
T J=150°C
T J=125°C
10
1.0
T J=75°C
0.1
T J =25°C
1N4007W
0.01
Junction Capacitance ( pF)
TJ =
2 5°
C
TJ =
10
15
0°C
0°C
0.5
TJ =
Instaneous Forward Current (A)
1.0
0.9
800
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
0.8
600
Instaneous Reverse Voltage (V)
Case Temperature (°C)
0.2
0.1
0.5
400
200
100
T J=25°C
10
1
0.6
0.7
1.0
1.1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
35
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123FL
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
g
pad
e
E
A
pad
HE
7°
The recommended mounting pad size
Marking
Type number
2.0
(79)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
2016.01
JD512184B2
Marking code
1N4001W
A1
1N4002W
A2
1N4003W
A3
1N4004W
A4
1N4005W
A5
1N4006W
A6
1N4007W
A7
Page 3 of 3
很抱歉,暂时无法提供与“1N4005W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.11770
- 200+0.03927
- 1500+0.02453
- 3000+0.01947
- 国内价格
- 20+0.05240
- 100+0.03920
- 800+0.03040
- 3000+0.02200
- 6000+0.02090
- 30000+0.01940
- 国内价格
- 100+0.05584
- 1000+0.04472
- 3000+0.03564
- 国内价格
- 50+0.05118
- 600+0.04099
- 1200+0.04038
- 3000+0.03267
