SMD0603 Series
SMD0603 Polymer PTC
»Performance Specification
Maximum
Model
Markin
V max
Imax
g
Resistance
I hold
I trip
Pd
Time To Trip
@25°C
@25°C
Typ.
Current
Time
R i min
R1max
(V dc)
(A)
(A)
(A)
(W)
(A)
(Sec)
SMD0603-001/60N
X
60
0.03
0.5
0.2
1.00
15.000
100.000
SMD0603-002/60N
Y
60
0.06
0.5
0.2
1.00
12.000
70.000
SMD0603-002/09N
Y
9
0.06
0.5
0.2
1.00
12.000
70.000
SMD0603-003/30N
Z
30
0.09
0.5
0.2
1.00
6.000
50.000
SMD0603-003/09N
Z
9
0.09
0.5
0.2
1.00
6.000
50.000
SMD0603-004/15N
15.0
0.12
0.5
0.20
1.00
4.000
40.000
SMD0603-005/15N
15.0
0.15
0.5
0.25
1.00
3.800
30.000
SMD0603-005/30N
30.0
0.15
0.5
0.25
1.00
3.800
30.000
SMD0603-010/15N
1
15.0
35
0.10
0.30
0.5
0.5
1.00
0.900
6.000
SMD0603-010/09N
1
9.0
35
0.10
0.30
0.5
0.5
1.00
0.900
6.000
SMD0603-020/09N
2
9.0
35
0.20
0.50
0.5
1.0
0.60
0.550
3.500
SMD0603-020/16N
2
16.0
35
0.20
0.50
0.5
1.0
0.60
0.550
3.500
SMD0603-025/09N
2
9.0
35
0.25
0.55
0.5
8.0
0.08
0.500
3.000
SMD0603-025/16N
2
16.0
35
0.25
0.55
0.5
8.0
0.08
0.500
3.000
SMD0603-035/06N
3
6.0
35
0.35
0.75
0.5
8.0
0.10
0.200
1.000
SMD0603-040/06N
5
6.0
35
0.40
0.80
0.5
8.0
0.10
0.150
0.900
SMD0603-050/06N
5
6.0
35
0.50
1.00
0.5
8.0
0.10
0.100
0.800
SMD0603-050/12N
5
12.0
35
0.50
1.00
0.5
8.0
0.10
0.100
0.800
SMD0603-060/06N
7
6.0
35
0.60
1.20
0.5
8.0
0.10
0.080
0.600
SMD0603-065/06N
7
6.0
35
0.65
1.30
0.5
8.0
0.10
0.070
0.550
SMD0603-075/06N
7
6.0
35
0.75
1.40
0.5
8.0
0.10
0.060
0.450
SMD0603-100/06N
35
1.00
2.00
0.5
8.0
0.10
0.050
0.300
V max = Maximum operating voltage device can withstand without damage at rated current (Imax).
I max
= Maximum fault current device can withstand without damage at rated voltage (V max).
I hold
= Hold Current. Maximum current device will not trip in 25°C still air.
I trip
= Trip Current. Minimum current at which the device will always trip in 25°C still air.
Pd
= Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage.
Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C.
R1max = Maximum device resistance is measured one hour post reflow.
CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame.
»Environmental Specifications
Test
Conditions
Resistance change
Passive aging
+85°C, 1000 hrs.
±5% typical
Humidity aging
+85°C, 85% R.H. , 168 hours
±5% typical
Thermal shock
+85°C to -40°C, 20 times
±33% typical
Resistance to solvent
MIL-STD-202,Method 215
No change
Vibration
MIL-STD-202,Method 201
No change
Ambient operating conditions : - 40 °C to +85 °C
Maximum surface temperature of the device in the tripped state is 125 °C
Revision 2018
www.born-tw.com
1/5
SMD0603 Series
»Thermal Derading Chart
Model
Recommended Hold Current(A) at Ambient Temperature(°C)
Ambient Operation Temperature
-40°C
-20°C
0°C
25°C
40°C
50°C
60°C
70°C
85°C
SMD0603-001N
0.016
0.014
0.012
0.010
0.008
0.007
0.006
0.005
0.0035
SMD0603-002N
0.031
0.027
0.024
0.020
0.016
0.014
0.012
0.011
0.007
SMD0603-003N
0.047
0.041
0.036
0.030
0.024
0.021
0.018
0.016
0.0108
SMD0603-004N
0.052
0.048
0.044
0.040
0.032
0.028
0.024
0.020
0.012
SMD0603-005N
0.065
0.060
0.055
0.050
0.040
0.035
0.031
0.025
0.015
SMD0603-010N
0.13
0.12
0.11
0.10
0.08
0.07
0.06
0.05
0.03
SMD0603--020N
0.27
0.25
0.23
0.20
0.17
0.14
0.12
0.10
0.07
SMD0603-025N
0.32
0.29
0.27
0.25
0.21
0.18
0.16
0.14
0.10
SMD0603-035N
0.47
0.41
0.38
0.35
0.29
0.26
0.24
0.20
0.14
SMD0603-040N
0.54
0.47
0.43
0.40
0.33
0.29
0.27
0.22
0.16
SMD0603-050N
0.67
0.59
0.54
0.50
0.41
0.37
0.34
0.29
0.20
SMD0603-060N
0.81
0.70
0.651
0.60
0.49
0.44
0.41
0.34
0.24
SMD0603-065N
0.87
0.76
0.71
0.65
0.54
0.48
0.44
0.37
0.26
SMD0603-075N
0.98
0.85
0.81
0.75
0.60
0.54
0.44
0.40
0.31
SMD0603-100N
1.19
1.13
1.08
1.00
0.80
0.72
0.59
0.54
0.43
»Thermal Derating Curve
Revision 2018
»Average Time-Current Curve
www.born-tw.com
2/5
SMD0603Series
»Soldering Parameters
TP 20~40 S
TP 260
Critical Zone
Ramp-up
TL 217
TL to TP
tL
60~150 s
Tsmax
200
Tsmin
Ramp-down
150
ts
Preheat 60~180 s
25
t 25°C to peak
Time
Profile Feature
Pb-Free Assembly
Average Ramp-Up Rate(Ts max to T p)
3℃/second mac.
