BDFN2C031V
Transient Voltage Suppressors
ROHS ROHS
Features
Protects one I/O or Power Line
Completely Compatible with SOD923
Low Clamping Voltage
Working Voltage: 3.3V
Low Leakage Current
Response Time is Typically < 1 ns
DFN-2L
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±25kV (air), ±15kV(contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Mechanical Characteristics
Applications
JEDEC DFN-2Lpackage (0402 size)
Cellular Handsets & Accessories
Molding compound flammability rating:
Personal Digital Assistants (PDAs)
UL 94V-0
Notebooks & Handhelds
Marking : Marking Code
Portable Instrumentation
RoHS Compliant
Digital Cameras
MP3 Players
Schematic & PIN Configuration
Bi irectional
1/4
BDFN2C031V
ROHS ROHS
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp = 8/20μs )
PPP
80
Watts
Peak Forward Voltage ( IF = 1A, tp = 8/20μs )
VFP
1.5
V
Operating Temperature
TJ
-55 to + 125
TSTG
-55 to +150
Storage Temperature
Electrical Parameters (T=25℃)
I
Symbol
Parameter
I PP
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRW M
IR
VBR
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
VC VBR VRWM
IT
IR
IR
IT
Breakdown Voltage @ IT
VRWM VBR VC
1.5KExxA(CA)
IT
Test
T t Current
Curr t
IF
Forward Current
VF
Forward Voltage @ IF
I PP
Electrical Characteristics
BDFN2C031V
Parameter
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
3.3
V
VBR
IT=1mA
3.7
V
IR
VRWM=5V, T=25℃
0.5
μA
Peak Pulse Current
IPP
tp =8/20μs
11
A
Clamping Voltage
VC
IPP=5A, tp=8/20μs
6
V
Clamping Voltage
VC
IPP=11A, tp=8/20μs
8
V
Junction Capacitance
Cj
VR =0V, f =1MHz
pF
18
2/4
V
BDFN2C031V
ROHS ROHS
Typical Characteristics
Figure 2: Power Derating Curve
10
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
1
80w 8/20µs waveform
0.1
0.01
0.1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
125
150
8
Clamping Voltage–VC (V)
90
80
Ipp
100
9
Waveform
Paramters
tr=8µs
td=20µs
100
Percent
75
Figure 4: Clamping Voltage vs.Ipp
110
70
e-1
60
50
Ambient Temperature - TA (℃)
50
40
30
td=Ipp/2
6
5
4
Test
Waveform
Paramters
tr=8µs
td=20µs
3
2
1
10
10
15
Time (µs)
30
4
6
8
10
Peak Pulse Current–IPP (A)
3/4
12
BDFN2C031V
ROHS ROHS
Outline Drawing – DFN-2L
PACKAGE OUTLINE
D
e
h
DFN-2L
1
2
2
L
L1
1
SYMB
OL
A
A1
b
C
D
e
E
L
L1
h
b
E
h
L1
A1
C
A
BOTTOM VIEW
MILIMETER
MIN
NOM
MAX
0.45
0.50
0.55
0.05
0.45
0.50
0.55
0.12
0.15
0.18
0.95
1.00
1.05
0.65BSC
0.55
0.60
0.65
0.20
0.25
0.30
0.05REF
0.07
0.12
0.17
Land Pattern
1.00
0.35
0.60
0.60
0.30
0.35
Marking Codes
Part Number
Marking Code
BDFN2C031V
3E
Package Information
Qty:10k/Reel
4/4
很抱歉,暂时无法提供与“BDFN2C031V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.21520
- 200+0.16850
- 600+0.14280
- 2000+0.12740
- 10000+0.10810
- 20000+0.10090
- 国内价格
- 20+0.19869
- 1000+0.13217
- 4000+0.11791
