BV-ULC0524P
BV-ULC0524P
    BENCENT(槟城)
    DFN2510-10
    TVS二极管 VRWM=5 V VBR(Min)=6 V VC=15 V IPP=1 A Ppp=Original DFN2510-10L
BV-ULC0524P 数据手册
BV V_ULC00524P Ordder Code:BV V_ULC05224P Version n: A1 2014-03 3-26 Tra ansient Vo oltage Sup ppressor F Features Exterior E IE EC 61000-4-22(ESD)±15K KV(air), ±8K KV(contact) ES SD Maximum m ±17KV (airr), ±12KV (contact) IE EC61000-4-4 (EFT) 40A (5/50ns) ( IE EC61000-4-5 (Lightning) 4 A (8/20us) 1550Watts peakk pulse powerr per line (tp= =8/20μS) Loow capacitannce: 0.5 pF typpical (I/O to I/O) I Loow operatingg voltage: 5V Loow clamping voltage M Moisture sensiitivity level: level l 1 W Weight 15 mg (Approximatte) Sm mall packagee: DFN2510-110L DFN22510-10L Package P (topp view) Appplication Information High Definitioon Multi-Meddia Interface (HDMI) H ( Digital Visual Interface (DV VI) U Unified Displaay Interface (U UDI) Display Port M MDDI Ports PC CI Express Seerial ATA A Agency Appprovals Icon Schematic Descriptio on Compliance with 2011/6 65/EU Compliance withIEC61249-2-21:2003 3 Mean lead frree Paart Number and a Electriccal Parametter IDRM@ VDRM Part Number Mark μA V MAX BV V_ULC0524P P P524 5 VBR①@ IR V Vc@Ipp② V mA MIN 5 6 V A MA AX 1 15 V A MAX 1 CO③ Vc@Ipp② 25 4 pF p pF I/O-I/O I//O-GND MAX MAX 0.8 1.3 Ab bsolute maxim mum ratings measured m at TA= 25ºC RH H = 45%-75% % (unless otheerwise noted)). ① VBR is measu ured at IR=1m mA ②Surge S Wavefform: 8/20μS. ③Off-state O capaacitance is measured m in VDC D =0V,VRMS=1V,f=1MHz = z. 1/4 www.benncent.com.cn S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications BV V_ULC00524P Ordder Code:BV V_ULC05224P Version n: A1 2014-03 3-26 Tra ansient Vo oltage Sup ppressor Part Numberring System m BV Mark M ULC0524P (1) P5 524 (2) ( Bencent Transient (1) T Volttage Suppresssor ( Series:UL (2) LC0524P etc. P524: Paart Number V Curve V-I I Parameterrs Definitiion VC Clamping Voltage V Ipp Su urge waveform m8/20μs VDRM Stand-off Voltage V VBR Breakdown Voltage V IDRM Reeverse Leakagge Current IR Test Currrent Ppp Peak k Pulse Powerr Dissipation VC VBR VDRRM IF VF V IDRM IR IPP Thhermal Conssiderations s symbol Parameteer Value Uniit TJ Operating Junction J Tem mperature Ran nge -55 to +150 ℃ TS Storaage Temperatu ure Range -55 to +150 ℃ Ennvironmentaal Characterristics Testing items High temp perature Reverrse Bias Test High Temp perature Life Test High-low Temperature T Cycle test High Tem mperature &H High Humid dity Test Pressure co ooker Test Resistance of soldering heat Tech hnical standarrds Temperrature: 150±3 3℃ Bias=80% %VDRM Time:1 168H Temperrature: 150℃ ℃ Time:1 168H Temperrature: From -40℃ to125℃ ℃ Dwell time t :30miin,10-100cycles Humidity:85% % Temperrature: 85℃H Time:1 168H Temperrature: 121℃ ℃,2atm. Hum midity:100% Time:2 24H-168H Temperrature: 260±5 5℃ Time of o dip solderin ng:10s,3tiimes Note: The abbove testing items can be specified s by customers c by y contacting Bencent B servicce 2/4 www.benncent.com.cn S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications BV V_ULC00524P Ordder Code:BV V_ULC05224P Version n: A1 2014-03 3-26 Tra ansient Vo oltage Sup ppressor Prooduct Dimeensions REF R mm inch A 0.58±0.08 8 0.023±0.00 03 A1 0.03±0.03 3 0.001±0.00 01 A2 0.13(Max) ) 0.005(Max x) b 0.20±0.05 5 0.008±0.00 02 b1 0.40±0.05 5 0.016±0.00 02 D 2.50±0.10 0 0.098±0.00 04 E 1.00±0.10 0 0.039±0.00 04 e 0.50 0.020 L 0.38±0.05 5 0.015±0.00 02 Reecommended Solderingg Pad 3/4 www.benncent.com.cn REF mm m inch C 0.87 75 0.034 G 0.20 0.008 P 0.50 0.020 P1 1.00 0.039 X 0.20 0.008 X1 0.40 0.016 Y 0.65 0.026 Y1 1.55 0.061 Z 1.55 0.061 S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications BV V_ULC00524P Ordder Code:BV V_ULC05224P Version n: A1 2014-03 3-26 Tra ansient Vo oltage Sup ppressor Refflow Profilee Pre Heat Pb-Free asssembly Tempeerature Min 150°C Tempeerature Max 200°C Time (min to max x) 60 – 180 seccs Aveerage ramp up rate(Liquid) ) Tam mp(TL) to peal p 3°C/s max TS(m max) to TL - Ramp-up R Rate 3°C/s max Refflow TP TP perature (TL) (L Liquid) - Temp 217°C - Temp perature (TL) 60 – 150 seccs Peaak Temperaturee (TP) 260+0/-5 °C C Tim me within 5°C of actual peak k Temperature (TP) 8– 15secs Ram mp-down Ratee 6°C/s max Tim me 25°C to peaak Temperaturee (TP) 8 mins Max x. Do not exceed 260°C Paackage 4/4 Reeel Criitical Zone TL to TP Ramp-up TL Temperature Refl flow Condition n TL TS(max) Ramp-dow wn Preheat TS(min) TS 25 Timee time to peak temp perature Inform mation REF mm inch A 1.3+/-0.1 1 0.051+ +/-0.004 B 3.0+/-0.1 1 0.354+ +/-0.004 d 1.25+/-0.1 0.049+ +/-0.004 D 178+/-1.0 0 7.01+ +/-0.039 D1 55+/-3 2.165+ +/-0.118 D2 13+/-0.5 5 0.512+ +/-0.020 E 1.75+/-0.1 0.069+ +/-0.004 F 3.6+/-0.2 2 0.138+ +/-0.008 P 4.0+/-0.2 2 0.158+ +/-0.008 P0 4.0+/-0.2 2 0.158+ +/-0.008 P1 2.0+/-0.2 2 0.079+ +/-0.008 W 8.0+/-0.2 2 0.315+ +/-0.008 W1 14.4+/-0.5 0.567+ +/-0.020 Outline Reeel (pccs) Per Carton (pcs) Reeel Diameters (mm) Taping 3,000 90,000 177 www.benncent.com.cn Carton Size((mm) L W H 390 370 220 S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications
BV-ULC0524P 价格&库存
很抱歉,暂时无法提供与“BV-ULC0524P”相匹配的价格&库存,您可以联系我们找货
