1.0SMBJ15CA
1.0SMBJ15CA
    BORN(伯恩半导体)
    SMB(DO-214AA)
    瞬态电压抑制器SMB VC=24.4V IPP=41A
1.0SMBJ15CA 数据手册
1.0SMBJ Series Transient Voltage Suppressors 1.0SMBJxxA(CA) ROHS DESCRIPTION: TVS diodes can be used in a wide range ofapplications which like consumer electronic products, automotive industries, munitions, telecommunications, aerospace industries, and intelligent control systems. SMB FEATURES:  Glass passivated or planner junction  Excellent clamping capability  Repetition rate (duty cycle): 0.01%  Typical IR less than 1μA above 10V.  Low profile package and low inductance  1000W Peak Pulse power capability at 10×1000μs waveform.  Fast response time: typically less than 1.0ps from 0V to VBR min.  High temperature soldering: 260℃/10s at terminals. Symbol  Plastic package has Underwriters Laboratory Flammability 94V-0.  For surface mounted applications in order to optimize board space ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwisenoted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 50A for Unidirectional 1/5 Symbol Value Tstg -55 to +150 Unit ℃ Tj -55 to +150 ℃ PM(AV) 5.0 W PPP 1000 W VF 5.0 V 1.0SMBJ Series Transient Voltage Suppressors 1.0SMBJxxA(CA) ROHS ELECTRICAL CHARACTERISTICS (TA=25℃) Part Number VR IR@ VR VBR@IT IT VC@IPP I PP① Uni-Polar Bi-Polar V μA 1.0SMBJ5.0A 1.0SMBJ5.0CA 5.0 200 6.40 7.00 10 9.2 108.7 1.0SMBJ6.0A 1.0SMBJ6.0CA 6.0 200 6.67 7.37 10 10.3 97.1 1.0SMBJ6.5A 1.0SMBJ6.5CA 6.5 100 7.22 7.98 10 11.2 89.3 1.0SMBJ7.0A 1.0SMBJ7.0CA 7.0 80 7.78 8.60 10 12.0 83.4 1.0SMBJ7.5A 1.0SMBJ7.5CA 7.5 50 8.33 9.21 1 12.9 77.6 1.0SMBJ8.0A 1.0SMBJ8.0CA 8.0 20 8.89 9.83 1 13.6 73.6 1.0SMBJ8.5A 1.0SMBJ8.5CA 8.5 10 9.44 10.40 1 14.4 69.5 1.0SMBJ9.0A 1.0SMBJ9.0CA 9.0 5 10.00 11.10 1 15.4 65.0 1.0SMBJ10A 1.0SMBJ10CA 10 2 11.10 12.30 1 17.0 58.9 1.0SMBJ11A 1.0SMBJ11CA 11 1 12.20 13.50 1 18.2 55.0 1.0SMBJ12A 1.0SMBJ12CA 12 1 13.30 14.70 1 19.9 50.3 1.0SMBJ13A 1.0SMBJ13CA 13 1 14.40 15.90 1 21.5 46.6 1.0SMBJ14A 1.0SMBJ14CA 14 1 15.60 17.20 1 23.2 43.1 1.0SMBJ15A 1.0SMBJ15CA 15 1 16.70 18.50 1 24.4 41.0 1.0SMBJ16A 1.0SMBJ16CA 16 1 17.80 19.70 1 26.0 38.5 1.0SMBJ17A 1.0SMBJ17CA 17 1 18.90 20.90 1 27.6 36.3 1.0SMBJ18A 1.0SMBJ18CA 18 1 20.00 22.10 1 29.2 34.3 1.0SMBJ20A 1.0SMBJ20CA 20 1 22.20 24.50 1 32.4 30.9 1.0SMBJ22A 1.0SMBJ22CA 22 1 24.40 26.90 1 35.5 28.2 1.0SMBJ24A 1.0SMBJ24CA 24 1 26.70 29.50 1 38.9 25.7 1.0SMBJ26A 1.0SMBJ26CA 26 1 28.90 31.90 1 42.1 23.8 1.0SMBJ28A 1.0SMBJ28CA 28 1 31.10 34.40 1 45.4 22.1 1.0SMBJ30A 1.0SMBJ30CA 30 1 33.30 36.80 1 48.4 20.7 1.0SMBJ33A 1.0SMBJ33CA 33 1 36.70 40.60 1 53.3 18.8 1.0SMBJ36A 1.0SMBJ36CA 36 1 40.00 44.20 1 58.1 17.3 1.0SMBJ40A 1.0SMBJ40CA 40 1 44.40 49.10 1 64.5 15.5 1.0SMBJ43A 1.0SMBJ43CA 43 1 47.80 52.80 1 69.4 14.4 1.0SMBJ45A 1.0SMBJ45CA 45 1 50.00 55.30 1 72.7 13.8 1.0SMBJ48A 1.0SMBJ48CA 48 1 53.30 58.90 1 77.4 13.0 1.0SMBJ51A 1.0SMBJ51CA 51 1 56.70 62.70 1 82.4 12.2 2/5 min(V) max(V) mA max(V) A 1.0SMBJ Series Transient Voltage Suppressors 