B0524P
Transient Voltage Suppressors
ROHS ROHS
Features
Solid-state silicon-avalanche technology
Low operating and clamping voltage
Up to four I/O Lines of Protection
Ultra low capacitance: 0.35pF typical(I/O to I/O)
Low Leakage
Low operating voltage:5V
Flow-Through design
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±15kV (air), ± 8kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 3A (8/20μs)
Mechanical Characteristics
Application
DFN-10L package (2.5×1.0×0.58mm)
Digital Visual Interface(DVI)
Molding compound flammability rating: UL 94V-0
MDDI Ports
Marking: Marking Code
DisplayPortTM Interface
Packaging: Tape and Reel
PCI Express
RoHS/WEEE Compliant
High Definition Multi-Media Interface(HDMI)
eSATA Interfaces
Circuit Diagram
Pin 1
Pin 2
Schematic & PIN Configuration
Pin 4
3,8
4-Line Protection
10
9
8
7
6
1
2
3
4
5
Pin 5
Pin
1,2,4,5
Identificaion
Input Lines
6,7,9,10
Output Lines
(No Internal Connection)
3,8
Ground
1/5
B0524P
ROHS
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
100
Watts
Peak Pulse Current ( tp =8/20μs )
Ipp
5
A
ESD per IEC 61000-4-2(Air)
+/-15
VESD
ESD per IEC 61000-4-2(contact)
Operating Temperature
Storage Temperature
kV
+/-8
TJ
-55 to + 125
°C
TSTG
-55 to +150
°C
Electrical Parameters (T=25℃)
Symbol
I
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRW M
IR
VBR
IF
Working Peak Reverse Voltage
VC VBRVRWM
Maximum Reverse Leakage Current @1.5KExxA(CA)
VRWM
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
V
IR VF
IT
IPP
Electrical Characteristics
Parameter
Symbol
Conditions
Minimum
Typical
Maximum
Units
5.0
V
VRWM
Any I/O pin to ground
VBR
It = 1mA
IR
VRWM = 5V, T=25°C
1
µA
Clamping Voltage
Vc
Ipp=3A, tp=8/20µs
V
VR = 0V, f = 1MHz
I/O pin to GND
0.7
pF
0.5
pF
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Junction Capacitance
Cj
VR = 0V, f = 1MHz
Between I/O pins
6.0
V
0.35
2/5
B0524P
ROHS
Typical Characteristics
Power Derating curve
Non-Repetitive Peak Pulse Power vs. Pulse Time
110
1
% of Rated Power or IPP
Peak Pulse Power - Ppp (KW)
10
100W 8/20µs
Waveform
0.1
100
90
80
70
60
50
40
30
0.1
1
100
10
1000
25
Pulse Duration tp (us)
150
40
Waveform
Parameters:
tr=8us
td=20us
90
80
70
e -t
60
Td=IPP /2
30
5
10
30
Line to Line
25
1.5KExxA(CA)20
50
40
35
Clamping Voltage - Vc(V)
100
Percent of Ipp
125
Clamping Voltage vs.Peak Pulse Current
110
Ambient Temperature - TA ( ℃ )
Pulse Waveform
50
25
15
Waveform
parameters:
tr=8us td=20us
10
5
Line to Gnd
2
3
Time (us)
4
5
6
Peak Pulse Current - Ipp (A)
Insertion Loss S21 - I/O to GND
Normalized Capacitance vs. Reverse Voltage
CH1S21 LOG 6dB / REF 0 dB
1: -0.086 dB
C ( V R ) / CJ ( V R = 0 )
1.5
900 MHz
1.3
1.2
1 2
- 6dB
0.8
0.7
0.6
0.5
2: -0.0336dB
1.8 GHz
- 12dB
3: -0.126dB
2.5GHz
- 18dB
0.4
0.3
0.1
- 24dB
F=1MHz
2
3
Reverse voltage - V R (V)
4
5
- 30dB
- 36dB
- 42dB
- 48dB
1
MHz
10
MHz
STAR .030MHz
100
MHz
1
3
GHz GHz
STOP 3000.000000MHz
3/5
B0524P
ROHS ROHS
Design Recommendations for HDMI protection
Adding external ESD protection to HDMI ports can be challenging. First, ESD protection devices have an inherent junction
capacitance. Furthermore, adding even a small amount of capacitance will cause the impedance of the differential pair to
drop. Second, large packages and land pattern requirements cause discontinuities that adversely affect signal integrity. The
B0524P are specifically designed for protection of high-speed interfaces such as HDMI.
They present
很抱歉,暂时无法提供与“B0524P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.35118
- 100+0.29121
- 600+0.26123
- 1200+0.25731
- 3000+0.19251
