SD15C
ESD Protection Diode
»Features
320Watts peak pulse power (tp = 8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 10A (8/20μs)
»Applications
»Mechanical Data
Microprocessor based equipment
SOD323 package
Personal Digital Assistants (PDA’s)
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
Portable Instrumentation
RoHS/WEEE Compliant
Pagers Peripherals
»Schematic & PIN Configuration
SOD-323
Revision 2018
www.born-tw.com
1/4
SD15C
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
320
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
10
A
VESD
30
30
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 150
Storage Temperature
Tstg
-55 to + 150
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=15V,T=25℃
Clamping Voltage
VC
Junction Capacitance
Cj
Max
Units
15.0
V
16.7
V
IPP=10A,tp=8/20μs
VR = 0V, f = 1MHz
0.5
uA
32
V
pF
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC VBR VRWM
Breakdown Voltage @ IT
IT
IR
IR
IT
VRWM VBR VC
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
SD15C
»Typical Characteristics
Figure 2: Power Derating Curve
10
110
320w8/20 μs waveform
1
0.1
0.01
0.1
1
10
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Percent
Ipp
80
80
Clamping Voltage–VC (V)
90
e-1
50
40
td=Ipp/
2
100
125
150
90
Waveform
Paramters
tr=8µs
td=20µs
100
30
50
Figure 4: Clamping Voltage vs.Ipp
110
60
25
Ambient Temperature - TA (℃)
Figure3: Pulse Waveform
70
Test
Waveform
Paramters
tr=8µs
td=20µs
70
60
50
40
30
10
15
Time (µs)
30
4
6
8
10
12
Peak Pulse Current–IPP (A)
Revision 2018
www.born-tw.com
3/4
SD15C
»Outline Drawing – SOD323
C
A
DIMENSIONS
SYMBOL
E
B
1
2
MILLIMETER
A
MIN
1.600
MAX
1.800
MIN
0.063
MAX
0.071
B
0.250
0.350
0.010
0.014
C
2.500
2.700
0.098
D
D
H
L
1.000
0.106
0.039
E
1.200
1.400
0.047
0.055
F
0.080
0.150
0.003
0.006
L
F
INCHES
0.475 REF
0.019REF
L1
0.250
0.400
0.010
0.016
H
0.000
0.100
0.000
0.004
L1
»Ordering information
Order code
SD15C
Revision 2018
Package
Base qty
Delivery mode
SOD323
3000
Tape and reel
www.born-tw.com
4/4
很抱歉,暂时无法提供与“SD15C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27200
- 50+0.25160
- 200+0.23460
- 600+0.21760
- 1500+0.20400
- 3000+0.19550
- 国内价格
- 10+0.45015
- 100+0.36202
- 300+0.31796
- 3000+0.25089
- 6000+0.22443
- 9000+0.21114
- 国内价格
- 1+0.39160
- 200+0.25190
- 1500+0.22000
- 3000+0.19360
