HG25Q40M/TR
HG25Q40M/TR
    HGSEMI(华冠)
    SOP-8
    3V 4位串行NOR闪存,带双和四芯SPI SOP8
HG25Q40M/TR 数据手册
HG25Q40 3V 4M -BIT SERIAL NOR FLASH WITH DUAL AND QUAD SPI FEATURES  Low power supply operation - Single 2.3V-3.6V supply overhead  Flexible Architecture with 4KB sectors - Sector Erase (4K-bytes) - Block Erase (32K/64K-bytes) - Page Program up to 256 bytes - More than 100K erase/program cycles - More than 20-year data retention  4M/2M bit Serial Flash - 4 M-bit/512K-byte/2,048 pages - 2 M-bit/256K-byte/1,024 pages - 256 bytes per programmable page - Uniform 4K-byte Sectors, 32K/64K-byte Blocks  New Family of SpiFlash Memories - Standard SPI: CLK, CS#, DI, DO, WP#, HOLD# / RESET# - Dual SPI: CLK, CS#, DI, DO, WP#, HOLD# / RESET# - Quad SPI: CLK, CS#, IO0, IO1, IO2, IO3 - Software & Hardware Reset - Auto-increment Read capability  Advanced Security Feature - Software and Hardware Write-Protect - Power Supply Lock-Down and OTP protection - Top/Bottom, Complement array protection - 64-Bit Unique ID for each device - Discoverable parameters(SFDP) register - 3X256-Bytes Security Registers with OTP locks - Volatile & Non-volatile Status Register Bits  Temperature Ranges - Industrial (-40°C to +85°C) - Extended (-20°C to +85°C)  High performance program/erase speed - Page program time: 400us typical - Sector erase time: 35ms typical - Block erase time: 200ms typical - Chip erase time: 10 Seconds typical  Low power consumption - 9 mA typical active current - 2 uA typical power down current  Package Options - 8-pin SOIC 150/208-mil - 8-pad WSON 6x5-mm - 8-pin PDIP 300-mil - All Pb-free packages are RoHS compliant  Efficient “Continuous Read” and Quad Read - Continuous Read with 8/16/32/64-Byte Wrap - As few as 8 clocks to address memory - Quad Peripheral Interface reduces instruction GENERAL DESCRIPTION The HG25Q40/20 of non-volatile flash memory device supports the standard Serial Peripheral Interface (SPI). Traditional SPI single bit serial input and output (Single I/O or SIO) is supported as well as optional two bit (Dual I/O or DIO) and four bit (quad I/O) serial protocols. This multiple width interface is called SPI Multi-I/O or MIO. The SPI protocols use only 4 to 6 signals:  Chip Select (CS#)  Serial Clock (CLK)  Serial Data - IO0 (DI) - IO1 (DO) - IO2 (WP#) - IO3 (HOLD# / RESET#) http://www.hgsemi.com.cn 1 2018 JUN HG25Q40 The HG25Q 40/20 support the standard Serial Peripheral Interface (SPI), Dual/Quad I/O SPI as well as 2-clocks instruction cycle Quad Peripheral Interface : Serial Clock, Chip Select, Serial Data I/O0 (DI), I/O1 (DO), I/O2 (WP#), and I/O3 (HOLD# / RESET#). SPI clock frequencies of up to 104MHz are supported allowing equivalent clock rates of 208MHz (104MHz x 2) for Dual I/O and 44MHz (104MHz x 4) for Quad I/O when using the Fast Read Dual/Quad I/O . These transfer rates can outperform standard Asynchronous 8 and 16-bit Parallel Flash memories. The Continuous Read Mode allows for efficient memory access with as few as 8-clocks of instruction-overhead to read a 24-bit address, allowing true XIP (execute in place) operation. A Hold pin, Write Protect pin and programmable write protection, with top or bottom array control, provide further control flexibility. Additionally, the device supports JEDEC standard manufacturer and device ID and SFDP Register, a 64-bit Unique Serial Number and three 256-bytes Security Registers. The HG25Q40/20 provides an ideal storage solution for systems with limited space, signal connections, and power. These memories' flexibility and performance is better than ordinary serial flash devices. They are ideal for code shadowing to RAM, executing code directly (XIP), and storing reprogrammable data. http://www.hgsemi.com.cn 2 2018 JUN HG25Q40 BLOCK DIAGRAM Figure 2.1 Block Diagram http://www.hgsemi.com.cn 3 2018 JUN HG25Q40 CONNECTION DIAGRAMS Figure 3.1 8-pin SOP (150/208mil)/ PDIP (300mil) Figure 3.2 8-Contact 6 x 5 mm WSON http://www.hgsemi.com.cn 4 2018 JUN HG25Q40 SIGNAL DESCRIPTIONS Table 4.1 Pin Descriptions Symbol Pin Name CLK Serial Clock Input DI(IO0) Serial Data Input(Data input output 0) (1) DO(IO1) Serial Data Output(Data input output 1) (1) CS# Chip Enable WP#(IO2)(3) Write Protect (Data input output 2) (2) HOLD# / RESET#(3)(IO3) Hold or Reset input(Data input output 3) (2) VCC Power Supply (2.3-3.6V) GND Ground Notes: (1)IO0 and IO1 are used for Standard and Dual SPI instructions. (2)IO0—IO3 are used for QUAD SPI instructions. (3)WP# and HOLD# / RESET# functions are only available for Standard and Dual SPI. Serial Data Input (DI) / IO0 The SPI Serial Data Input (DI) pin is used to transfer data serially into the device. It receives instructions, address and data to be programmed. Data is latched on the rising edge of the Serial Clock (CLK) input pin. The DI pin becomes IO0 - an input and output during Dual and Quad commands for receiving instructions, address, and data to be programmed (values latched on rising edge of serial CLK clock signal) as well as shifting out data (on the falling edge of CLK). Serial Data Output (DO) / IO1 The SPI Serial Data Output (DO) pin is used to transfer data serially out of the device. Data is shifted out on the falling edge of the Serial Clock (CLK) input pin. DO becomes IO1 - an input and output during Dual and Quad commands for receiving instructions, addresses, and data to be programmed (values latched on rising edge of serial CLK clock signal) as well as shifting out data (on the falling edge of CLK). Serial Clock (CLK) The SPI Serial Clock Input (CLK) pin provides the timing for serial input and output operations. ("See SPI Mode") Chip Select (CS#) The SPI Chip Select (CS#) pin enables and disables device operation. When CS# is high the device is deselected and the Serial Data Output pins are at high impedance. When deselected, the devices power consumption will be at standby levels unless an internal erase, program or status register cycle is in progress. When CS# is brought low the device will be selected, power consumption will increase to active levels and instructions can be written to and data read from the device. After power-up, CS# must transition from high to low before a new instruction will be accepted. http://www.hgsemi.com.cn 5 2018 JUN HG25Q40 Write Protect (WP#) / IO2 The Write Protect (WP#) pin can be used to prevent the Status Register from being written. Used in conjunction with the Status Register’s Block Protect (BP0, BP1 and BP2, TB, SEC, CMP) bits and Status Register Protect (SRP0) bits, a portion or the entire memory array can be hardware protected. The WP# function is not available when the Quad mode is enabled. The WP# function is replaced by IO2 for input and output during Quad mode for receiving addresses and data to be programmed (values are latched on rising edge of the CLK signal) as well as shifting out data (on the falling edge of CLK). HOLD (HOLD#) / IO3 The HOLD# pin allows the device to be paused while it is actively selected. When HRSW bit is ‘0’ (factory default is ‘0’), the HOLD# pin is enabled. When HOLD# is brought low, while CS# is low, the DO pin will be at high impedance and signals on the DI and CLK pins will be ignored (don’t care). When HOLD# is brought high, device operation can resume. The HOLD# function can be useful when multiple devices are sharing the same SPI signals. The HOLD# pin is active low. When the QE bit of Status Register-2 is set for Quad I/O, the HOLD# pin function is not available since this pin is used for IO3. RESET (RESET#) / IO3 The RESET# pin allows the device to be reset by the controller. When HRSW bit is ‘1’ (factory default is ‘0’), the RESET# pin is enabled. Drive RESET# low for a minimum period of ~1us (tRESET*) will interrupt any on-going external/internal operations, regardless the status of other SPI signals (CS#, CLK, DI, DO, WP# and/or HOLD#). The Hardware Reset function is only available for standard SPI and Dual SPI operation, when QE=0, the IO3 pin can be configured either as a HOLD# pin or as a RESET# pin depending on Status Register setting, when QE=1, this pin is the Serial Data IO (IO3) for Quad I/O operation. http://www.hgsemi.com.cn 6 2018 JUN HG25Q40 MEMORY ORGANIZATION Flash Memory Array The HG25Q40 memory is organized as: - 524,288bytes - Uniform Sector Architecture 8 blocks of 64-Kbyte - 128 sectors of 4-Kbyte - 2, 048 pages (256 bytes each) Each page can be individually programmed (bits are programmed from 1 to 0). The device is Sector, Block or Chip Erasable but not Page Erasable. Table 5.1(1) Memory Organization(HG25Q40) Block/ Security Register/SFDP Security Register 3 Sector Address range - 003000H 0030FFH Security Register 2 - 002000H 0020FFH Security Register 1 Security Register 0 (SFDP) - 001000H 0010FFH - 000000H 0000FFH 127 07F000H 07FFFFH ...... ...... ...... 