RClamp7534P-N
ESD Protection Diode Array
»Features
45Watts peak pulse power (tp = 8/20μs)
Tiny DFN2010 package
Protect up to 4-lines
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=0.28pF typ. I/O to I/O)
IEC 61000-4-2 ±12kV contact ±15kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 3.5A(8/20μs)
»Applications
»Mechanical Data
USB 3.0/3.1,Type C
DFN2010 package
HDMI 1.4/2.0,Display Port 1.3
Molding compound flammability rating: UL 94V-0
Unified Display interface
Packaging: Tape and Reel
Digital visual interface
RoHS/WEEE Compliant
»Schematic & PIN Configuration
Pin 1
Pin 2
Pin 3
Pin 4
I/O
5
4
Pin 5
1
I/O
Revision 2018
I/O
www.born-tw.com
2
3
GND
I/O
1/4
RClamp7534P-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
45
Watts
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
3.5
A
VESD
15
12
kV
Lead SolderingTemperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
StorageTemperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2(Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Conditions
Min
Typical
Max
Units
5.0
V
7.2
9.5
V
0.1
0.5
μA
VRWM
VBR
IT=1mA
Reverse LeakageCurrent
IR
VRWM=5V,T=25℃
Peak Pulse Current
IPP
tp =8/20μs
3.5
A
Clamping Voltage
VC
IPP=3.5A,tp=8/20μs
13
V
Reverse BreakdownVoltage
Cj
Junction Capacitance
6.0
VR = 0V, f = 1MHz
I/O to I/O
0.28
0.4
pF
VR = 0V, f = 1MHz
I/O to GND
0.28
0.4
pF
»Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RWM
IR
V BR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC V BR
V RWM
IT
IR
ITIR
VRWM
V BR V C
V
Breakdown Voltage @ IT
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
RClamp7534P-N
»TypicalCharacteristics
Fig.2 IEC61000-4-2 +8kV ContactESD
ClampingWaveform
Fig.1 IEC61000-4-2Waveform
100%
90%
30ns
10%
tr 0.7 to 1ns
Pf
I n
o
t c
r P
e e
60ns
60
Time (ns)
Time (ns)
Fig.3 Eye Diagram - USB3.1 at 10Gbpsper
Fig.4 Insertion Loss S21 - I/O toI/O
Insertion Loss (dB)
channel
m1
m2
m3
m4
= 0.123dB @2.5GHz
= 0.245dB @5.0GHz
= 0.489dB @7.5GHz
= 3.751dB @15GHz
Frequency (Hz)
Revision 2018
www.born-tw.com
3/4
RClamp7534P-N
»Outline Drawing – DFN2010
D
A
E
Dim
A
A1
b
D
E
e
e1
L
N
A1
1
2
LxN
Millimeters
Min Nom Max
0.45 0.50 0.55
0.00 0.02 0.05
0.15 0.20 0.25
1.95 2.00 2.05
0.95 1.00 1.05
0.40 BSC
0.80 BSC
0.25 0.30 0.35
5
bxN
e
e1
»Marking
M534
»Ordering information
Order code
RClamp7534P-N
Revision 2018
Package
DFN2010
Base qty
3000
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“RClamp7534P-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.03733
- 50+0.82496
- 600+0.62034
- 1200+0.61103
- 3000+0.56977