Preheat
-Temperature Min(Ts min)
150℃
-Temperature Max(Ts max)
200℃
-Time(Ts min to Ts max)
60~180 seconds
Time maintained above:
-Temperature(TL)
217℃
-Time(tL)
60~150 seconds
Peak Temperature(Tp)
260℃
Ramp-Down Rate
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max
Storage Condition
0℃~35℃,30%-60%RH
Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free
Recommended maximum paste thickness is 0.25mm
Devices can be cleaned using standard industry methods and solvents.
Note 1:All temperature refer to topside of the package, measured on the package body surface.
Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements
Revision 2018
www.born-tw.com
3/5
SMD0603 Series
»Physical Dimensions(mm.)
A
3
B
D
E
A
型號
C
B
C
D
E
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Min.
SMD0603-001N
1.45
1.85
0.65
1.05
0.40
1.00
0.15
0.10
SMD0603-002N
1.45
1.85
0.65
1.05
0.35
0.75
0.15
0.10
SMD0603-003N
1.45
1.85
0.65
1.05
0.35
0.75
0.15
0.10
SMD0603-004N
1.45
1.85
0.65
1.05
0.40
1.00
0.15
0.10
SMD0603-005N
1.45
1.85
0.65
1.05
0.35
0.75
0.15
0.10
SMD0603-010N
1.45
1.85
0.65
1.05
0.35
0.75
0.15
0.10
SMD0603-020N
1.45
1.85
0.65
1.05
0.30
0.70
0.15
0.10
SMD0603-020/16N
1.45
1.85
0.65
1.05
0.40
1.00
0.15
0.10
SMD0603-025N
1.45
1.85
0.65
1.05
0.30
0.70
0.15
0.10
SMD0603-025/16N
1.45
1.85
0.65
1.05
0.40
1.00
0.15
0.10
SMD0603-035N
1.45
1.85
0.65
1.05
0.35
0.90
0.15
0.10
SMD0603-040N
1.45
1.85
0.65
1.05
0.40
0.90
0.15
0.10
SMD0603-050N
1.45
1.85
0.65
1.05
0.55
1.15
0.15
0.10
SMD0603-050/15N
1.45
1.85
0.65
1.05
0.55
1.15
0.15
0.10
SMD0603-060N
1.45
1.85
0.65
1.05
0.55
1.15
0.15
0.10
SMD0603-065N
1.45
1.85
0.65
1.05
0.55
1.15
0.15
0.10
SMD0603-075N
1.45
1.85
0.65
1.05
0.55
1.15
0.15
0.10
SMD0603-100N
1.45
1.85
0.65
1.05
0.55
1.15
0.15
0.10
Termination Pad Characteristics
Terminal pad materials:Tin-plated Nickel-Copper
Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3.
»Recommended Pad Layout (mm.)
1.0 士 0.1
1.5 士 0.1
1.0 士 0.1
»Packaging Quantity
Part Number
SMD0603
Series
Quantity
4,000 pcs/reel
Tape & reel packaging per EIA481-1
1.2 士 0.1
Revision 2018
www.born-tw.com
4/5
SMD0603 Series
»Tape And Reel Specifications (mm)
Governing
Specifications
EIA 481-1
W
8.0 ± 0.2
P0
4.0 ± 0.10
P1
4.0 ± 0.10
P2
2.0 ± 0.05
A0
1.05 ± 0.10
B0
1.85 ± 0.10
D0
1.55 + 0.05
F
3.5 ± 0.05
E1
1.75 ± 0.10
E2min.
6.25
T
0.20
T1max.
0.1
K0
0.75/0.95 ± 0.1
Leader min.
390
Trailer min.
160
EIA Tape Component Dimensions
P0
Embossment
D
T
P2
E1
Cover
tape
B
A
F
W
B0
K0
E2
T
P1
EIA Reel Dimensions
W2(measured at hub)
A
Cover tape
Reel Dimensions
2
22
A max.
178
Carrier tape
N min.
60
Embossed cavity
W1
9.0 ± 0.5
W2
12.0 ± 0.05
W
8.0 ± 0.2
N(hub dia.)
W1(measured at hub)
Storage And Handling
‧ Storage conditions:35°C max,30%-60%R.H.
‧ Devices may not meet specified performance
‧ if storage conditions are exceeded.
»Part Number System
SMD
0603 - 020 / 16
N
BORN
special voltage Rating(Optional)
Holding Current Rating
Size 0603 inch
SMD
Revision 2018
www.born-tw.com
5/5
很抱歉,暂时无法提供与“SMD0603-035/06N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.22400
- 30+0.21600
- 100+0.20800
- 500+0.19200
- 1000+0.18400
- 2000+0.17920
- 国内价格
- 10+0.30953
- 100+0.24484
- 300+0.21255
- 1000+0.18825
- 4000+0.16881
- 8000+0.15909