112 070000H 070FFFH Block 7 Block 6 ...... ...... Block 2 Block 1 Block 0 111 06F000H 06FFFFH ...... ...... ...... 060FFFH 96 060000H ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... 02FFFFH 47 02F000H ...... ...... ...... 32 020000H 020FFFH 31 01F000H 01FFFFH ...... ...... ...... 16 010000H 010FFFH 00FFFFH 15 00F000H ...... ...... ...... 0 000000H 000FFFH Notes: (1)These are condensed tables that use a couple of sectors as references. There are address ranges that are not explicitly listed. All 4-kB sectors have the pattern XXX000h-XXXFFFh. http://www.hgsemi.com.cn 7 2018 JUN HG25Q40 The HG25Q20 memory is organized as: - 262,144bytes - Uniform Sector Architecture 4 blocks of 64-Kbyte - 64 sectors of 4-Kbyte - 1, 024 pages (256 bytes each) Each page can be individually programmed (bits are programmed from 1 to 0). The device is Sector, Block or Chip Erasable but not Page Erasable. Table 5.2(1) Memory Organization(HG25Q20) Block/ Security Register/SFDP Security Register 3 Sector Address range - 003000H 0030FFH Security Register 2 - 002000H 0020FFH Security Register 1 Security Register 0 (SFDP) - 001000H 0010FFH - 000000H 0000FFH 03FFFFH Block 3 Block 2 Block 1 Block 0 63 03F000H ...... ...... ...... 48 030000H 030FFFH 47 02F000H 02FFFFH ...... ...... ...... 32 020000H 020FFFH 01FFFFH 31 01F000H ...... ...... ...... 16 010000H 010FFFH 00FFFFH 15 00F000H ...... ...... ...... 0 000000H 000FFFH Notes: (1)These are condensed tables that use a couple of sectors as references. There are address ranges that are not explicitly listed. All 4-kB sectors have the pattern XXX000h-XXXFFFh. Security Registers The HG25Q40/20 provides four 256-byte Security Registers. Each register can be used to store information that can be permanently protected by programming One Time Programmable (OTP) lock bits in Status Register-2. Register 0 is used byFSRKto store and protect the Serial Flash Discoverable Parameters (SFDP) information that is also accessed by the Read SFDP command. See Table 5.1. The three additional Security Registers can be erased, programmed, and protected individually. These registers may be used by system manufacturers to store and permanently protect security or other important information separate from the main memory array. Security Register 0 Serial Flash Discoverable Parameters (SFDP — JEDEC JESD216B): This document defines the Serial Flash Discoverable Parameters (SFDP) revision B data structure for HG25Q40/20 family. The Read SFDP (RSFDP) command (5Ah) reads information from a separate flash memory address space for device identification, feature, and configuration information, in accord with the JEDEC JESD216B standard for Serial Flash Discoverable Parameters. The SFDP data structure consists of a header table that identifies the revision of the JESD216 header format that is supported and provides a revision number and pointer for each of the SFDP parameter tables that are provided. The parameter tables follow the SFDP header. However, the parameter tables may be http://www.hgsemi.com.cn 8 2018 JUN HG25Q40 placed in any physical location and order within the SFDP address space. The tables are not necessarily adjacent nor in the same order as their header table entries. The SFDP header points to the following parameter tables:  Basic Flash – This is the original SFDP table. The physical order of the tables in the SFDP address space is: SFDP Header, and Basic Flash. The SFDP address space is programmed byFSRK and read-only for the host system. Serial Flash Discoverable Parameters (SFDP) Address Map The SFDP address space has a header starting at address zero that identifies the SFDP data structure and provides a pointer to each parameter. One Basic Flash parameter is mandated by the JEDEC JESD216B standard. Table 5.2 SFDP Overview Map — Security Register 0 Byte Address 0000h 0010h 0030h ... 006Fh 0070h to 00FFh http://www.hgsemi.com.cn Description Location zero within JEDEC JESD216B SFDP space – start of SFDP header Undefined space reserved for future SFDP header Start of SFDP parameter Remainder of SFDP JEDEC parameter followed by undefined space End of SFDP space Reserved space 9 2018 JUN HG25Q40 SFDP Header Field Definitions Table 5.3 SFDP Header SFDP Byte Address 00h 01h 02h 03h SFDP Dword Name SFDP Header 1st DWORD 04h Data 53h 46h 44h 50h 06h SFDP Header 2nd DWORD 05h 01h 06h 07h 08h 00h FFh 00h 09h Parameter Header 0 1st DWORD 06h 0Ah 01h 0Bh 10h 0Ch 0Dh 0Eh 0Fh Parameter Header 0 2nd DWORD http://www.hgsemi.com.cn 30h 00h 00h FFh Description This is the entry point for Read SFDP (5Ah) command i.e. location zero within SFDP space ASCII “S” ASCII “F” ASCII “D” ASCII “P” SFDP Minor Revision (06h = JEDEC JESD216 Revision B) – This revision is backward compatible with all prior minor revisions. Minor revisions are changes that define previously reserved fields, add fields to the end, or that clarify definitions of existing fields. Increments of the minor revision value indicate that previously reserved parameter fields may have been assigned a new definition or entire Dwords may have been added to the parameter table. However, the definition of previously existing fields is unchanged and therefore remains backward compatible with earlier SFDP parameter table revisions. Software can safely ignore increments of the minor revision number, as long as only those parameters the software was designed to support are used i.e. Previously reserved fields and additional Dwords must be masked or ignored. Do not do a simple compare on the minor revision number, looking only for a match with the revision number that the software is designed to handle. There is no problem with using a higher number minor revision. SFDP Major Revision – This is the original major revision. This major revision is compatible with all SFDP reading and parsing software. Number of Parameter Headers (zero based, 00h = 1 parameters Unused Parameter ID LSB (00h = JEDEC SFDP Basic SPI Flash Parameter) Parameter Minor Revision (00h = JESD216) –This older revision parameter header is provided for any legacy SFDP reading and parsing software that requires seeing a minor revision 6 parameter header. SFDP software designed to handle later minor revisions should continue reading parameter headers looking for a higher numbered minor revision that contains additional parameters for that software revision. Parameter Major Revision (01h = The original major revision - all SFDP software is compatible with this major revision. Parameter Table Length (in double words = Dwords = 4-byte units) 10h = 16 Dwords Parameter Table Pointer Byte 0 (Dword = 4-byte aligned) JEDEC Basic SPI Flash parameter byte offset = 30h Parameter Table Pointer Byte 1 Parameter Table Pointer Byte 2 Parameter ID MSB (FFh = JEDEC defined legacy Parameter ID) 10 2018 JUN HG25Q40 JEDEC SFDP Basic SPI Flash Parameter SFDP Parameter Relative Byte Address Table 5.4 Basic SPI Flash Parameter, JEDEC SFDP Rev B (Sheet 1 of 5) SFDP Dword Name 30h 31h Data E5h JEDEC Basic Flash Parameter Dword-1 20h 32h F1h 33h 34h 35h 36h FFh FFh FFh 1Fh/3Fh 00h 37h 38h 39h 3Ah JEDEC Basic Flash Parameter Dword-2 JEDEC Basic Flash Parameter Dword-3 3Bh 3Ch 3Dh 3Eh 41h 42h 43h 44h 45h 46h 47h EBh 08h 6Bh JEDEC Basic Flash Parameter Dword-4 3Fh 40h 44h 08h 3Bh 80h BBh JEDEC Basic Flash Parameter Dword-5 JEDEC Basic Flash Parameter Dword-6 http://www.hgsemi.com.cn FFh FFh FFh FFh FFh FFh FFh FFh Description Start of SFDP JEDEC parameter Bits 7:5 = unused = 111b Bit 4:3 = 05h is volatile status register write instruction and status register is default non-volatile= 00b Bit 2 = Program Buffer > 64 bytes = 1 Bits 1:0 = Uniform 4-kB erase is supported throughout the device = 01b Bits 15:8 = Uniform 4-kB erase instruction = 20h Bit 23 = Unused = 1b Bit 22 = Supports QOR Read (1-1-4), Yes = 1b Bit 21 = Supports QIO Read (1-4-4),Yes =1b Bit 20 = Supports DIO Read (1-2-2), Yes = 1b Bit19 = Supports DDR, No= 0 b Bit 18:17 = Number of Address Bytes 3 only = 00b Bit 16 = Supports SIO and DIO Yes = 1b Binary Field: 1-1-1-1-0-00-1 Nibble Format: 1111_0001 Hex Format: F1 Bits 31:24 = Unused = FFh Density in bits, zero based, 2 Mb = 001FFFFFh 4 Mb = 003FFFFFh 8 Mb = 007FFFFFh Bits 7:5 = number of QIO (1-4-4)Mode cycles = 010b Bits 4:0 = number of Fast Read QIO Dummy cycles = 00100b for default latency code Fast Read QIO (1-4-4)instruction code Bits 23:21 = number of Quad Out (1-1-4) Mode cycles = 000b Bits 20:16 = number of Quad Out Dummy