TPD4E001DRLR-N
ESD Protection Diode Array
»Features
60Watts peak pulse power (tp = 8/20μs)
SOT563 package
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=0.25pF typ.)
Protection one data/power line
IEC 61000-4-2 ±15kV contact ±20kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 3.5A (8/20μs)
»Applications
Ethernet
Digital Visual Interface (DVI)
USB2.0
Notebook and PC Computers
»Mechanical Data
SOT563 package
Molding compound flammability rating: UL 94V-0
Packaging: Tape and Reel
RoHS/WEEE Compliant
»Schematic & PIN Configuration
I/O 1
6 I/O
GND
Vcc
I/O 3
4 I/O
SOT563
Revision 2018
www.born-tw.com
1/4
TPD4E001DRLR-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
60
Watts
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
3.5
A
VESD
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Typical
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=5V,T=25℃
Peak Pulse Current
IPP
tp =8/20μs
Clamping Voltage
VC
IPP=3.5A,tp=8/20μs
Cj
Junction Capacitance
Min
Max
Units
5.0
V
6
V
50
500
nA
3
A
15
18
V
VR = 0V, f = 1MHz
IO to IO
0.2
0.25
VR = 0V, f = 1MHz
IO to GND
0.35
0.5
pF
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
V C V BR
VRWM
IT
IR
I
IT R
V RWM
VBR VC
V
Breakdown Voltage @ IT
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
TPD4E001DRLR-N
»Typical Characteristic Curves
Fig.1 Peak Pulse Power RatingCurve
Fig.2 Pulse Derating Curve
Percent of Rated Power for Ipp
Peak Pulse Power –PPP(KW)
10
1
60w 8/20μs waveform
0.1
0.01
0.1
1
10
100
Pulse Duration tp (μs)
60
40
100%IPP , 8μS
25
50
75
100
1
Ambient Temperature—TA(℃)
150
100%
90%
50%IPP, 20μS
e-t
60
Percent of IPP
30ns
80
40
Fig.4 PulseWaveform-ESD(IEC61000-4-2)
100
Percent of IPP
80
1000
Fig.3 PulseWaveform-8/20μs
120
110
100
60ns
10%
10
15
30
tr 0.7 to 1ns
Time (μs)
60
Time (ns)
Fig.5 Eye Diagram - HDMI mask at 5.0Gbpsper
channel
Fig.6 Insertion Loss S21 - I/O toGND
2
3.2GHz @ -1dB
Horizontal: 50 ps/div
Vertical: 200 mV/div
Insertion Loss (dB)
-4
5GHz @ -3dB
-6
-8
-10
100k
1M
10M
100M
1G
10G
Frequency (Hz)
Revision 2018
www.born-tw.com
3/4
TPD4E001DRLR-N
»Outline Drawing – SOT563
PACKAGE OUTLINE
E1
L
A1
DIMENSIONS
INCHES
SYMBOL
MIN
MAX
MIN
MAX
A
0.021
0.024
0.525
0.600
A1
0.000
0.002
0.000
0.050
e
b
D
A
E
c
θ
MILLIMETER
e
0.018
0.022
0.450
0.550
c
0.004
0.006
0.090
0.160
D
0.059
0.067
1.500
1.700
b
0.007
0.011
0.170
0.270
E1
0.043
0.051
1.100
1.300
E
0.059
0.067
1.500
1.700
L
0.004
0.012
0.100
0.300
θ
7°REF
7°REF
θ
X
DIMENSIONS
G
Y
Z
DIM
INCHES
MILLIMETERS
Z
0.0752
1.91
G
0.0350
0.89
P
0.020TYP
0.51 TYP
X
0.0118
0.3
Y
0.0201
0.51
P
»Marking
E5C
Ordering information
Order code
TPD4E001DRLR-N
Revision 2018
Package
SOT563
Base qty
3k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“TPD4E001DRLR-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.68845
- 50+0.54733
- 600+0.42385
- 国内价格
- 5+0.75870
- 50+0.60318
- 150+0.52542
- 500+0.46710
- 3000+0.40425
- 6000+0.38081
