SSL510B
SSL510B
    JINGDAO(晶导微电子)
    SMB(DO-214AA)
    表面贴装肖特基势垒整流器 反向电压-60~100 V 正向电流-5.0A
SSL510B 数据手册
山东晶导微电子股份有限公司 SSL56B THRU SSL510B Jingdao Microelectronics co.LTD Surface Mount Schottky Barrier Rectifier Reverse Voltage - 60~100 V Forward Current - 5.0A PINNING PIN Features • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications DESCRIPTION 1 Cathode 2 Anode 2 1 Top View Marking Code: SL56B~SL510B Simplified outline SMB and symbol MECHANICAL DATA • Case: SMB • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.1g / 0.0034oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Symbols Parameter SSL56B SSL510B Units Maximum Repetitive Peak Reverse Voltage V RRM 60 100 V Maximum RMS voltage V RMS 42 70 V Maximum DC Blocking Voltage V DC 60 100 V Maximum Average Forward Rectified Current I F(AV) 5.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 150 A Max Instantaneous Forward Voltage at 5 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range VF 0.5 0.6 V IR 1.0 50 mA Cj 600 pF RθJA 45 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2017.04 SMB-S-SSL56B~SSL510B -5A100V Page 1 of 3 山东晶导微电子股份有限公司 SSL56B THRU SSL510B Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics Average Forward Current (A) 6.0 5.0 4.0 3.0 2.0 1.0 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =100°C 10 3 10 1 T J =25°C 10 0 0 Case Temperature (°C) 60 80 100 Fig.4 Typical Junction Capacitance T J =25°C 10 1 SSL56B SSL510B 0.1 0 0.5 1.0 1.5 500 100 20 10 0.1 1 10 100 Instaneous Forward Voltage (V) Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 180 150 120 90 60 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 1000 2.0 210 30 Junction Capacitance ( pF) 20 10 100 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) Peak Forward Surage Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 100 10 Number of Cycles at 60Hz 2017.04 T J =75°C 10 2 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 SSL56B THRU SSL510B Jingdao Microelectronics co.LTD PACKAGE OUTLINE SMB Plastic surface mounted package; 2 leads L A A1 C A b D E E1 VM A SMB mechanical data UNIT mm mil A1 L C b 5.59 0.20 1.5 0.305 2.2 3.3 5.08 0.05 0.8 0.152 1.9 155 220 7.9 59 12 87 200 2.0 32 6 75 A E D max 2.44 4.70 3.94 min 2.13 4.06 max 96 185 min 84 160 E1 130 SS26F Marking The recommended mounting pad size 3.0(118) Type number Marking code SSL56B SL56B SSL510B SL510B 1.8(71) 2.54(100) 1.8(71) Unit:mm(mil) 2017.04 706067B2 Page 3 of 3
SSL510B 价格&库存
很抱歉,暂时无法提供与“SSL510B”相匹配的价格&库存,您可以联系我们找货
SSL510B
    • 1+0.86890
    库存:5
    SSL510B
    • 5+0.79233
    • 50+0.63808
    • 600+0.63170
    • 1200+0.61907
    • 3000+0.60050
    库存:2230