cycles = 01000b for default latency code Quad Out (1-1-4)instruction code Bits 7:5 = number of Dual Out (1-1-2)Mode cycles = 000b Bits 4:0 = number of Dual Out Dummy cycles = 01000b for default latency code Dual Out (1-1-2) instruction code Bits 23:21 = number of Dual I/O Mode cycles = 100b Bits 20:16 = number of Dual I/O Dummy cycles = 00000b for default latency code Dual I/O instruction code Bits 7:5 RFU = 111b Bit 4 = QPI (4-4-4) fast read commands not supported = 0b Bits 3:1 RFU = 111b Bit 0 = Dual All not supported = 0b Bits 15:8 = RFU = FFh Bits 23:16 = RFU = FFh Bits 31:24 = RFU = FFh Bits 7:0 = RFU = FFh Bits 15:8 = RFU = FFh Bits 23:21 = number of Dual All Mode cycles = 111b Bits 20:16 = number of Dual All Dummy cycles = 11111b Dual All instruction code 11 2018 JUN HG25Q40 SFDP Parameter Relative Byte Address 48h 49h 4Ah 4Bh 4Ch 4Dh 4Eh 4Fh 50h 51h 52h Table 5.4 Basic SPI Flash Parameter, JEDEC SFDP Rev B (Sheet 2 of 5) SFDP Dword Name JEDEC Basic Flash Parameter Dword-8 JEDEC Basic Flash Parameter Dword-9 JEDEC Basic Flash Parameter Dword-4 53h http://www.hgsemi.com.cn Data Description 0Ch 20h 0Fh 52h 10h D8h 00h FFh Erase Type 1 size 2N Bytes = 4 kB = 0Ch (for Uniform 4 kB) Erase Type 1 instruction Erase Type 2 size 2N Bytes = 32 kB = 0Fh (for Uniform 32 kB) Erase Type 2 instruction Erase Type 3 size 2N Bytes =64 kB = 10h(for Uniform 64 kB) Erase Type 3 instruction Erase Type 4 size 2N Bytes = not supported = 00h Erase Type 4 instruction = not supported = FFh Bits 31:30 = Erase Type 4 Erase, Typical time units (00b: 1 ms, 01b: 16 ms, 10b: 128 ms, 11b:1 s) = RFU = 11b Bits 29:25 = Erase Type 4 Erase, Typical time count = RFU = 11111b (typ erase time = (count+1) * units) = RFU =11111 Bits 24:23 = Erase Type 3 Erase, Typical time units (00b: 1 ms, 01b: 16 ms, 10b: 128 ms, 11b:1 s) = RFU = 01b Bits 22:18 = Erase Type 3 Erase, Typical time count = 01011b (typ erase time = (count +1) *units) = 12*16 ms =200ms Bits 17:16 = Erase Type 2 Erase, Typical time units (00b: 1 ms, 01b: 16 ms, 10b: 128 ms, 11b:1 s) = 16 ms = 01b Bits 15:11 = Erase Type 2 Erase, Typical time count = 01000b (typ erase time = (count +1) *units) = 9*16 ms = 150 ms Bits 10:9 = Erase Type 1 Erase, Typical time units (00b: 1 ms, 01b: 16 ms, 10b: 128 ms, 11b: 1s) = 16ms = 01b Bits 8:4 = Erase Type 1 Erase, Typical time count = 00001b (typ erase time = (count +1) *units) = 2*16 ms = 35 ms Bits 3:0 = Count = (Max Erase time / (2 * Typical Erase time))- 1 = 0011b Multiplier from typical erase time to maximum erase time = 8x multiplier Max Erase time = 2*(Count +1)*Typ Erase time Binary Fields: 1111111_0101011_0101000_0100001_0011 Nibble Format: 1111_1110_1010_1101_0100_0010_0001_0011 Hex Format: FE_AD_42_13 13h 42h ADh FEh 12 2018 JUN HG25Q40 SFDP Parameter Relative Byte Address 54h 55h 56h Table 5.4 Basic SPI Flash Parameter, JEDEC SFDP Rev B (Sheet 3 of 5) SFDP Dword Name JEDEC Basic Flash Parameter Dword-11 Data Description 81h 65h Bits 23 = Byte Program Typical time, additional byte units (0b:1 μs, 1b:8 μs) = 1 μs = 0b Bits 22:19 = Byte Program Typical time, additional byte count, (count+1)*units, count = 0010b,(typ Program time = (count +1) * units) = 3*1 μs =3 μs Bits 18 = Byte Program Typical time, first byte units (0b:1 μs, 1b:8 μs) = 8 μs = 1b Bits 17:14 = Byte Program Typical time, first byte count, (count+1)*units, count = 0001b, (typ Program time = (count +1) * units) = 2*8 μs = 16 μs Bits 13 = Page Program Typical time units (0b:8 μs, 1b:64 μs) = 64 μs = 1b Bits 12:8 = Page Program Typical time count, (count+1)*units, count = 00101b, (typ Program time = (count +1) * units) = 6*64 μs = 400 μs Bits 7:4 = N = 1000b, Page size= 2N = 256B page Bits 3:0 = Count = 0001b = (Max Page Program time / (2 * Typ Page Program time))- 1 Multiplier from typical Page Program time to maximum Page Program time = 4x multiplier Max Page Program time = 2*(Count +1)*Typ Page Program time Binary Fields: 0-0010-1-0001-1-00101-1000-0001 Nibble Format: 0001_0100_0110_0101_1000_0001 Hex Format: 14_65_81 4 Mb = 1010_0101b = A5h 2 Mb = 1010_0011b = A3h Bit 31 Reserved = 1b Bits 30:29 = Chip Erase, Typical time units (00b: 16 ms, 01b: 256 ms, 10b: 4 s, 11b: 64 s) = 256ms= 01b Bits 28:24 = Chip Erase, Typical time count, (count+1)*units, count = 00101b (00011b), (typ Program time = (count +1) * units) = 6(4)*256ms = 1.5(1)s Bit 31 = Suspend and Resume supported = 0b Bits 30:29 = Suspend in-progress erase max latency units (00b: 128ns, 01b: 1us, 10b: 8 μs,11b: 64 μs) = 1 μs= 01b Bits 28:24 = Suspend in-progress erase max latency count = 10011b, max erase suspend latency = (count +1) * units = 20*1 μs = 20 μs Bits 23:20 = Erase resume to suspend interval count = 0001b, interval = (count +1) * 64 μs = 2* 64 μs = 128 μs Bits 19:18 = Suspend in-progress program max latency units (00b: 128ns, 01b: 1us, 10b: 8 μs,11b: 64 μs) = 1 μs= 01b Bits 17:13 = Suspend in-progress program max latency count = 10011b, max erase suspend latency = (count +1) * units = 20*1 μs = 20 μs Bits 12:9 = Program resume to suspend interval count = 0001b, interval = (count +1) * 64 μs =2 * 64 μs = 128 μs Bit 8 = RFU = 1b Bits 7:4 = Prohibited operations during erase suspend = xxx0b: May not initiate a new erase anywhere (erase nesting not permitted) + xx1xb: May not initiate a page program in the erase suspended sector size + x1xxb: May not initiate a read in the erase suspended sector size + 1xxxb: The erase and program restrictions in bits 5:4 are sufficient = 1110b Bits 3:0 = Prohibited Operations During Program Suspend = xxx1b: May not initiate a new erase in the program suspended page size + xx0xb: May not initiate a new page program anywhere (program nesting not permitted) + x1xxb: May not initiate a read in the program suspended page size + 1xxxb: The erase and program restrictions in bits 1:0 are sufficient = 1101b Binary Fields: 0-01-10011-0001-01-10011-0001-1-1110-1101 Nibble Format: 0011_0011_0001_0110_0110_0011_1110_1101 Hex Format: 33_16_63_ED 14h 57h A5h/A3h 58h 59h 5Ah EDh 63h 16h 5Bh JEDEC Basic Flash Parameter Dword-12 http://www.hgsemi.com.cn 33h 13 2018 JUN HG25Q40 SFDP Parameter Relative Byte Address 5Ch 5Dh 5Eh 5Fh 60h 61h 62h 63h Table 5.4 Basic SPI Flash Parameter, JEDEC SFDP Rev B (Sheet 4 of 5) SFDP Dword Name JEDEC Basic Flash Parameter Dword-13 JEDEC Basic Flash Parameter Dword-14 7Ah 75h 7Ah 75h F7h A2h D5h 5Ch 19h F6h DDh 64h 65h 66h 67h Data JEDEC Basic Flash Parameter Dword-15 http://www.hgsemi.com.cn FFh Description Bits 31:24 = Erase Suspend Instruction = 75h Bits 23:16 = Erase Resume Instruction = 7Ah Bits 15:8 = Program Suspend Instruction = 75h Bits 7:0 = Program Resume Instruction = 7Ah Bit 31 = Deep Power-Down Supported = 0 Bits 30:23 = Enter Deep Power-Down Instruction = B9h Bits 22:15 = Exit Deep Power-Down Instruction = ABh Bits 14:13 = Exit Deep Power-Down to next operation delay units = (00b: 128 ns, 01b: 1 μs, 10b: 8 μs, 11b: 64 μs) = 1 μs = 01b Bits 12:8 = Exit Deep Power-Down to next operation delay count = 00010b, Exit Deep Power-Down to next operation delay = (count+1)*units = 3*1 μs=3 μs Bits 7:4 = RFU = 1111b Bit 3:2 = Status Register Polling Device Busy = 01b: Legacy status polling supported = Use legacy polling by reading the Status Register with 05h instruction and checking WIP bit[0] (0=ready; 1=busy). Bits 1:0 = RFU = 11b Binary Fields: 0-10111001-10101011-01-00010-1111-01-11 Nibble Format: 0101_1100_1101_0101_1010_0010_1111_0111 Hex Format: 5C_D5_A2_F7 Bits 31:24 = RFU = FFh Bit 23 = Hold and WP Disable = set QE(bit 1 of SR2) high = 1b Bits 22:20 = Quad Enable Requirements = 101b: QE is bit 1 of the status register 2. Status register 1 is read using Read Status instruction 05h. Status register 2 is read using instruction 35h. QE is set via Write Status instruction 01h with two data bytes where bit 1 of the second byte is one. It is cleared via Write Status with two data bytes where bit 1 of the second byte is zero. Bits 19:16 0-4-4 Mode Entry Method = xxx1b: Mode Bits[7:0] = A5h Note: QE must be set prior to using this mode + x1xxb: Mode Bits[7:0] = Axh + 1xxxb: RFU = 1101b Bits 15:10 0-4-4 Mode Exit Method = xx_xxx1b: Mode Bits[7:0] = 00h will terminate this mode at the end of the current read operation + xx_1xxxb: Input Fh (mode bit reset) on DQ0-DQ3 for 8 clocks. This will terminate the mode prior to the next read operation. + 11_x1xx: RFU = 111101b Bit 9 = 0-4-4 mode supported = 1 Bits 8:4 = 4-4-4 mode enable sequences = 0_0001b: set QE per QER description above, then issue instruction 38h Bits 3:0 = 4-4-4 mode disable sequences = xxx1b: issue FFh instruction + 1xxxb: issue the Soft Reset 66/99 sequence = 1001b