BSD3C241V
BSD3C241V
    BORN(伯恩半导体)
    SOD-323
    Transient Voltage Suppressors VC=67V IPP=6A SOD323 PPP=400W
BSD3C241V 数据手册
BSD3C241V ESD Protection Diode »Features ■ 300Watts peak pulse power (tp = 8/20μs) ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±30kV contact ±30kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 5A (8/20μs) »Applications »Mechanical Data ■ Microprocessor based equipment ■ SOD323 package ■ Personal Digital Assistants (PDA’s) ■ Molding compound flammability rating: UL 94V-0 ■ Notebooks, Desktops, and Servers ■ Packaging: Tape and Reel ■ Portable Instrumentation ■ RoHS/WEEE Compliant ■ Pagers Peripherals »Schematic & PIN Configuration SOD-323 Revision 2018 www.born-tw.com 1/4 BSD3C241V »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs) PPP 300 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 5 A VESD 30 30 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) »Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Min Typical VRWM VBR IT=1mA Reverse Leakage Current IR VRWM=24V,T=25℃ Clamping Voltage VC IPP=5A,tp=8/20μs Junction Capacitance Cj VR = 0V, f = 1MHz Max Units 24.0 V 26.7 V 15 0.5 uA 50 V pF »Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I IPP Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM VC VBR VRWM Breakdown Voltage @ IT IT IR IR IT VRWM VBR VC V Test Current IPP Note:. 8/20μs pulsewaveform. Revision 2018 www.born-tw.com 2/4 BSD3C241V »Typical Characteristics Figure 2: Power Derating Curve 10 110 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 300w 8/20μs waveform 1 0.1 0.01 0.1 1 10 100 100 90 80 70 60 50 40 30 20 10 0 1,000 td – Pulse Duration - µs 90 Ipp 80 Percent 100 e-1 50 40 td=Ipp/ 2 10 5 Revision 2018 10 15 150 70 60 50 40 Test Waveform Paramters tr=8µs td=20µs 30 20 10 0 0 125 80 Clamping Voltage–VC (V) 100 20 75 90 Waveform Paramters tr=8µs td=20µs 30 50 Figure 4: Clamping Voltage vs.Ipp 110 60 25 Ambient Temperature - TA (℃) Figure3: Pulse Waveform 70 0 Time (µs) 20 25 30 0 0 1 2 3 4 5 6 Peak Pulse Current–IPP (A) www.born-tw.com 3/4 BSD3C241V »Outline Drawing – SOD323 C A DIMENSIONS SYMBOL E B 1 2 MILLIMETER MIN MAX MIN MAX A 1.600 1.800 0.063 0.071 B 0.250 0.350 0.010 0.014 C 2.500 2.700 0.098 D D H L L1 1.000 0.106 0.039 E 1.200 1.400 0.047 0.055 F 0.080 0.150 0.003 0.006 L F INCHES 0.475 REF 0.019REF L1 0.250 0.400 0.010 0.016 H 0.000 0.100 0.000 0.004 »Marking 1 24B 2 »Ordering information Order code Package Base qty Delivery mode BSD3C241V SOD323 3000 Tape and reel Revision 2018 www.born-tw.com 4/4
BSD3C241V
物料型号: BSD3C241V
器件简介: ESD保护二极管,具有300W峰值脉冲功率,双向配置,固态硅雪崩技术,低钳位电压,低漏电流,符合IEC 61000-4-2 ±30kV接触和±30kV空气的ESD标准,IEC 61000-4-4 (EFT) 40A(5/50ns),IEC 61000-4-5 (Lightning) 5A(8/20μs)。
引脚分配: SOD-323封装,引脚配置为: - A: 阳极 - C: 阴极 - B: 测试引脚
参数特性: - 峰值脉冲功率 (t=8/20μs): 300W - 峰值脉冲电流 (t=8/20μs): 5A - ESD (空气): ±30kV - 引脚焊接温度: 260°C (10秒) - 结温: -55至+150°C - 存储温度: -55至+150°C
功能详解: - 反向工作电压: 24.0V - 反向击穿电压: 26.7V - 反向漏电流: 0.5uA (在24V反向工作电压下,25°C) - 钳位电压: 50V (在5A峰值脉冲电流,8/20μs脉冲波形下) - 结电容: 15pF (在0V反向电压,1MHz频率下)
应用信息: - 微处理器基础设备 - 个人数字助理 (PDA) - 笔记本电脑、台式机和服务器 - 便携式仪器 - 寻呼机外围设备
封装信息: - 封装类型: SOD323 - 包装: 带和卷 - 符合RoHS/WEEE标准 - 阻燃等级: UL94V-0
BSD3C241V 价格&库存
很抱歉,暂时无法提供与“BSD3C241V”相匹配的价格&库存,您可以联系我们找货
BSD3C241V
  • 10+0.57651
  • 100+0.47283
  • 300+0.42099
  • 3000+0.33837
  • 6000+0.30726
  • 9000+0.29160
库存:5131
BSD3C241V
  • 1+0.48510
  • 200+0.31350
  • 1500+0.27170
  • 3000+0.24090
库存:3000
BSD3C241V
  • 10+0.34820
  • 50+0.32420
  • 200+0.30420
  • 600+0.28420
  • 1500+0.26820
  • 3000+0.25820
库存:2590
