BZT52Cxx Series
ZENER
SOD123 Plastic-Encapsulate Zener Diode
ROHS
SOD-123
Features
Low Zener Impedance
Power Dissipation of 500mW
High Stability and High Reliability
Mechanical Data
SOD-123 Small Outline Plastic Package
Polarity: Color band denotes cathode end
Epoxy UL: 94V-0
Mounting Position: Any
Maximum Ratings & Thermal Characteristics
(Ratings at 25℃ ambient temperature unless otherwise specified.)
Parameters
Symbol
Value
Power Dissipation
Pd
500
1)
mW
Forward Voltage @IF=10mA
Vf
0.9
2)
Storage temperature range
Ts
-65-+150
V
1)
2)
3)
Unit
Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm²
Short duration test pulse used to minimize self-heating effect
f=1KHz
Electrical Characteristics
. Ratings at 25℃ ambient temperature unless otherwise specified).
Zener Voltage Range
Device
Marking
Vz@Izt
Maximum Zener
Impedance
1.5KExxA(CA)
Zzt
Zzk
Izt
@Izt
@Izk
Ω
Maximum
Reverse Current
Izk
IR
VR
Typical
Temperature
coefficent @
IZTC=mV/℃
Test
Current
IZTC
Nom(V)
Min(V)
Max(V)
mA
mA
uA
V
Min
Max
mA
BZT52C2V4
WX
2.4
2.2
2.6
5
100
600
1.0
50
1.0
-3.5
BZT52C2V7
W1
2.7
2.5
2.9
5
100
600
1.0
-3.5
BZT52C3V0
W2
3.0
2.8
3.2
5
95
600
1.0
10
1.0
-3.5
BZT52C3V3
W3
3.3
3.1
3.5
5
95
600
1.0
5
1.0
-3.5
BZT52C3V6
W4
3.6
3.4
3.8
5
90
600
1.0
5
1.0
-3.5
BZT52C3V9
W5
3.9
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
BZT52C4V3
W6
4.3
4.0
4.6
5
90
600
1.0
3
1.0
-3.5
BZT52C4V7
W7
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
5
BZT52C5V1
W8
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
5
BZT52C5V6
W9
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
5
BZT52C6V2
WA
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
5
BZT52C6V8
WB
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
5
BZT52C7V5
WC
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
5
BZT52C8V2
WD
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
5
BZT52C9V1
WE
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
5
BZT52C10
WF
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
5
BZT52C11
WG
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
5
BZT52C12
WH
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
5
BZT52C13
WI
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
5
Rev 8: Nov 2014
www.born-tw.com
Page 1 of 5
BZT52Cxx Series
ZENER
Zener Voltage Range
Maximum Zener
Impedance
Zzt
Zzk
Izk
@Izt
@Izk
Ω
mA
ROHS
Maximum
Reverse Current
Typical
Temperature
coefficent @
IZTC=mV/℃
Test
Current
IZTC
Device
Marking
Nom(V)
Min(V)
Max(V)
mA
uA
V
Min
Max
mA
BZT52C15
WJ
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
5
BZT52C16
WK
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
5
BZT52C18
WL
18
16.8
19.1
5
45
225
1.0
0.1
12.6
12.4
16.0
5
BZT52C20
WM
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
5
BZT52C22
WN
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
5
BZT52C24
WO
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
5
BZT52C27
WP
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
2
BZT52C30
WQ
30
28.0
32.0
2
80
300
0.5
0.1
21.0
24.4
29.4
2
BZT52C33
WR
33
31.0
35.0
2
80
325
0.5
0.1
23.1
27.4
33.4
2
BZT52C36
WS
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
2
BZT52C39
WT
39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
2
BZT52C43
WU
43
40.0
46.0
2
100
700
1.0
0.1
32.0
10.0
12.0
5
BZT52C47
WV
47
44.0
50.0
2
100
750
1.0
0.1
35.0
10.0
12.0
5
BZT52C51
WW
51
48.0
54.0
2
100
750
1.0
0.1
38.0
10.0
12.0
5
Vz@Izt
Izt
IR
VR
at Tj=constant (pulsed)
1.5KExxA(CA)
Forward characteristics
Rev 8: Nov 2014
Admissible power dissipation versus ambient temperature
www.born-tw.com
Page 2 of 5
BZT52Cxx Series
ZENER
Pulse thermal resistance versus pulse duration
Dynamic resistance versus Zener current
Capacitance versus Zener voltage
ROHS
1.5KExxA(CA)
Rev 8: Nov 2014
www.born-tw.com
Thermal differential resistance versus Zener voltage
Page 3 of 5
BZT52Cxx Series
ZENER
Dynamic resistance versus Zener voltage
ROHS
Temperature dependence of Zener voltage versus Zener voltage
Change of Zener voltage versus junction temperature
1.5KExxA(CA)
Change of Zener voltge from turn-on up to the point of thermal
equilibrium versus Zener voltage
Rev 8: Nov 2014
www.born-tw.com
Page 4 of 5
BZT52Cxx Series
ZENER
ROHS
SOD-123 PACKAGE OUTLINE Plastic surface mounted package
b
D
c
Rev 8: Nov 2014
www.born-tw.com
Page 5 of 5
很抱歉,暂时无法提供与“BZT52C30”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11762
- 500+0.09245
- 3000+0.07733
- 6000+0.06902
- 24000+0.06167
- 51000+0.05778
- 国内价格
- 1+0.39840
- 200+0.13320
- 1500+0.08304
- 3000+0.06588
- 国内价格
- 50+0.10781
- 600+0.08474
- 1200+0.08347
- 3000+0.07088