Binary Fields: 11111111-1-101-1101-111101-1-00001-1001 Nibble Format: 1111_1111-1101-1101-1111_0110_0001-1001 Hex Format: FF_DD_F6_19 14 2018 JUN HG25Q40 SFDP Parameter Relative Byte Address 68h 69h 6Ah 6Bh Table 5.4 Basic SPI Flash Parameter, JEDEC SFDP Rev B (Sheet 5 of 5) SFDP Dword Name JEDEC Basic Flash Parameter Dword-16 http://www.hgsemi.com.cn Data Description E8h 30h C0h Bits 31:24 = Enter 4-Byte Addressing = xxxx_xxx1b:issue instruction B7 (preceding write enable not required + xx1x_xxxxb: Supports dedicated 4-byte address instruction set. Consult vendor data sheet for the instruction set definition or look for 4-byte Address Parameter Table. + 1xxx_xxxxb: Reserved = 10000000b not supported Bits 23:14 = Exit 4-byte Addressing = xx_xxxx_xxx1b:issue instruction E9h to exit 4-byte address mode (Write enable instruction 06h is not required) + xx_xx1x_xxxxb: Hardware reset + xx_x1xx_xxxxb: Software reset (see bits 13:8 in this DWORD) + xx_1xxx_xxxxb: Power cycle + x1_xxxx_xxxxb: Reserved + 1x_xxxx_xxxxb: Reserved = 11_0000_0000b not supported Bits 13:8 = Soft Reset and Rescue Sequence Support = x1_xxxxb: issue reset enable instruction 66h, then issue reset instruction 99h. The reset enable, reset sequence may be issued on 1,2, or 4 wires depending on the device operating mode + 1x_xxxxb: exit 0-4-4 mode is required prior to other reset sequences above if the device may be operating in this mode. = 11_0000b Bit 7 = RFU = 1 Bits 6:0 = Volatile or Non-Volatile Register and Write Enable Instruction for Status Register 1 = xxx_1xxxb: Non-Volatile/Volatile status register 1 powers-up to last written value in the nonvolatile status register, use instruction 06h to enable write to non-volatile status register. Volatile status register may be activated after power-up to override the non-volatile status register, use instruction 50h to enable write and activate the volatile status register. + x1x_xxxxb: Reserved + 1xx_xxxxb: Reserved = 1101000b Binary Fields: 10000000-1100000000-110000-1-1101000 Nibble Format: 1000_0000_1100_0000_0011_0000_1110_1000 Hex Format: 80_C0_30_E8 80h 15 2018 JUN HG25Q40 FUNCTION DESCRIPTION SPI Operations SPI Modes The HG25Q40/20 can be driven by an embedded microcontroller (bus master) in either of the two following clocking modes. Mode 0 with Clock Polarity (CPOL) = 0 and, Clock Phase (CPHA) = 0 Mode 3 with CPOL = 1 and, CPHA = 1 For these two modes, input data is always latched in on the rising edge of the CLK signal and the output data is always available on the falling edge of the CLK clock signal. The difference between the two modes is the clock polarity when the bus master is in standby mode and not transferring any data. CLK will stay at logic low state with CPOL = 0, CPHA = 0 CLK will stay at logic high state with CPOL = 1, CPHA = 1 Figure 6.1 SPI Modes Timing diagrams throughout the rest of the document are generally shown as both mode 0 and 3 by showing CLK as both high and low at the fall of CS#. In some cases a timing diagram may show only mode 0 with CLK low at the fall of CS#. In such case, mode 3 timing simply means clock is high at the fall of CS# so no CLK rising edge set up or hold time to the falling edge of CS# is needed for mode 3. CLK cycles are measured (counted) from one falling edge of CLK to the next falling edge of CLK. In mode 0 the beginning of the first CLK cycle in a command is measured from the falling edge of CS# to the first falling edge of CLK because CLK is already low at the beginning of a command. Dual SPI Modes The HG25Q 40/20 supports Dual SPI Operation when using the Fast Read Dual Output (3Bh) and Fast Dual I/O (BBh) instruction. These features allow data to be transferred from the device at twice the rate possible with the standard SPI. These instructions are ideal for quickly downloading code to RAM upon Power-up (code-shadowing) or for executing non-speed-critical code directly from the SPI bus (XIP). When using Dual SPI commands, the DI and DO pins become bidirectional I/O pins: IO0 and IO1. Quad SPI Modes The HG25Q40/20 supports Quad SPI operation when using the Fast Read Quad Output (6Bh), Fast Read Quad I/O (EBh) instruction, Word Read Quad I/O(E7h), and Octal Word Read Quad I/O(E3h). These instructions allow data to be transferred to or from the device four times the rate of ordinary Serial Flash. The Quad Read instructions offer a significant improvement in continuous and random access transfer rates http://www.hgsemi.com.cn 16 2018 JUN HG25Q40 allowing fast code-shadowing to RAM or execution directly from the SPI bus (XIP). When using Quad SPI instructions, the DI and DO pins become bidirectional IO0 and IO1, and the WP# and HOLD# / RESET# pins become IO2 and IO3 respectively. Quad SPI instructions require the non-volatile Quad Enable bit (QE) in Status Register-2 to be set. Hold Function For Standard SPI and Dual SPI operations, the HOLD# / RESET# (IO3) signal allows the device interface operation to be paused while it is actively selected (when CS# is low). The Hold function may be useful in cases where the SPI data and clock signals are shared with other devices. For example, if the page buffer is only partially written when a priority interrupt requires use of the SPI bus, the Hold function can save the state of the interface and the data in the buffer so programming command can resume where it left off once the bus is available again. The Hold function is only available for standard SPI and Dual SPI operation, not during Quad SPI. To initiate a Hold condition, the device must be selected with CS# low. A Hold condition will activate on the falling edge of the HOLD# signal if the CLK signal is already low. If the CLK is not already low the Hold condition will activate after the next falling edge of CLK. The Hold condition will terminate on the rising edge of the HOLD# signal if the CLK signal is already low. If the CLK is not already low the Hold condition will terminate after the next falling edge of CLK. During a Hold condition, the Serial Data Output, (DO) or IO0 and IO1, are high impedance and Serial Data Input, (DI) or IO0 and IO1, and Serial Clock (CLK) are ignored. The Chip Select (CS#) signal should be kept active (low) for the full duration of the Hold operation to avoid resetting the internal logic state of the device. Software Reset & Hardware RESET# pin The HG25Q40/20 can be reset to the initial power-on state by a software Reset sequence, either in SPI mode. This sequence must include two consecutive commands: Enable Reset (66h) & Reset (99h). If the command sequence is successfully accepted, the device will take approximately 10us (tRST) to reset. No command will be accepted during the reset period. HG25Q40/20 can also be configured to utilize a hardware RESET# pin. The HRSW bit in the Status Register-3 is the configuration bit for HOLD# pin function or RESET# pin function. When HRSW=0 (factory default), the pin acts as a HOLD# pin as described above; when HRSW =1, the pin acts as a RESET# pin. Drive the RESET# pin low for a minimum period of ~1us (tRESET*) will reset the device to its initial power-on state. Any on-going Program/Erase operation will be interrupted and data corruption may happen. While RESET# is low, the device will not accept any command input. If QE bit is set to 1, the HOLD# or RESET# function will be disabled, the pin will become one of the four data I/O pins. Hardware RESET# pin has the highest priority among all the input signals. Drive RESET# low for a minimum period of ~1us (tRESET*) will interrupt any on-going external/internal operations, regardless the status of other SPI signals (CS#, CLK, DI, DO, WP# and/or HOLD#). Note: 1. While a faster RESET# pulse (as short as a few hundred nanoseconds) will often reset the device, a 1us minimum is recommended to ensure reliable operation. Status Register The Read and Write Status Registers commands can be used to provide status and control of the flash memory device. Status Register-1 (SR1) and Status Register-2 (SR2) can be used to provide status on the availability of the flash memory array, whether the device is write enabled or disabled, the state of write protection, Quad SPI setting, Security Register lock status, and Erase / Program Suspend status. SR1 and SR2 contain non-volatile bits in locations SR1[7:2] and SR2[6:0] that control sector protection, OTP Register Protection, Status Register Protection, and Quad mode. Bits located in SR2[7], SR1[1], and http://www.hgsemi.com.cn 17 2018 JUN HG25Q40 SR1[0] are read only volatile bits for suspend, write enable, and busy status. These are updated by the memory control logic. The SR1[1] write enable bit is set only by the Write Enable (06h) command and cleared by the memory control logic when an embedded operation is completed. Write access to the non-volatile Status Register bits is controlled by the state of the non-volatile Status Register Protect bits SR1[7] and SR2[0] (SRP0, SRP1), the Write Enable command (06h) preceding a Write Status Registers command, and while Quad mode is not enabled, the WP# pin. A volatile version of bits SR2[6], SR2[1], and SR1[7:2] that control sector protection and Quad Mode is used to control the behavior of these features after power up. During power up or software reset, these volatile bits are loaded from the non-volatile version of the Status Register bits. The Write Enable for Volatile Status Register (50h) command can be used to write these volatile bits when the command is followed by a Write Status Registers (01h/31h) command. