CTBP93HD/2
CTBP93HD/2
    CAMDENBOSS
    弯插,P=3.5mm
    线对板连接器 间距3.50mm 2Pin 弯插
CTBP93HD/2 数据手册
CAMBLOCK PLUS Female Connector Vertical (reversed) LENGTH 7mm 10.5mm 14mm 17.5mm 21mm 24.5mm 28mm 31.5mm 35mm 38.5mm 42mm CTBP92VD/R 3.5 (XX-1) +4.3 3.5 (XX-1) 10.50 19.20 POLES 2 3 4 5 6 7 8 9 10 11 12 6.60 TYPE NO. CTBP92VD/2R CTBP92VD/3R CTBP92VD/4R CTBP92VD/5R CTBP92VD/6R CTBP92VD/7R CTBP92VD/8R CTBP92VD/9R CTBP92VD/10R CTBP92VD/11R CTBP92VD/12R PCB TERMINAL BLOCKS 3.50 PCB Mounting Male Horizontal (closed ended) CTBP93HD 3.50 3.5 (XX-1) 0.20 3.5 (XX-1) +4.3 0.20 7.20 7.00 9.20 LENGTH 8.4mm 11.9mm 15.4mm 18.9mm 22.4mm 25.9mm 29.4mm 32.9mm 36.4mm 39.9mm 43.4mm 1.20 POLES 2 3 4 5 6 7 8 9 10 11 12 0.80 TYPE NO. CTBP93HD/2 CTBP93HD/3 CTBP93HD/4 CTBP93HD/5 CTBP93HD/6 CTBP93HD/7 CTBP93HD/8 CTBP93HD/9 CTBP93HD/10 CTBP93HD/11 CTBP93HD/12 *3.40 +_ 0.3 PCB Mounting Male Vertical (closed ended) LENGTH 8.4mm 11.9mm 15.4mm 18.9mm 22.4mm 25.9mm 29.4mm 32.9mm 36.4mm 39.9mm 43.4mm CTBP93VD 0.20 7.20 0.80 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com Downloaded from Arrow.com. 0.20 7.00 3.5 (XX-1) +4.3 9.20 POLES 2 3 4 5 6 7 8 9 10 11 12 3.0 *3.40 +_ 0.3 TYPE NO. CTBP93VD/2 CTBP93VD/3 CTBP93VD/4 CTBP93VD/5 CTBP93VD/6 CTBP93VD/7 CTBP93VD/8 CTBP93VD/9 CTBP93VD/10 CTBP93VD/11 CTBP93VD/12 3.50 3.5 (XX-1) 41 We operate a constant improvement policy, our products are subject to change without notice. Ver 1.0 EL EC T RO N IC S & ENC LOSURES
CTBP93HD/2 价格&库存
很抱歉,暂时无法提供与“CTBP93HD/2”相匹配的价格&库存,您可以联系我们找货
CTBP93HD/2
  • 1+1.84672
  • 30+1.78304
  • 100+1.65568
  • 500+1.52832
  • 1000+1.46464