1.0SMBJxxA(CA) ROHS ELECTRICAL CHARACTERISTICS (TA=25℃, continued) Part Uni-Polar Number Bi-Polar VR IR@ VR V μA min(V) max(V) mA VBR@IT IT VC@IPP max(V) IPP ① A 1.0SMBJ54A 1.0SMBJ54CA 54 1 60.00 66.30 1 87.1 11.5 1.0SMBJ58A 1.0SMBJ58CA 58 1 64.40 71.20 1 93.6 10.7 1.0SMBJ60A 1.0SMBJ60CA 60 1 66.70 73.70 1 96.8 10.4 1.0SMBJ64A 1.0SMBJ64CA 64 1 71.10 78.60 1 103.0 9.7 1.0SMBJ70A 1.0SMBJ70CA 70 1 77.80 86.00 1 113.0 8.9 1.0SMBJ75A 1.0SMBJ75CA 75 1 83.30 92.10 1 121.0 8.3 1.0SMBJ78A 1.0SMBJ78CA 78 1 86.70 95.80 1 126.0 8.0 1.0SMBJ85A 1.0SMBJ85CA 85 1 94.40 104.0 1 137.0 7.3 1.0SMBJ90A 1.0SMBJ90CA 90 1 100.0 111.0 1 146.0 6.9 1.0SMBJ100A 1.0SMBJ100CA 100 1 111.0 123.0 1 162.0 6.2 1.0SMBJ110A 1.0SMBJ110CA 110 1 122.0 135.0 1 177.0 5.7 1.0SMBJ120A 1.0SMBJ120CA 120 1 133.0 147.0 1 193.0 5.2 1.0SMBJ130A 1.0SMBJ130CA 130 1 144.0 159.0 1 209.0 4.8 1.0SMBJ150A 1.0SMBJ150CA 150 1 167.0 185.0 1 243.0 4.2 1.0SMBJ160A 1.0SMBJ160CA 160 1 178.0 197.0 1 259.0 3.9 1.0SMBJ170A 1.0SMBJ170CA 170 1 189.0 209.0 1 275.0 3.7 1.0SMBJ180A 1.0SMBJ180CA 180 1 201.0 222.0 1 292.0 3.5 1.0SMBJ190A 1.0SMBJ190CA 190 1 211.0 234.0 1 307.0 3.3 1.0SMBJ200A 1.0SMBJ200CA 200 1 224.0 247.0 1 324.0 3.1 ①Surge waveform: 10/1000μ VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current 3/5 1.0SMBJ Series Transient Voltage Suppressors 1.0SMBJxxA(CA) ROHS ORDERING INFORMATION 1.0SMBJ xx C A 1000W SMB Series 5% VBR Voltage tolerance VR Voltage C: Bi-directional RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP VC VBR VR IT IR VC VBR VR V VF VR VBR VC IPP IPP FIG.4: Pulse derating curve FIG.3: Pulse waveform PPP derating in percentage(%) 100 IPPM(%IRSM) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 V IR IT 80 Peak value 60 Half value 40 50 20 td t(ms) 0 0 4/5 1.0 2.0 3.0 4.0 0 0 TA(℃) 25 50 75 100 125 150 175 1.0SMBJ Series Transient Voltage Suppressors 1.0SMBJxxA(CA) ROHS SOLDERING PARAMETERS -Temperature Min (Ts(min)) Pb-Free assembly (see FIG.5) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Pre Heat FIG.5: Reflow condition tp TP Critical Zone TL to TP Ramp-up Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. TL Ramp-down Preheat TS(min) ts 25 Reflow Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃to Peak Temp (TP) 8 min. Max Do not exceed +260℃ tL TS(max) Temperature Reflow Condition time to peak temperatue (t 25℃ to peak) Time PACKAGE MECHANICAL DATA A Dimensions C Ref. H G D E L J K Millimeters Min. Max. Min. Max. A 4.25 4.75 0.167 0.187 B 3.30 3.94 0.130 0.155 C 1.85 2.21 0.073 0.087 D 0.76 1.52 0.030 0.060 E 5.08 5.59 0.200 0.220 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.11 2.44 0.083 0.096 J 6.80 5/5 L 0.270 2.60 K DO-214AA (SMB) Inches 2.40 0.100 0.090
1.0SMBJ15CA 价格&库存
很抱歉,暂时无法提供与“1.0SMBJ15CA”相匹配的价格&库存,您可以联系我们找货
1.0SMBJ15CA
  • 1+0.39150
  • 10+0.37700
  • 100+0.34220
  • 500+0.32480
1.0SMBJ15CA
  • 5+0.59649
  • 50+0.47153
  • 150+0.40900
  • 500+0.36213
  • 3000+0.32465
  • 6000+0.30597
库存:1618