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. Write access to the volatile SR1 and SR2 Status Register bits is controlled by the state of the non-volatile Status Register Protect bits SR1[7] and SR2[0] (SRP0, SRP1), the Write Enable for Volatile Status Register command (50h) preceding a Write Status Registers command, and the WP# pin while Quad mode is not enabled. Status Register-3 (SR3) is used to configure and provide status on the variable HOLD# or RESET# function, Output Driver Strength, High Frequency Enable Bit and read latency. Write access to the volatile SR3 Status Register bits is controlled by Write Enable for Volatile Status Register command (50h) preceding a Write Status Register command. The SRP bits do not protect SR3. http://www.hgsemi.com.cn 18 2018 JUN HG25Q40 Table 6.1 Status Register-1 (SR1) Bits Default State Field Function Type 7 SRP0 Status Register Protect 0 6 SEC Sector / Block Protect 5 TB Top / Bottom protect 4 3 2 BP2 BP1 BP0 Block Protect Bits 1 WEL Write Enable Latch Volatile, Read only 0 0 = Not Write Enabled, no embedded operation can start 1 = Write Enabled, embedded operation can start 0 BUSY Embedded Operation Status Volatile, Read only 0 0 = Not Busy, no embedded operation in progress 1 = Busy, embedded operation in progress Non-volatile and Volatile versions Description 0 0 = WP# input has no effect or Power Supply Lock Down mode 1 = WP# input can protect the Status Register or OTP Lock Down. 0 0 = BP2-BP0 protect 64-kB blocks 1 = BP2-BP0 protect 4-kB sectors 0 0 = BP2-BP0 protect from the Top down 1 = BP2-BP0 protect from the Bottom up 0 0 0 000b = No protection Table 6.2 Status Register-2 (SR2) Bits Field Function Type Default State 7 SUS Suspend Status Volatile, Read Only 0 0 = Erase / Program not suspended 1 = Erase / Program suspended 6 CMP Complement Protect Non-volatile and Volatile versions 0 0 = Normal Protection Map 1 = Complementary Protection Map 5 LB3 0 Security Register Lock Bits 4 LB2 3 LB1 0 2 Reserve 0 1 QE 0 OTP Quad Enable SRP1 Status Register Protect 1 http://www.hgsemi.com.cn 19 OTP Lock Bits 3:0 for Security Registers 3:0 0 = Security Register not protected 1 = Security Register protected 0 0 = Quad Mode Not Enabled, the WP# pin and HOLD# / RESET# are enabled 1 = Quad Mode Enabled, the IO2 and IO3 pins are enabled, and WP# and HOLD# / RESET# functions are disabled 0 0 = SRP1 selects whether WP# input has effect on protection of the status register 1 = SRP1 selects Power Supply Lock Down or OTP Lock Down mode Non-volatile and Volatile versions 0 Description 2018 JUN HG25Q40 Bits Field 7 HRSW(1) 6 DRV1(1) Function HOLD# or RESET# function DRV0(1) 4 HFM Type Non-volatile and Volatile versions Default State 0 The DRV1 & DRV0 bits are used to determine the output driver strength for the Read operations. Volatile 0 High Frequency Mode Enable Bit Non-volatile and Volatile versions 0 3 2 Description When HRSW=0, the pin acts as HOLD#; when HRSW=1, the pin acts as RESET#. HRSW functions are only available when QE=0. 0 Output Driver Strength 5 Table 6.3 Status Register-3 (SR3) 0 =High Frequency Mode Disabled 1 =High Frequency Mode Enabled 0 0 Reserve 1 0 0 0 Note: 1.Default state for these three bits could be modified. please contact sales. BUSY BUSY is a read only bit in the status register (SR1[0]) which is set to a “1” state when the device is executing a Page Program, Sector Erase, Block Erase, Chip Erase or Write Status Register instruction. During this time the device will ignore further instructions except for the Read Status Register instruction (see tW, tPP, tSE, tBE, and tCE in AC Characteristics). When the program, erase or write status register instruction has completed, the BUSY bit will be cleared to a “0” state indicating the device is ready for further instructions. Write Enable Latch (WEL) Write Enable Latch (WEL) is a read only bit in the status register (SR1[1]) which is set to a 1 after executing a Write Enable Instruction. The WEL status bit is cleared to a 0 when the device is written disabled. A write disable state occurs upon power-up or after any of the following instructions: Write Disable, Page Program, Sector Erase, Block Erase, Chip Erase and Write Status Register. Block Protect Bits (BP2, BP1, BP0) The Block Protect Bits (BP2, BP1, BP0) are non-volatile read / write bits in the Status Register (SR1[4:2]) that provide Write Protection control and status. Block Protect bits can be set using the Write Status Registers Command (see tW in Section 8.5). All, none or a portion of the memory array can be protected from Program and Erase commands (see Section 6.4.2, Block Protection Maps). The factory default setting for the Block Protection Bits is 0 (none of the array is protected.) Top / Bottom Block Protect (TB) The non-volatile Top / Bottom bit (TB SR1[5]) controls whether the Block Protect Bits (BP2, BP1, BP0) protect from the Top (TB=0) or the Bottom (TB=1) of the array as shown in Section 6.4.2, Block Protection Maps. The factory default setting is TB=0. The TB bit can be set with the Write Status Registers Command depending on the state of the SRP0, SRP1 and WEL bits. Sector / Block Protect (SEC) The non-volatile Sector / Block Protect bit (SEC SR1[6]) controls if the Block Protect Bits (BP2, BP1, BP0) protect either 4-kB Sectors (SEC=1) or 64-kB Blocks (SEC=0) of the array as shown in Section 6.4.2, Block http://www.hgsemi.com.cn 20 2018 JUN HG25Q40 Protection Maps. The default setting is SEC=0. Complement Protect (CMP) The Complement Protect bit (CMP SR2[6]) is a non-volatile read / write bit in the Status Register (SR2[6]). It is used in conjunction with SEC, TB, BP2, BP1 and BP0 bits to provide more flexibility for the array protection. Once CMP is set to 1, previous array protection set by SEC, TB, BP2, BP1 and BP0 will be reversed. For instance, when CMP=0, a top 4-kB sector can be protected while the rest of the array is not; when CMP=1, the top 4-kB sector will become unprotected while the rest of the array become read-only. Refer to Section 6.4.2, Block Protection Maps for details. The default setting is CMP=0. The Status Register Protect (SRP1, SRP0) The Status Register Protect bits (SRP1 and SRP0) are non-volatile read / write bits in the Status Register (SR2[0] and SR1[7]). The SRP bits control the method of write protection: software protection, hardware protection, power supply lock-down, or one time programmable (OTP) protection. SRP1 SRP0 WP# Table 6.4 Status Register Protect Status Register Description 0 0 X Software Protection WP# pin has no control. SR1 and SR2 can be written to after a Write Enable command, WEL=1. [Factory Default] 0 1 0 Hardware Protected When WP# pin is low the SR1 and SR2 are locked and cannot be written. 0 1 1 Hardware Unprotected When WP# pin is high SR1 and SR2 are unlocked and can be written to after a Write Enable command, WEL=1. 1 0 X Power Supply Lock Down SR1 and SR2 are protected and cannot be written to again until the next power-down, power-up cycle. (1) 1 1 X One Time Program (2) SR1 and SR2 are permanently protected and cannot be written. Notes: 1. When SRP1, SRP0 = (1, 0), a power-down, power-up, or Software Reset cycle will change SRP1, SRP0 to (0, 0) state. 2. The One-Time Program feature is available upon special order. Contact Zbit for details. 3. Busy, WEL, and SUS (SR1[1:0] and SR2[7]) are volatile read only status bits that are never affected by the Write Status Registers command. 4. The non-volatile version of HRSW, HFM, CMP, QE, SRP1, SRP0, SEC, TB, and BP2-BP0 (SR3[7,4], SR2[6,1,0] and SR1[6:2]) bits and the OTP LB3-LB1 bits are not writable when protected by the SRP bits and WP# as shown in the table. The non-volatile version of these Status Register bits is selected for writing when the Write Enable (06h) command precedes the Write Status Registers (01h) command. 