SS52
SS510
THRU
5.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
20 to 100 Volts
CURRENT
5.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
DO-214AC(SMA)
.110(2.79)
.100(2.54)
.058(1.47)
.052(1.32)
MECHANICAL DATA
.177(4.50)
.157(3.99)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.063 grams
.012(0.31)
.006(0.15)
.090(2.29)
.078(1.98)
.005
MAX.
(.127)
.208(5.28)
.194(4.93)
.060(1.52)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
SS52
SS53
21
30
SS54
40
28
40
SS55
SS56
50
35
50
60
42
60
At TL=100 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
SS59
SS510
UNITS
80
56
80
90
63
90
100
70
100
V
V
V
A
5.0
120
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 5.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJL (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
SS58
0.55
0.85
0.70
0.2
Ta=100 C
10
-65
+125
-65
-65
+150
+150
A
V
mA
mA
pF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (SS52 THRU SS510)
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
FIG.2-TYPICAL FORWARD
60
80
100
120
140
160
180
200
AMBIENT TEMPERATURE,( C)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
S5
SS
5
8
SS
5
10
6
~S
~S
S5
2
5
SS
1.0
SS
5
54
SS
2.0
10
SS
5
55
SS
3.0
INSTANTANEOUS FORWARD CURRENT,(A)
4.0
4
50
5.0
52
SS
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
6.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
PEAK FORWARD SURGE CURRENT,(A)
150
.01
120
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
90
8.3ms Single Half
Tj=25 C
Sine Wave
60
JEDEC method
30
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
1400
1200
1000
800
600
400
10
Tj=75 C
1.0
.1
Tj=25 C
200
.05
.1
.5
1
REVERSE VOLTAGE,(V)
5
10
50
100
.01
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SS54”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.25630
- 50+0.12760
- 2000+0.09680
- 国内价格
- 20+0.21482
- 200+0.17185
- 600+0.14799
- 2000+0.11631
- 8000+0.10392
- 16000+0.09721
- 国内价格
- 20+0.20347
- 200+0.16409
- 800+0.14221
- 2000+0.11318
- 10000+0.10182
- 20000+0.10080
