5.0SMDJ26CA
5.0SMDJ26CA
    BRIGHTKING(君耀)
    DO214AB
    极性:双向 反向截止电压(Vrwm):26V 击穿电压(最小值):28.9V 峰值脉冲电流(Ipp)@10/1000μs:119A 最大钳位电压:42.1V
5.0SMDJ26CA 数据手册
5.0SMDJ SERIES Transient Voltage Suppressors (TVS) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ For surface mounted applications in order to optimize board space Low profile package Built-in strain relief Glass passivated junction Low inductance Excellent clamping capability 5000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% Fast response time Typical IR less than 2μA above 22V High Temperature soldering: 260℃/10 seconds at terminals Plastic package has underwriters laboratory flammability 94V-0 Meets MSL level 1, per J-STD-020 Safety certification: UL: E244458 Mechanical Data ■ ■ ■ ■ ■ Case: JEDEC DO-214AB. Molded plastic over glass passivated junction Terminal: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode except bi-directional models Standard Packaging: 16mm tape (EIA STD RS-481) Weight: 0.30g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 5000 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 6.5 Watts IFSM 300 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Revision:25th-Jun-19 http://brightking.yageo.com 5.0SMDJ SERIES Dimensions (SMC/DO-214AB) Millimeters Inches Symbol Cathode Band D1 D Min. Max. Min. Max. L 6.60 7.11 0.260 0.280 D 5.59 6.22 0.220 0.245 D1 2.90 3.20 0.114 0.126 T 7.75 8.13 0.305 0.320 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.20 2.80 0.087 0.110 H1 2.06 2.62 0.079 0.103 L H1 H d T1 T Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 5.0SMDJ11A 5.0SMDJ11CA 5PEN 5BEN 11.0 12.20~13.50 10 18.2 275.00 800 5.0SMDJ12A 5.0SMDJ12CA 5PEP 5BEP 12.0 13.30~14.70 10 19.9 252.00 800 5.0SMDJ13A 5.0SMDJ13CA 5PEQ 5BEQ 13.0 14.40~15.90 10 21.5 233.00 500 5.0SMDJ14A 5.0SMDJ14CA 5PER 5BER 14.0 15.60~17.20 10 23.2 216.00 200 5.0SMDJ15A 5.0SMDJ15CA 5PES 5BES 15.0 16.70~18.50 1 24.4 205.00 100 5.0SMDJ16A 5.0SMDJ16CA 5PET 5BET 16.0 17.80~19.70 1 26.0 193.00 50 5.0SMDJ17A 5.0SMDJ17CA 5PEU 5BEU 17.0 18.90~20.90 1 27.6 181.00 20 5.0SMDJ18A 5.0SMDJ18CA 5PEV 5BEV 18.0 20.00~22.10 1 29.2 172.00 10 5.0SMDJ20A 5.0SMDJ20CA 5PEW 5BEW 20.0 22.20~24.50 1 32.4 155.00 5 5.0SMDJ22A 5.0SMDJ22CA 5PEX 5BEX 22.0 24.40~26.90 1 35.5 141.00 5 5.0SMDJ24A 5.0SMDJ24CA 5PEZ 5BEZ 24.0 26.70~29.50 1 38.9 129.00 2 5.0SMDJ26A 5.0SMDJ26CA 5PFE 5BFE 26.0 28.90~31.90 1 42.1 119.00 2 5.0SMDJ28A 5.0SMDJ28CA 5PFG 5BFG 28.0 31.10~34.40 1 45.4 110.00 2 5.0SMDJ30A 5.0SMDJ30CA 5PFK 5BFK 30.0 33.30~36.80 1 48.4 103.00 2 Revision:25th-Jun-19 http://brightking.yageo.com 5.0SMDJ SERIES Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 5.0SMDJ33A 5.0SMDJ33CA 5PFM 5BFM 33.0 36.70~40.60 1 53.3 93.90 2 5.0SMDJ36A 5.0SMDJ36CA 5PFP 5BFP 36.0 40.00~44.20 1 58.1 86.10 2 5.0SMDJ40A 5.0SMDJ40CA 5PFR 5BFR 40.0 44.40~49.10 1 64.5 77.60 2 5.0SMDJ43A 5.0SMDJ43CA 5PFT 5BFT 43.0 47.80~52.80 1 69.4 72.10 2 5.0SMDJ45A 5.0SMDJ45CA 5PFV 5BFV 45.0 50.00~55.30 1 72.7 68.80 2 5.0SMDJ48A 5.0SMDJ48CA 5PFX 5BFX 48.0 53.30~58.90 1 77.4 64.70 2 5.0SMDJ51A 5.0SMDJ51CA 5PFZ 5BFZ 51.0 56.70~62.70 1 82.4 60.70 2 5.0SMDJ54A 5.0SMDJ54CA 5PGE 5BGE 54.0 