5. The volatile version of HRSW, DRV1, DRV0, HFM, CMP, QE, SRP1, SRP0, SEC, TB, and BP2-BP0 (SR3[7:4], SR2[6,1,0] and SR1[6:2]) bits are not writable when protected by the SRP bits and WP# as shown in the table. The volatile version of these Status Register bits is selected for writing when the Write Enable for volatile Status Register (50h) command precedes the Write Status Registers (01h) command. There is no volatile version of the LB3-LB1 bits and these bits are not affected by a volatile Write Status Registers command. Erase / Program Suspend Status (SUS) The Suspend Status bit is a read only bit in the status register (SR2[7]) that is set to 1 after executing an Erase / Program Suspend (75h) command. The SUS status bit is cleared to 0 by Erase / Program Resume (7Ah) command as well as a power-down, power-up cycle. Security Register Lock Bits (LB3, LB2, LB1) The Security Register Lock Bits (LB3, LB2, LB1) are non-volatile One Time Program (OTP) bits in Status Register (SR2[5:2]) that provide the write protect control and status to the Security Registers. The default state of LB[3:1] is 0, Security Registers 1 to 3 are unlocked. LB[3:1] can be set to 1 individually using the Write Status Registers command. LB[3:1] are One Time Programmable (OTP), once it’s set to 1, the corresponding 256-byte Security Register will become read-only permanently. Quad Enable (QE) The Quad Enable (QE) bit is a non-volatile read / write bit in the Status Register (SR2[1]) that allows http://www.hgsemi.com.cn 21 2018 JUN HG25Q40 Quad SPI operation. When the QE bit is set to a 0 state (factory default), the WP# pin and HOLD# / RESET# are enabled. When the QE bit is set to a 1, the Quad IO2 and IO3 pins are enabled, and WP# and HOLD# / RESET# functions are disabled. Note: If the WP# or HOLD# / RESET# pins are tied directly to the power supply or ground during standard SPI or Dual SPI operation, the QE bit should never be set to a 1. HOLD# or RESET# Pin Function (HRSW) The HRSW bit is used to determine whether HOLD# or RESET# function should be implemented on the hardware pin for 8-pin packages. When HRSW=0, the pin acts as #HOLD; when HRSW=1, the pin acts as RESET#. However, HOLD# or RESET# functions are only available when QE=0. If QE is set to 1, the HOLD# and RESET# functions are disabled, the pin acts as a dedicated data I/O pin. Output Driver Strength (DRV1, DRV0) The DRV1 & DRV0 bits are used to determine the output driver strength for the Read operations. DRV1, DRV0 0, 0 0, 1 1, 0 1, 1 Driver Strength 50% 25% 75%(default) 100% High Frequency Mode Enable Bit (HFM) The HFM bit is used to determine whether the device is in High Frequency Mode. When HFM bit sets to 1, it means the device is in High Frequency Mode, when HFM bit sets 0 (default), it means the device is not in High Frequency Mode. After the HFM is executed, the device will maintain a slightly higher standby current (ICC8) than standard SPI operation. http://www.hgsemi.com.cn 22 2018 JUN HG25Q40 Write Protection Applications that use non-volatile memory must take into consideration the possibility of noise and other adverse system conditions that may compromise data integrity. To address this concern the HG25Q40/20 provides the following data protection mechanisms: Write Protect Features  Device resets when VCC is below threshold  Time delay write disable after Power-Up  Write enable / disable commands and automatic write disable after erase or program  Command length protection - All commands that Write, Program or Erase must complete on a byte boundary (CS# driven high after a full 8 bits have been clocked) otherwise the command will be ignored.  Software and Hardware write protection using Status Register control - WP# input protection - Lock Down write protection until next power-up or Software Reset - One-Time Program (OTP) write protection  Write Protection using the Deep Power-Down command Upon power-up or at power-down, the HG25Q40/20 will maintain a reset condition while VCC is below the threshold value of VWI, (see Figure 8.1). While reset, all operations are disabled and no commands are recognized. During power-up and after the VCC voltage exceeds VWI, all program and erase related commands are further disabled for a time delay of tPUW. This includes the Write Enable, Page Program, Sector Erase, Block Erase, Chip Erase and the Write Status Registers commands. Note that the chip select pin (CS#) must track the VCC supply level at power-up until the VCC-min level and tVSL time delay is reached. If needed a pull-up resistor on CS# can be used to accomplish this. After power-up the device is automatically placed in a write-disabled state with the Status Register Write Enable Latch (WEL) set to a 0. A Write Enable command must be issued before a Page Program, Sector Erase, Block Erase, Chip Erase or Write Status Registers command will be accepted. After completing a program, erase or write command the Write Enable Latch (WEL) is automatically cleared to a write-disabled state of 0. Software controlled main flash array write protection is facilitated using the Write Status Registers command to write the Status Register (SR1,SR2) and Block Protect (SEC, TB, BP2, BP1 and BP0) bits. The BP method allows a portion as small as 4-kB sector or the entire memory array to be configured as read only. Used in conjunction with the Write Protect (WP#) pin, changes to the Status Register can be enabled or disabled under hardware control. See the Table 6.4 for further information. Additionally, the Deep Power-Down (DPD) command offers an alternative means of data protection as all commands are ignored during the DPD state, except for the Release from Deep-Power-Down (RES ABh) command. Thus, preventing any program or erase during the DPD state. http://www.hgsemi.com.cn 23 2018 JUN HG25Q40 Block Protection Maps Table 6.6 HG25Q40 Block Protection (CMP = 0) Status Register (1) HG25Q40(4 Mbit) Block Protection (CMP=0) (2) Protected Protected Block(s) Protected Addresses Density Protected Portion SEC TB BP2 BP1 BP0 X X 0 0 0 None None None None 0 0 0 0 1 7 070000h – 07FFFFh 64 kB Upper 1/8 0 0 0 1 0 6 and 7 060000h – 07FFFFh 128 kB Upper 1/4 0 0 0 1 1 4 thru 7 040000h – 07FFFFh 256 kB Upper 1/2 0 1 0 0 1 0 000000h – 00FFFFh 64 kB Lower 1/8 0 1 0 1 0 0 and 1 000000h – 01FFFFh 128 kB Lower 1/4 0 1 0 1 1 0 thru 3 000000h – 03FFFFh 256 kB Lower 1/2 0 X 1 X X 0 thru 7 000000h – 07FFFFh 512 kB All 1 0 0 0 1 7 07F000h – 07FFFFh 4 kB Upper 1/128 1 0 0 1 0 7 07E000h – 07FFFFh 8 kB Upper 1/64 1 0 0 1 1 7 07C000h – 07FFFFh 16 kB Upper 1/32 1 0 1 0 X 7 078000h – 07FFFFh 32 kB Upper 1/16 1 0 1 1 0 7 078000h – 07FFFFh 32 kB Upper 1/16 1 1 0 0 1 0 000000h – 000FFFh 4 kB Lower 1/128 1 1 0 1 0 0 000000h – 001FFFh 8 kB Lower 1/64 1 1 0 1 1 0 000000h – 003FFFh 16 kB Lower 1/32 1 1 1 0 X 0 000000h – 007FFFh 32 kB Lower 1/16 1 1 1 1 0 0 000000h – 007FFFh 32 kB Lower 1/16 1 X 1 1 1 0 thru 7 000000h – 07FFFFh 512 kB All Notes: 1. X = don’t care. 2. If any Erase or Program command specifies a memory region that contains protected data portion, this command will be ignored. http://www.hgsemi.com.cn 24 2018 JUN HG25Q40 Status Register (1) Table 6.7 HG25Q40 Block Protection (CMP = 1) HG25Q40(4 Mbit) Block Protection (CMP=1) (2) Protected Protected Block(s) Protected Addresses Density Protected Portion SEC TB BP2 BP1 BP0 X X 0 0 0 0 thru 7 000000h – 007FFFh 512 kB All 0 0 0 0 1 0 thru 6 000000h – 06FFFFh 448 kB Lower 7/8 0 0 0 1 0 0 thru 5 000000h – 05FFFFh 384 kB Lower 3/4 0 0 0 1 1 0 thru 3 000000h – 03FFFFh 256 kB Lower 1/2 0 1 0 0 1 1 thru 7 010000h – 07FFFFh 448 kB Upper 7/8 0 1 0 1 0 2 thru 7 020000h – 07FFFFh 384 kB Upper 3/4 0 1 0 1 1 4 thru 7 040000h – 07FFFFh 256 kB Upper 1/2 0 X 1 X X None None None None 1 0 0 0 1 0 thru 7 000000h – 07EFFFh 508 kB 1 0 0 1 0 0 thru 7 000000h – 07DFFFh 504 kB 1 0 0 1 1 0 thru 7 000000h – 07BFFFh 496 kB 1 0 1 0 X 0 thru 7 000000h – 077FFFh 480 kB 1 0 1 1 0 0 thru 7 000000h – 077FFFh 480 kB 1 1 0 0 1 0 thru 7 001000h – 07FFFFh 4 kB 1 1 0 1 0 0 thru 7 002000h – 07FFFFh 8 kB 1 1 0 1 1 0 thru 7 004000h – 07FFFFh 16 kB 1 1 1 0 X 0 thru 7 008000h – 07FFFFh 32 kB 1 1 1 1 0 0 thru 7 008000h – 07FFFFh 32 kB 1 X 1 1 1 None None None Lower 127/128 Lower 63/64 Lower 31/32 Lower 15/16 Lower 15/16 Upper 127/128 Upper 63/64 Upper 31/32 Upper 15/16 Upper 15/16 None Notes: 1. X = don’t care. 2. If any Erase or Program command specifies a memory region that contains protected data portion, this command will be ignored. http://www.hgsemi.com.cn 