PESD5V0U1BB-N
ESD Protection Diode
»Features
40Watts peak pulse power (tp = 8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=2.7pF typ.)
Protection one data/power line
IEC 61000-4-2 ±10kV contact ±15kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 3.0A (8/20μs)
»Applications
»Mechanical Data
Cell Phone Handsets and Accessories
SOD523 package
Microprocessor based equipment
Molding compound flammability rating: UL 94V-0
Personal Digital Assistants (PDA’s)
Packaging: Tape and Reel
Notebooks, Desktops, and Servers
RoHS/WEEE Compliant
Portable Instrumentation
»Schematic & PIN Configuration
SOD-523
Revision 2018
www.born-tw.com
1/4
PESD5V0U1BB-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
40
Watts
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
3.0
A
VESD
15
10
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
5.5
Max
Units
5.0
V
VBR
IT=1mA
6.5
V
Reverse Leakage Current
IR
VRWM=5V,T=25℃
0.1
μA
Peak Pulse Current
IPP
tp =8/20μs
3.0
A
Clamping Voltage
VC
IPP=3.0A,tp=8/20μs
13
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
3.5
pF
2.7
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC V BR
V RWM
IT
IR
ITIR
VRWM
V BR V C
V
Breakdown Voltage @ IT
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
PESD5V0U1BB-N
»TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
1
40w 8/20μs waveform
0.1
0.01
0.1
1
10
100
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
Percent
Ipp
80
Clamping Voltage–VC (V)
90
e-1
50
40
30
td=Ipp/2
125
150
18
Waveform
Paramters
tr=8µs
td=20µs
100
60
75
Figure 4: Clamping Voltage vs.Ipp
110
70
50
Ambient Temperature - TA (℃)
10
16
14
12
10
8
Test
Waveform
Paramters
tr=8µs
td=20µs
6
4
2
Revision 2018
10
15
Time (µs)
30
2
3
4
5
6
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
PESD5V0U1BB-N
»Outline Drawing – SOD523
D
-X-YE
1
DIMENSIONS
2
SYMBOL
b 2x
0.08 (0.0032)
X
A
b
C
D
E
HE
L
Y
A
C
HE
L
MILLIMETER
INCHES
MIN
MAX
MIN
MAX
0.50
0.25
0.07
1.10
0.70
1.50
0.15
0.70
0.35
0.20
1.30
0.90
1.70
0.25
0.020
0.010
0.0028
0.043
0.028
0.059
0.006
0.028
0.014
0.0079
0.051
0.035
0.067
0.010
»Marking
1
5B
2
»Ordering information
Order code
PESD5V0U1BB-N
Revision 2018
Package
SOD523
Base qty
5000
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“PESD5V0U1BB-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23318
- 200+0.18069
- 600+0.15153
- 5000+0.13155
- 10000+0.11643
- 20000+0.10822
- 国内价格
- 1+0.58575
- 500+0.19305
- 2500+0.12705
- 5000+0.10725
- 国内价格
- 20+0.20054
- 200+0.15667
