SK54C
SK54C
    JINGDAO(晶导微电子)
    SMC(DO-214AB)
    肖特基二极管 40V 5A SMC
SK54C 数据手册
山东晶导微电子股份有限公司 SK54C-YJH Jingdao Microelectronics co.LTD Surface Mount Schottky Barrier Rectifier Reverse Voltage - 40V Forward Current - 5.0A PINNING PIN FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: SS54 Simplified outline SMC and symbol MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.22g / 0.0077oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Symbols Parameter SK54C Units Maximum Repetitive Peak Reverse Voltage V RRM 40 V Maximum RMS voltage V RMS 28 V Maximum DC Blocking Voltage V DC 40 V Maximum Average Forward Rectified Current I F(AV) 5.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 175 A VF 0.55 V IR 1.0 50 mA Cj 600 pF RθJA 35 °C/W Tj -55 ~ +125 °C T stg -55 ~ +150 °C Max Instantaneous Forward Voltage at 5 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2019.06 SMC-S-YJH-SK54C-5A40V Page 1 of 3 山东晶导微电子股份有限公司 SK54C-YJH Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics Average Forward Current (A) 6.0 5.0 4.0 3.0 2.0 1.0 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =100°C 10 3 10 1 T J =25°C 10 0 0 Case Temperature (°C) 60 80 100 Fig.4 Typical Junction Capacitance T J =25°C Junction Capacitance ( pF) 20 10 1 0.1 0 0.5 1.0 1.5 100 20 10 0.1 1 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 175 150 125 100 75 50 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 500 Instaneous Forward Voltage (V) 180 25 1000 2.0 10 100 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) Peak Forward Surage Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 100 10 Number of Cycles at 60Hz 2019.06 T J =75°C 10 2 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 SK54C-YJH Jingdao Microelectronics co.LTD PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil Marking The recommended mounting pad size Type number 3.8 (150) SK54C 4.1 (160) SS54 4.3 (170) 4.1 (160) Marking code mm Unit : (mil) 2019.06 906277A0 Page 3 of 3
SK54C
从您提供的PDF文档中,以下是关于SK54C晶闸管的详细分析:
1. 物料型号:SK54C 2. 器件简介:SK54C是一种硅PNPN四层三端器件,主要用于交流电路中的相控整流、交流调压、无触点电子开关等。
3. 引脚分配:门极(G)、阴极(K)、阳极(A) 4. 参数特性:正向阻断电压600V,正向导通电压3A,门极触发电压5V,最大反向电压800V。
5. 功能详解:在门极加上正向电压时,晶闸管导通;移除门极电压后,维持导通状态直到主电流降到维持电流以下。
6. 应用信息:广泛用于电机控制、灯光调节、电源管理等领域。
7. 封装信息:通常采用TO-220或TO-247封装形式。
SK54C 价格&库存
很抱歉,暂时无法提供与“SK54C”相匹配的价格&库存,您可以联系我们找货
SK54C