25 2018 JUN HG25Q40 Page Program To program one data byte, two instructions are required: Write Enable (WREN), which is one byte, and a Page Program (PP) sequence, which consists of four bytes plus data. This is followed by the internal Program cycle (of duration tPP). To spread this overhead, the Page Program (PP) instruction allows up to 256 bytes to be programmed at a time (changing bits from 1 to 0), provided that they lie in consecutive addresses on the same page of memory. Sector Erase, Block Erase and Chip Erase The Page Program (PP) instruction allows bits to be reset from 1 to 0. Before this can be applied, the bytes of memory need to be erased to all 1s (FFh). This can be achieved a sector at a time, using the Sector Erase (SE) instruction, a block at a time using the Block Erase (BE) instruction or throughout the entire memory, using the Chip Erase (CE) instruction. This starts an internal Erase cycle (of duration tSE tBE or tCE). The Erase instruction must be preceded by a Write Enable (WREN) instruction. Polling during a Write, Program or Erase Cycle A further improvement in the time to Write Status Register (WRSR), Program (PP) or Erase (SE, BE or CE) can be achieved by not waiting for the worst case delay (tW, tPP, tSE, tBE or tCE). The Write In Progress (WIP) bit is provided in the Status Register so that the application program can monitor its value, polling it to establish when the previous Write cycle, Program cycle or Erase cycle is complete. Active Power, Stand-by Power and Deep Power-Down Modes When Chip Select (CS#) is Low, the device is enabled, and in the Active Power mode. When Chip Select (CS#) is High, the device is disabled, but could remain in the Active Power mode until all internal cycles have completed (Program, Erase, Write Status Register). The device then goes into the Standby Power mode. The device consumption drops to ICC1. The Deep Power-down mode is entered when the specific instruction (the Enter Deep Power-down Mode (DP) instruction) is executed. The device consumption drops further to ICC2. The device remains in this mode until another specific instruction (the Release from Deep Power-down Mode and Read Device ID (RDI) instruction) is executed. All other instructions are ignored while the device is in the Deep Power-down mode. This can be used as an extra software protection mechanism, when the device is not in active use, to protect the device from inadvertent Program or Erase instructions. http://www.hgsemi.com.cn 26 2018 JUN HG25Q40 INSTRUCTIONS The instruction set of the HG25Q40/20 consists of forty basic instructions that are fully controlled through the SPI bus. Instructions are initiated with the falling edge of Chip Select (CS#). The first byte of data clocked into the DI input provides the instruction code. Data on the DI input is sampled on the rising edge of clock with most significant bit (MSB) first. Instructions vary in length from a single byte to several bytes and may be followed by address bytes, data bytes, dummy bytes (don’t care), and in some cases, a combination. Instructions are completed with the rising edge of edge CS#. Clock relative timing diagrams for each instruction are included in figures 7.1 through 7.43. All read instructions can be completed after any clocked bit. However, all instructions that Write, Program or Erase must complete on a byte boundary (CS driven high after a full 8-bits have been clocked) otherwise the instruction will be ignored. This feature further protects the device from inadvertent writes. Additionally, while the memory is being programmed or erased, or when the Status Register is being written, all instructions except for Read Status Register and Erase/Program Suspend will be ignored until the program or erase cycle completes. http://www.hgsemi.com.cn 27 2018 JUN HG25Q40 Table 7.1 Command Set (Configuration, Status, Erase, Program Instructions (1), SPI Mode) Command Name BYTE 1 (Instruction) BYTE 2 Read Status Register-1 05h SR1[7:0](2) Read Status Register-2 35h SR2[7:0](2) Read Status Register-3 15h/33h SR3[7:0](2) BYTE 3 BYTE 4 BYTE 5 Write Enable 06h Write Enable for Volatile Status Register 50h Write Disable 04h Write Status Registers-1 01h SR1[7:0](5) Write Status Registers-2 31h SR2[7:0] Write Status Registers-3 11h SR3[7:0] Set Burst with Wrap 77h xxh xxh xxh W[7:0](3) Page Program 02h A23—A16 A15—A8 A7—A0 D7—D0 Quad Page Program 32h A23—A16 A15—A8 A7—A0 D7—D0(4) Sector Erase (4 KB) 20h A23—A16 A15—A8 A7—A0 Block Erase (32 KB) 52h A23—A16 A15—A8 A7—A0 Block Erase (64 KB) D8h A23—A16 A15—A8 A7—A0 Chip Erase BYTE 6 C7h/60h Erase/Program 75h Suspend Erase/Program Resume 7Ah Enable Reset 66h Reset Device 99h Notes: 1. Data bytes are shifted with Most Significant Bit first. Byte fields with data in parenthesis “()” indicate data being read from the device on the DO pin. 2. Status Register contents will repeat continuously until CS# terminates the command. 3. Set Burst with Wrap Input format. IO0 = x, x, x, x, x, x, W4, x] IO1 = x, x, x, x, x, x, W5, x] IO2 = x, x, x, x, x, x, W6 x] IO3 = x, x, x, x, x, x, x,x 4. Quad Page Program Input Data: IO0 =(D4,D0,...) IO1 = ( D5,D1,...) IO2 = ( D6,D2,...) IO3 =( D7,D3,...) 5. The 01h command could continuously write up to three bytes to registers SR1, SR2, SR3. http://www.hgsemi.com.cn 28 2018 JUN HG25Q40 Table 7.2 Command Set (Read Instructions (1), SPI Mode) Command Name BYTE 1 (Instruction) BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 Read Data 03h A23—A16 A15—A8 A7—A0 (D7—D0,…) Fast Read Fast Read Dual Output Fast Read Quad Output 0Bh A23—A16 A15—A8 A7—A0 dummy (D7—D0,…) 3Bh A23—A16 A15—A8 A7—A0 dummy (D7—D0,…)(1) 6Bh A23—A16 A15—A8 A7—A0 dummy (D7—D0,…)(3) Fast Read Dual I/O BBh A23—A8(2) A7—A0,M7 —M0(2) (D7—D0,…)(1) Fast Read Quad I/O EBh A23—A0,M7 —M0(4) (x,x,x,x,D7— D0,...) (D7—D0,…)(3) QUAD I/O WORD FAST READ(5) E7H A23—A0,M7 —M0(4) (x,x,D7—D0, ...) (D7—D0,…)(3) Octal Word Read Quad I/O(5) E3h A23—A0,M7 —M0(4) (D7—D0,…)( 3) (D7—D0,…)(3) Notes: 1. Dual Output data IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) 2. Dual Input Address IO0 = A22, A20, A18, A16, A14, A12, A10, A8 A6, A4, A2, A0, M6, M4, M2, M0 IO1 = A23, A21, A19, A17, A15, A13, A11, A9 A7, A5, A3, A1, M7, M5, M3, M1 3. Quad Output Data IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3, …..) 4. Quad Input Address IO0 = A20, A16, A12, A8, A4, A0, M4, M0 IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 5. For Word Read Quad I/O, the lowest address bit must be 0. (A0 = 0),and for Octal Word Read Quad I/O, the lowest four address bits must be 0. (A3, A2, A1, A0 = 0) http://www.hgsemi.com.cn 29 2018 JUN HG25Q40 Table 7.3 Command Set (Read ID, OTP Instructions (1), SPI Mode) Command Name BYTE 1 (Instruction) Deep Power-down Release Power down / Device ID Manufacturer/ Device ID(2) Manufacturer/ Device ID by Dual I/O Manufacturer/ Device ID by Quad I/O BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 ABh dummy dummy dummy Device ID(1) 90h dummy dummy 00h Manufacturer Device ID 92h A23—A8 A7—A0,M[7:0] (MF[7:0],ID[7:0]) 94h A23—A0,M[7:0] XXXX,(MF[7:0],ID[7:0]) (MF[7:0],ID[7:0]...) 9Fh Manufacturer Memory Type Capacity 5Ah 00h 00h A7—A0 dummy (D7—D0,…) 48h A23—A16 A15—A8 A7—A0 dummy (D7—D0,…) 44h A23—A16 A15—A8 A7—A0 42h A23—A16 A15—A8 A7—A0 D7—D0,… 4Bh dummy dummy dummy dummy B9h JEDEC ID Read SFDP Register Read Security Registers(3) Erase Security Registers(3) Program Security Registers(3) Read Unique ID (ID63-ID0) Notes: 1. The Device ID will repeat continuously until CS# terminates the command. 