SELC3D12V1BA
SELC3D12V1BA
    ELECSUPER(静芯微)
    SOD-323
    TVS SOD323 Ppk=300W VC=35V Ipp=7A VRWM=12V
SELC3D12V1BA 数据手册
SELC3Dxx1BA Rev-2021-1 www.elecsuper.com SuperESD - SELC3Dxx1BA 1. Description The SELC3Dxx1BA Series are ultra-low capacitance transient voltage suppressor arrays, designed to protect applications such as portable electronics and smart phones. This series is available bidirectional configurations and is rated at 300 Watts for an 8/20us waveshape. At higher operating frequencies or faster edge rates, insertion loss and signal integrity are a major concern. This series offers a ultra-low capacitance and low leakage current in a miniature SOD-323 package. 2. Features    IEC 61000-4-2 Level 4 ESD Protection  RoHS compliance - ±15kV Contact Discharge  Bidirectional configuration - ±15kV Air Discharge  Ultra-low Capacitance: 0.8pF (Typical) IEC 61000-4-4 EFT Protection  Low clamping voltage -  Protects one power or I/O  End Equipment 40A (5/50ns) 300W Peak pulse Power (8/20us) 3. Applications  Interfaces - USB 2.0/1.1 - Industrial and Serve Robots - GPIO - Laptops and Desktops - Ethernet 10/100/1000 Mbps - TV and Monitors - Audio - Wearables 4. Ordering Information Part Number SELC3Dxx1BA Package Material Packing Quantity per reel Flammability Rating Reel Size SOD-323 Halogen free Tape & Reel 3000 PCS UL 94V-0 7 inches Marking for the SELC3Dxx1BA series VRWM 3.3V 5V 8V 12V 15V 24V - Marking CC AC BC DC EC HC - Table-1 Copyright© ElecSuper Incorporated Ordering information Contact Us 1 / 7 SELC3Dxx1BA Rev-2021-1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description 1 IO Connect to IO 2 IO Outline 1 Marking Circuit Diagram 2 2 1 Connect to IO Table-2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 300 W Peak pulse current (tp=8/20us)@25℃ IPP Refer to Table-5 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±15 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±15 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SELC3Dxx1BA Rev-2021-1 www.elecsuper.com 6.2. Electrical Characteristics Symbol Description VRWM Rated reverse stand-off voltage VBR Minimum breakdown voltage @IT = 1mA VCL Typical Clamping voltage IPP Maximum peak pulse current IR Reverse leakage current @VRWM CO Typical line capacitance (VIO=0V, VP-P = 30mV, f = 1MHz) Table-4 Parameters Description At TA = 25℃ unless otherwise noted VRWM VBR VCL@I=1A IPP VCL@I=IPP IR CO (V) (V) (V) (A) (V) (uA) (pF) SELC3D3V1BA 3.3 4.5 8.5 14.0 20.0 1.0 0.8 SELC3D5V1BA 5.0 6.5 9.5 12.0 21.0 1.0 0.8 SELC3D8V1BA 8.0 8.5 12.0 10.0 25.0 1.0 0.8 SELC3D12V1BA 12.0 13.3 19.0 7.0 35 1.0 0.8 SELC3D15V1BA 15.0 16.5 24 5.0 45 1.0 0.8 SELC3D24V1BA 24.0 26.0 34 3.0 55 1.0 0.8 Part Number Table-5 Copyright© ElecSuper Incorporated Electrical Characteristics for All Series Contact Us 3 / 7 SELC3Dxx1BA Rev-2021-1 www.elecsuper.com 7. Typical Characteristic 8. Typical Application Pic-3 Copyright© ElecSuper Incorporated Typical Internet 1G Interface Application Contact Us 4 / 7 SELC3Dxx1BA Rev-2021-1 www.elecsuper.com 9. Dimension SOD-323 Symbol A A1 A2 b C D E E1 L L1 θ Dimensions in Millimeters Min. Max. 1.000 0.000 0.100 0.800 0.900 0.250 0.350 0.080 0.150 1.200 1.400 1.600 1.800 2.550 2.750 0.475REF 0.250 0.400 0° 8° Table-6 Copyright© ElecSuper Incorporated Dimensions in Inches Min. Max. 0.039 0.000 0.004 0.031 0.035 0.010 0.014 0.003 0.006 0.047 0.055 0.063 0.071 0.100 0.108 0.019REF 0.010 0.016 0° 8° product dimensions Contact Us 5 / 7 SELC3Dxx1BA Rev-2021-1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only Copyright© ElecSuper Incorporated Contact Us 6 / 7 SELC3Dxx1BA Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products Copyright© ElecSuper Incorporated Contact Us 7 / 7
SELC3D12V1BA 价格&库存
很抱歉,暂时无法提供与“SELC3D12V1BA”相匹配的价格&库存,您可以联系我们找货
SELC3D12V1BA
    • 10+0.32012
    • 100+0.23933
    • 300+0.19883
    • 1000+0.16848
    库存:19
