山东晶导微电子股份有限公司
SSL34
Jingdao Microelectronics co.LTD
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 40V
Forward Current - 3.0A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SSL34
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
SSL34
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
V
Maximum RMS voltage
V RMS
28
V
Maximum DC Blocking Voltage
V DC
40
V
Maximum Average Forward Rectified Current
at T c = 100 °C
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
80
A
Maximum Instantaneous Forward Voltage at 3 A
VF
0.45
V
IR
0.3
5
mA
Cj
450
pF
RθJA
60
°C/W
Operating Junction Temperature Range
Tj
-55 ~ +150
°C
Storage Temperature Range
T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =100 °C
Typical Junction Capacitance
(1)
Typical Thermal Resistance
(2)
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.05
SMA-S-SSL34-3A40V
Page 1 of 3
山东晶导微电子股份有限公司
SSL34
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half wave resistive
or inductive
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Fig.2 Typical Reverse Characteristics
10 4
10 1
T J =25°C
10 0
80
T J =25°C
T J =25°C
Junction Capacitance ( pF)
1
0.1
1.0
1.5
1000
500
100
2.0
0.1
1
10
100
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.5- Typical Transient Thermal Impedance
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
100
Fig.4 Typical Junction Capacitance
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
T J =75°C
10 2
Case Temperature (°C)
100
10
Number of Cycles at 60Hz
2016.05
T J =100°C
10 3
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
SSL34
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
0.3
12
1.8
(71)
Type number
Marking code
SS L 34
SS L 34
1.8
(71)
2.4
(94)
a
Marking
The recommended mounting pad size
1.8
(71)
g
e
A
D
mm
Unit :
(mil)
2016.05
XTH605057B0
Page 3 of 3
很抱歉,暂时无法提供与“SSL34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.79560
- 100+0.47450
- 500+0.33210
- 5000+0.23720
- 10000+0.22540
- 50000+0.20870
- 国内价格
- 5+0.39553
- 50+0.38960
- 1000+0.38570
- 2000+0.37799
- 5000+0.36665