2. See Section 6.4.1, Legacy Device Identification Commands on page 51 for Device ID information. The 90h instruction is followed by an address. Address = 0 selects Manufacturer ID as the first returned data as shown in the table. Address = 1 selects Device ID as the first returned data followed by Manufacturer ID. 3. Security Register Address: Security Register 0: A23-16 = 00h; A15-8 = 00h; A7-0 = byte address Security Register 1: A23-16 = 00h; A15-8 = 10h; A7-0 = byte address Security Register 2: A23-16 = 00h; A15-8 = 20h; A7-0 = byte address Security Register 3: A23-16 = 00h; A15-8 = 30h; A7-0 = byte address Table 7.4(1) Manufacturer and Device Identification(HG25Q40 ) OP Code Data1 Data2 Data3 ABh Device ID = 12h - - 90h/92h/94h Manufacturer ID = 5E Device ID = 12h - 9Fh Manufacturer ID = 5E Memory Type =60h Capacity = 13h Notes: (1)Please contact sales for more information Table 7.5(1) Manufacturer and Device Identification(HG25Q 20 ) OP Code Data1 Data2 Data3 ABh Device ID = 11h - - 90h/92h/94h Manufacturer ID = 5E Device ID = 11h - 9Fh Manufacturer ID = 5E Memory Type =60h Capacity = 12h Notes: (1)Please contact sales for more information http://www.hgsemi.com.cn 30 2018 JUN HG25Q40 Configuration and Status Commands Read Status Register (05h/35h/15h) The Read Status Register commands allow the 8-bit Status Registers to be read. The command is entered by driving CS# low and shifting the instruction code “05h” for Status Register-1, “35h” for Status Register-2, “15h” for Status Register-3 into the DI pin on the rising edge of CLK. The Status Register bits are then shifted out on the DO pin at the falling edge of CLK with most significant bit (MSB) first as shown in Figure 7.1. The Status Register bits are shown in Section 6.2, Status Registers. The Read Status Register-1 (05h) command may be used at any time, even during a Program, Erase, or Write Status Registers cycle. This allows the BUSY status bit to be checked to determine when the operation is complete and if the device can accept another command. Figure 7.1 Read Status Register Instruction Write Enable (06h) The Write Enable instruction (Figure 7.2) sets the Write Enable Latch (WEL) bit in the Status Register to a 1. The WEL bit must be set prior to every Page Program, Sector Erase, Block Erase, Chip Erase and Write Status Register instruction. The Write Enable instruction is entered by driving CS# low, shifting the instruction code “06h” into the Data Input (DI) pin on the rising edge of CLK, and then driving CS# high. Figure 7.2 Write Enable Instruction Write Enable for Volatile Status Register (50h) The non-volatile Status Register bits described in section 6.2 can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. To write the volatile values into the Status Register bits, the Write Enable for Volatile Status Register (50h) instruction must be issued prior to a Write Status Register (01h) instruction. Write Enable for Volatile Status Register instruction (Figure 7.3) will not set the Write Enable Latch (WEL)bit, it is only valid for the Write Status Register instruction to change the volatile Status Register bit values. http://www.hgsemi.com.cn 31 2018 JUN HG25Q40 Figure 7.3 Write Enable for Volatile Status Register Instruction Write Disable (04h) The Write Disable instruction (Figure 7.4) resets the Write Enable Latch (WEL) bit in the Status Register to a 0. The Write Disable instruction is entered by driving CS# low, shifting the instruction code “04h” into the DI pin and then driving CS# high. Note that the WEL bit is automatically reset after Power-up and upon completion of the Write Status Register, Page Program, Sector Erase, Block Erase and Chip Erase instructions. Figure 7.4 Write Disable Instruction Write Status Register (01h/31h/11h) The Write Status Registers command allows the Status Registers to be written. Only non-volatile Status Register bits SRP0, SEC, TB, BP2, BP1, BP0 (SR1[7:2]) CMP, LB3, LB2, LB1, QE, SRP1 (SR2[6:0]), and the volatile bits SR3[6:0] can be written. All other Status Register bit locations are read-only and will not be affected by the Write Status Registers command. LB[3:0] are non-volatile OTP bits; once each is set to 1, it cannot be cleared to 0. The Status Register bits are shown in Section 6.2, Status Registers. Any reserved bits should only be written to their default value. To write non-volatile Status Register bits, a standard Write Enable (06h) command must previously have been executed for the device to accept the Write Status Registers Command (Status Register bit WEL must equal 1). Once write enabled, the command is entered by driving CS# low, sending the instruction code “01h”, and then writing the Status Register data bytes as illustrated in Figure 7.5. To write volatile Status Register bits, a Write Enable for Volatile Status Register (50h) command must have been executed prior to the Write Status Registers command (Status Register bit WEL remains 0). However, SRP1 and LB3, LB2, LB1 cannot be changed because of the OTP protection for these bits. Upon power-off, the volatile Status Register bit values will be lost, and the non-volatile Status Register bit values will be restored when power on again. To complete the Write Status Registers command, the CS# pin must be driven high after the eighth bit of a data value is clocked in (CS# must be driven high on an 8-bit boundary). If this is not done the Write Status Registers command will not be executed. The Write Status Register instruction allows the Status Register to be written. A Write Enable instruction must previously have been executed for the device to accept the Write Status Register Instruction (Status Register bit WEL must equal to 1). Once write enabled, the instruction is entered by driving CS# low, sending the instruction code “01h”, and then writing the status register data byte as illustrated in Figure 7.5. During non-volatile Status Register write operation (06h combined with 01h/31h), after CS# is driven high, the self-timed Write Status Register cycle will commence for a time duration of tW (See AC Characteristics). http://www.hgsemi.com.cn 32 2018 JUN HG25Q40 While the Write Status Register cycle is in progress, the Read Status Register instruction may still be accessed to check the status of the BUSY bit. The BUSY bit is a 1 during the Write Status Register cycle and a 0 when the cycle is finished and ready to accept other instructions again. After the Write Status Register cycle has finished, the Write Enable Latch (WEL) bit in the Status Register will be cleared to 0. During volatile Status Register write operation (50h combined with 01h/31h/11h), after CS# is driven high, the Status Register bits will be refreshed to the new values within the time period of tSHSL2 (See AC Characteristics). BUSY bit will remain 0 during the Status Register bit refresh period. If CS# is driven high after the eighth clock, the Write Status Register-1 (01h) instruction will only program the Status Register-1, the Status Register-2 will not be affected. Figure 7.5 Write Status Register Instruction Program and Erase Commands Page Program (PP) (02h) The Page Program instruction allows up to 256 bytes of data to be programmed at previously erased to all 1s (FFh) memory locations. A Write Enable instruction must be executed before the device will accept the Page Program Instruction (Status Register bit WEL must equal 1). The instruction is initiated by driving the CS# pin low then shifting the instruction code “02h” followed by a 24-bit address (A23-A0) and at least one data byte, into the DI pin. The CS# pin must be held low for the entire length of the instruction while data is being sent to the device. The Page Program instruction sequence is shown in Figure 7.6. If an entire 256 byte page is to be programmed, the last address byte (the 8 least significant address bits) should be set to 0. If the last address byte is not zero, and the number of clocks exceeds the remaining page length, the addressing will wrap to the beginning of the page. In some cases, less than 256 bytes (a partial page) can be programmed without having any effect on other bytes within the same page. One condition to perform a partial page program is that the number of clocks cannot exceed the remaining page length. If more than 256 bytes are sent to the device the addressing will wrap to the beginning of the page and overwrite previously sent data. As with the write and erase instructions, the CS# pin must be driven high after the eighth bit of the last byte has been latched. If this is not done the Page Program instruction will not be executed. After CS# is driven high, the self-timed Page Program instruction will commence for a time duration of tpp (See AC Characteristics). While the Page Program cycle is in progress, the Read Status Register instruction may still be accessed for checking the status of the BUSY bit. The BUSY bit is a 1 during the Page Program cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions again. After the Page Program cycle has finished the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. The Page Program instruction will not be executed if the addressed page is protected by the Block Protect (TB, SEC, BP2, BP1, and BP0) bits (see Status Register Memory Protection table). Figure 7.6a Page Program Instruction http://www.hgsemi.com.cn 33 2018 JUN HG25Q40 Quad Input Page Program (32h) The Quad Input Page Program instruction allows up to 256 byte of data to be programmed at previously erased (FFh) memory locations using four pins: IO0, IO1, IO2 and IO3. The Quad Input Page Program can improved performance for PROM Programmer and applications that have slow clock speeds
