SS22-210 SERIES
SCHOTTKY
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
ROHS
FEATURES
Schottky barrier rectifier
Guardring protection
Low forward voltage
Reverse energy tested
High current capability
Extremely low thermal resistance
MECHANICAL DATA
Case: SMB molded plastic body
1111
Polarity: Color band denotes cathode end
Mounting position: ANY
Weight: 0.003 ounces, 0.093 gram
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25oC ambient temperature unless otherwise specified
Device marking code
SS22
SS23 SS24 SS25 SS26
SS28 SS29 S210 UNITS
Maximum repetitive peak reverse voltage
VRRM
40
50
60
80
90
100
V
Maximum RMS voltage
VRWS
14
21
28
35
42
56
63
70
V
Maximum DC blocking voltage
VDC
40
50
60
80
90
100
V
Maximum average forward rectified current at
TL=90
IF(AV)
2.0
A
Peak forward surge current 8.3ms single
half-sine-wave
IFSM
75
A
Maximum instantaneous forward voltage
at I FM=2.0A (NOTE1)
VF
Maximum DC reverse current
TJ=25
at rated DC blocking voltage TJ=125
Maximum thermal resistance
Operating temperature range
Storage temperature range
IR
R
0.75
0.50
0.85
0.4
0.03
10
5.0
28
JL
V
mA
o
C/W
TJ
-55 ---- +125
o
C
TSTG
-55 ---- +150
o
C
NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 %
Rev 8: Nov 2014
www.born-tw.com
Page 1 of 2
SS22-210 SERIES
SCHOTTKY
2.0
FIG.2-- PEAK FORWARD SURGE CURRENT
Resistive or
inductive Load
1.0
P.C.B.MOUNTED ON
0.2X0.2(5.0X5.0mm)
COPPERPAD AREAS
60
70 80
90 100 110 120 130 140 150 160 170
PEAK FORWARD SURGE
CURRENT,AMPERES
CURRENT,AMPERES
FIG.1 -- FORWARD DERATING CURVE
LEAD TEMPERATURE
75
T L =100℃
8.3ms Single Half Sine-Wave
(JED E C M ethod)
60
45
30
15
10
10 0
NUMBER OF CYCLES AT 60Hz
FIG.3 -- TYPICAL FORWARD CHARACTERISTICS
FIG.4 -- TYPICAL REVERSE CHARACTERISTICS
1
SS
25
~S
S2
SS
6
28
~S
S2
10
10
INSTANTANEOUS REVERSE
CURRENT,MICRO AMPERES
100
SS
22~
SS
24
INSTANTANEOUS FORWARD
CURRENT,AMPERES
ROHS
0.1
0.01
Tj=25oC
Pulse Width=300 s
1% Duty Cycle
.2
.3
.4
.5
.6
.7
.8
SS28-SS210
1.0
TJ=125℃
0.1
SS22-SS26
SS28-SS210
0.01
0.001
T J=25℃
SS22-SS26
0.001
60
80
1 00
.9
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
Rev 8: Nov 2014
10
www.born-tw.com
PERCENT OF RATED PEAK REVERSE VOLTAGE,
Page 2 of 2
很抱歉,暂时无法提供与“SS26SMB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.36852
- 200+0.23865
- 1500+0.20646
- 3000+0.18315
- 国内价格
- 10+0.34650
- 100+0.27760
- 600+0.24314
- 1200+0.23949
- 3000+0.19751
- 国内价格
- 10+0.37811
- 100+0.30294
- 300+0.26536
- 3000+0.21557
- 6000+0.19311
- 9000+0.18177
