山东晶导微电子股份有限公司
SS82C THRU SS820C
Jingdao Microelectronics co.LTD
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200V
Forward Current - 8.0A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS82 ~ SS820
Simplified outline SMC and symbol
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.22g / 0.0077oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS82C
SS84C
SS86C
SS88C
SS810C
SS812C
SS815C
SS820C
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
8.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
150
A
Max Instantaneous Forward Voltage at 8 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance
(1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
VF
0.45
0.55
0.85
1.0
50
IR
Cj
0.70
mA
400
600
V
pF
RθJA
35
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMC-S-SS82C~SS820C-8A200V
Page 1 of 3
山东晶导微电子股份有限公司
SS82C THRU SS820C
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
9.6
8.0
6.4
4.8
3.2
1.6
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
T J =100°C
10 3
10 1
T J =25°C
10 0
Case Temperature (°C)
60
80
100
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1
SS82C
SS84C
SS86C/SS88C
SS810C/SS820C
0.1
1.0
1.5
100
SS82C/SS84C
SS54F/SS520F
SS86C~SS820C
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
175
150
125
100
75
50
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
500
Instaneous Forward Voltage (V)
180
25
1000
2.0
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Peak Forward Surage Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
100
10
Number of Cycles at 60Hz
2017.01
T J =75°C
10 2
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
SS82C THRU SS820C
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
Type number
3.8
(150)
4.1
(160)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
2017.01
703248B8
Marking code
SS82C
SS 8 2
SS 8 4C
SS 8 4
SS 8 6C
SS 8 6
SS 8 8C
SS 8 8
SS 8 10C
SS 8 10
SS 8 12C
SS 8 12
SS 8 15C
SS 8 15
SS 8 20C
SS 8 20
Page 3 of 3
很抱歉,暂时无法提供与“SS84C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.83160
- 50+0.66647
- 150+0.58385
- 500+0.52197
- 国内价格
- 20+1.59030
- 100+0.94870
- 800+0.66410
- 3000+0.47440
- 6000+0.45070
- 30000+0.41740
- 国内价格
- 5+0.75460
- 50+0.60476
- 600+0.47363
- 1200+0.46653
- 3000+0.42865
- 国内价格
- 1+0.64240
- 200+0.44220
- 1500+0.40260
- 3000+0.37620