60.00~66.30 1 87.1 57.50 2 5.0SMDJ58A 5.0SMDJ58CA 5PGG 5BGG 58.0 64.40~71.20 1 93.6 53.50 2 5.0SMDJ60A 5.0SMDJ60CA 5PGK 5BGK 60.0 66.70~73.70 1 96.8 51.70 2 5.0SMDJ64A 5.0SMDJ64CA 5PGM 5BGM 64.0 71.10~78.60 1 103.0 48.60 2 5.0SMDJ70A 5.0SMDJ70CA 5PGP 5BGP 70.0 77.80~86.00 1 113.0 44.30 2 5.0SMDJ75A 5.0SMDJ75CA 5PGR 5BGR 75.0 83.30~92.10 1 121.0 41.40 2 5.0SMDJ78A 5.0SMDJ78CA 5PGT 5BGT 78.0 86.70~95.80 1 126.0 39.70 2 5.0SMDJ85A 5.0SMDJ85CA 5PGV 5BGV 85.0 94.40~104.00 1 137.0 36.50 2 5.0SMDJ90A 5.0SMDJ90CA 5PGX 5BGX 90.0 100.00~111.00 1 146.0 34.30 2 5.0SMDJ100A 5.0SMDJ100CA 5PGZ 5BGZ 100.0 111.00~123.00 1 162.0 30.90 2 5.0SMDJ110A 5.0SMDJ110CA 5PHE 5BHE 110.0 122.00~135.00 1 177.0 28.30 2 5.0SMDJ120A 5.0SMDJ120CA 5PHG 5BHG 120.0 133.00~147.00 1 193.0 26.00 2 5.0SMDJ130A 5.0SMDJ130CA 5PHK 5BHK 130.0 144.00~159.00 1 209.0 24.00 2 5.0SMDJ150A 5.0SMDJ150CA 5PHM 5BHM 150.0 167.00~185.00 1 243.0 20.60 2 5.0SMDJ160A 5.0SMDJ160CA 5PHP 5BHP 160.0 178.00~197.00 1 259.0 19.30 2 5.0SMDJ170A 5.0SMDJ170CA 5PHR 5BHR 170.0 189.00~209.00 1 275.0 18.20 2 Notes: For bidirectional type having VRWM of 18V and less, the IR limit is double. Revision:25th-Jun-19 http://brightking.yageo.com 5.0SMDJ SERIES Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 1000 100 10 1 0.31×0.31″(8.0×8.0mm) Copper Pad Area 0.1 0.1 1 100 10 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) 125 150 175 100000 Uni-directional Peak Value IPPM 100 Cj (pF) IPPM - Peak Pulse Current, %IRSM 100 10000 Half Value IPPM (IPPM/2) 1000 Bi-directional 100 50 10/1000µs Waveform as defined by R.E.A 10 td 0 0 Measured at 1MHz, 100mV, 0V bias 1 1.0 2.0 3.0 1 4.0 t-Time (ms) Figure 5. Steady State Power Dissipation Derating IFSM - Peak Forward Surve Current (A) 6 5 4 3 2 1 0 25 1000 Surge Current Uni-Directional Only 7 0 10 100 VRWM-Reverse Stand-Off Voltage (V) Figure 6. Maximum Non-Repetitive Forward Curve PM(AV), Steady State Power Dissipation (W) 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 50 75 100 125 TA-Ambient Temperature (℃) Revision:25th-Jun-19 150 175 350 300 250 200 150 100 50 0 1 10 Number of Cycles at 60Hz 100 http://brightking.yageo.com 5.0SMDJ SERIES Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) 20-40 seconds Ramp-down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max. Marking Code Cathode Band YXXX YXXX 5PEN Logo 5BEN Date Code Marking Code Revision:25th-Jun-19 Logo Date Code Marking Code http://brightking.yageo.com 5.0SMDJ SERIES Part Number Code 5.0SMDJ XXX C A 5% VBR Voltage Tolerance Bidirectional VRWM Voltage Series Code Packaging Tape P0 P1 P2 D0 B T E F W B0 D1 A A B K0 SECTION B-B A0 SECTION A-A 7” Reel Symbol Dimension (mm) W 16.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1.5±0.10 E 1.75±0.10 F 7.50±0.10 A0 6.27±0.10 B0 8.30±0.10 K0 3.15±0.15 T 0.30±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 20.0±2.0 D4 D3 D2 13” Reel W1 Quantity: 500PCS D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 20.0±2.0 Quantity: 3000PCS Revision:25th-Jun-19 http://brightking.yageo.com
5.0SMDJ26CA 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ26CA”相匹配的价格&库存,您可以联系我们找货
5.0SMDJ26CA
