BSD3C(A)XX1L
Transient Voltage Suppressors
ROHS
Features
350 Watts Peak Pulse Power per Line (tp = 8/20μs)
Unidirectional & Bidirectional Configuration
Protects One Power or I/O Port
ESD Protection > 40 kilovolts
Low Clamping Voltages
Available in Multiple Voltage Types Ranging from 3V to 24V
Ultra Low Capacitance: 1.0 pF Typical
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±25kV (air), ±15kV(contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Applications
Mechanical Characteristics
Molded JEDEC SOD-323 package
Ethernet - 10/100/1000 Base T
Weight 10 milligrams (Approximate)
Cellular Phones
Flammability rating UL 94V-0
8mm Tape and Reel Per EIA Standard 481
Device Marking: Marking Code
RoHS/WEEE Compliant
Handheld - Wireless Systems
Personal Digital Assistant (PDA)
USB Interface
PIN Configuration
1
1
2
2
UNIDIRECTIONAL
BIDIRECTIONAL
1/4
BSD3C(A)XX1L
ROHS
Absolute Maximum Rating
Rating
Peak Pulse Power ( tp=8/20μs ) - See Figure 1
Operating Temperature
Storage Temperature
Symbol
Value
Units
PPP
350
Watts
TJ
-55 to + 150
°C
TSTG
-55 to +150
°C
Electrical Parameters(T=25°C)
Symbol
I
IPP
IF
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
Bidirectional
V
IT
IR
VC VBR VRWM
VRWMVBR VC
IR VF
IT
Breakdown Voltage @ IT
IT
Unidirectional
IPP
Electrical Characteristics
PART
NUMBER
(See Note 1
& Note 2)
DEVICE
MARKING
RATED
STAND-OFF
VOLTAGE
VWM(Volts)
MINIMUM
BREAKDOWN
VOLTAGE
@ 1mA
V BR(Volts)
MAXIMUM
CLAMPING
VOLTAGE
(See Fig. 2)
@ IP = 1A
VC(Volts)
MAXIMUM
CLAMPING
VOLTAGE
(See Fig. 2)
@8/20μs
VC @ IPP
MAXIMUM
LEAKAGE
CURRENT
@VWM
Id(μA)
TYPICAL
CAPACITANCE
@0V, 1 MHz
C(pF)
BSD3A031L
03
3.3
4.0
7.0
19.0V @ 20.0A
1
1
BSD3C031L
3B
3.3
4.0
7.0
19.0V @ 20.0A
0.050
1
BSD3A051L
05
5.0
6.0
9.8
18.3V @ 17.0A
1
1
BSD3C051L
5B
5.0
6.0
9.8
18.3V @ 17.0A
0.045
1
BSD3A081L
08
8.0
8.5
13.4
18.5V @ 17.0A
1
1
BSD3C081L
8B
8.0
8.5
13.4
18.5V @ 17.0A
1
1
BSD3A121L
12
12.0
13.3
19.0
28.6V @ 11.0A
1
1
BSD3C121L
AB
12.0
13.3
19.0
28.6V @ 11.0A
1
1
BSD3A151L
15
15.0
16.7
24.0
31.8V @ 10.0A
1
1
BSD3C151L
BB
15.0
16.7
24.0
31.8V @ 10.0A
1
1
BSD3A241L
24
24.0
26.7
43.0
56.0V @ 6.0A
1
1
BSD3C241L
CB
24.0
26.7
43.0
56.0V @ 6.0A
1
1
2/4
BSD3C(A)XX1L
ROHS
Typical Characteristics
Figure 2: Power Derating Curve
10
1
Percent of Rated Power for Ipp
Ppp - Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
350W 8/20µs
Waveform
0.1
110
100
0.01
0.1
1
10
100
90
80
70
60
50
40
30
25
50
75
100
125
Figure 4: Normalized Junction Capacitance
vs. Reverse Voltage
Figure 3: Clamping Voltage vs. Peak Pulse
Current
1.0
F=1MHz
0.9
15
Cj(VR)/Cj(VR=0)
Clamping Voltage -Vc(V)
150
Ambient Temperature - TA (℃)
td – Pulse Duration - µs
BSD3C051L
10
5
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
10
15
Peak Pulse Current -Ipp(A)
3
4
5
Reverse Voltage -VR(V)
Figure 6: ESD Clamping( 8kV Contact per
IEC 61000-4-2)
Figure 5: Pulse Waveform
Tek Run : 5.00GS/s Sample WE05S
110
Waveform
Paramters
tr=8µs
td=20µs
100
90
80
Percent Ipp
2
70
C1 Max
19.0V
e-t
60
50
40
td=Ipp/2
30
R1
10
10
15
30
Ch1 500mV
M 10.0ns Ch1 1.36V
Time (µs)
3/4
BSD3C(A)XX1L
ROHS
OutlineDrawing–SOD323
PACKAGE OUTLINE
C
A
SOD-323
DIMENSIONS
E
B
1
SYMBOL
2
A
D
F
H
L
L1
MOUNTING PAD
MILLIMETER
INCHES
MIN
MAX
MIN
MAX
1.60
1.80
0.063
0.071
B
0.25
0.35
0.010
0.014
C
2.50
2.70
0.098
0.106
D
0.00
1.00
0.000
0.039
E
1.20
1.40
0.047
0.055
F
0.08
0.15
0.003
0.006
L
0.475 REF
0.019REF
L1
0.25
0.40
0.010
0.016
H
0.00
0.10
0.000
0.004
Notes
1. Controlling Dimensions in Millimeters.
2. Dimensions are exclusive of mold flash and metal burrs.
0.118”(3.00mm)
0.031”(0.80mm)
0.031”(0.80mm)
Marking Codes
BSD3A031L
BSD3C031L
Marking Code
03
BSD3A051L
3B
05
BSD3C051L
5B
BSD3A081L
08
BSD3C081L
BSD3A121L
8B
BSD3C121L
12
AB
BSD3A151L
15
BSD3C151L
BSD3A241L
BSD3C241L
BB
24
CB
LC LC LC LC LC LC LC LC LC LC LC LC
Part Number
Package
Qty:3k/Reel
4/4
很抱歉,暂时无法提供与“BSD3C121L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.45421
- 100+0.36868
- 600+0.32591
- 1200+0.32102
- 3000+0.27017
- 国内价格
- 10+0.49551
- 100+0.40220
- 300+0.35554
- 3000+0.29474
- 6000+0.26676
- 9000+0.25283
- 国内价格
- 1+0.44330
- 200+0.28600
- 1500+0.24860
- 3000+0.22000
