BST23Axx2V
Transient Voltage Suppressors
ROHS
Features
300 watts peak pulse power (tp = 8/20μs)
ESD Protection > 40 kilovolts
Protects one bidirectional line or two unidirectional lines
Working Voltages: 5V, 12V, 15V, 24V and36V
Low clamping voltages
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Applications
Mechanical Characteristics
JEDEC SOT23 package
RS-232, RS-422 & RS-485
Molding compound flammability rating: UL
Cellular Handsets and Accessories
94V-0
Control & Monitoring Systems
Marking: Marking Code
Portable Electronics
Packaging: Tape and Reel per EIA 481
Set-Top Box
RoHS/WEEE Compliant
Servers, Notebook, and Desktop PC
Wireless Bus Protection
Circuit Diagram
Schematic & PIN Configuration
2
1
3
3
2
1
SOT-23 (Top View)
1/5
BST23Axx2V
ROHS
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power(tp=8/20μs)
PPP
300
Watts
Lead Soldering Temperature
TL
260(10sec)
°C
Operating Temperature
TJ
-55 to + 125
°C
TSTG
-55 to +150
°C
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
I
Parameter
IF
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
VC VBR VRWM
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
V
IR VF
IT
IPP
Electrical Characteristics(T=25℃)
BST23A052V
Parameter
Reverse Stand-Off Voltage
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
5
V
VBR
IT=1mA
IR
VRWM=5V,T=25°C
1
μA
Peak Pulse Current
IPP
tp =8/20μs
18
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
9.8
V
Maximum Clamping Voltage
VC
IPP=18A, tp=8/20μs
16.7
V
Junction Capacitance
Cj
Cj
Reverse Breakdown Voltage
Pin 1 to 2
VR = 0V, f = 1MHz
Pin 1 to 3 and Pin 2 to 3
VR = 0V, f = 1MHz
6
V
100
pF
150
pF
2/5
BST23Axx2V
ROHS
BST23A122V
Parameter
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
12
V
VBR
IT=1mA
13.3
IR
VRWM=12V,T=25°C
1
μA
Peak Pulse Current
IPP
tp =8/20μs
12
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
19
V
VC
IPP=12A, tp=8/20μs
25
V
Cj
Cj
Pin 1 to 2
VR = 0V, f = 1MHz
VR = 0V, f = 1MHz
V
30
pF
50
pF
BST23A152V
Parameter
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
15
V
VBR
IT=1mA
16.7
IR
VRWM=15V,T=25°C
1
μA
Peak Pulse Current
IPP
tp =8/20μs
10
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
24
V
VC
IPP=10A, tp=8/20μs
30
V
Cj
Cj
Pin 1 to 2
VR = 0V, f = 1MHz
VR = 0V, f = 1MHz
V
25
pF
40
pF
BST23A242V
Parameter
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
24
V
VBR
IT=1mA
IR
VRWM=24V,T=25°C
1
μA
Peak Pulse Current
IPP
tp =8/20μs
5
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
43
V
VC
IPP=5A, tp=8/20μs
60
V
Cj
Cj
Pin 1 to 2
VR = 0V, f = 1MHz
VR = 0V, f = 1MHz
26.7
V
pF
30
pF
3/5
BST23Axx2V
ROHS
BST23A362V
Parameter
Symbol
Conditions
Minimum
Typical
Maximum
Units
36
V
VRWM
VBR
IT=1mA
40
V
IR
VRWM=36V,T=25°C
1
μA
Peak Pulse Current
IPP
tp =8/20μs
4
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
60
V
VC
IPP=4A, tp=8/20μs
75
V
Cj
Pin 1 to 2
VR = 0V, f = 1MHz
pF
Cj
VR = 0V, f = 1MHz
26
pF
Typical Characteristics
Peak Pulse Power vs. Pulse Time
Power Derating Curve
110
100
1,000
% of Rated Power or IPP
Ppp–Peak Pulse Power–Watts
10,000
300W 8/20µs
Waveform
100
90
80
70
60
50
40
30
10
0.1
1
10
100
1000
10000
50
75
100
125
Ambient Temprature -TA(°C)
td–Pulse Duration–µs
ESD Pulse Waveform (Per IEC 61000-4-2)
Pulse Waveform
110
Waveform
Paramters
tr=8µs
td=20µs
100
90
Percent of Ipp
80
70
e-t
60
50
40
30
td=Ipp/2
R1
10
15
Time (µs)
25
30
35
Ref1 500mV 10.0ns
4/5
150
BST23Axx2V
ROHS
Outline Drawing – SOT-23
PACKAGE OUTLINE
D
SOT-23
3
DIMENSIONS
E1 E
0.25
θ
1
b
e
A
INCHES
MIN
MAX
MIN
MAX
0.900
1.150
0.035
0.045
A1
0.000
0.100
A2
0.900
1.050
0.035
0.041
D
2.800
3.000
0.110
0.118
0.000
0.004
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
A1
MILLIMETER
A
L
2
A2
SYMBOL
L
θ
0.950 BSC
0.037 BSC
0.300
0.500
0.012
0.020
8○
8○
Notes
b
DIMENSIONS
M
Z
C
e
e1
DIM
INCHES
MILLIMETERS
M
0.088
2.20
C
0.0058
0.15
Z
0.093
2.35
e
0.037 BSC
0.95 BSC
e1
0.074 BSC
1.9 BSC
b
0.0389
0.35
1. Dimensioning and tolerances per ANSI Y14.5M,
1985.
2. Controlling Dimension: Inches
3. Pin 3 is the cathode (Unidirectional Only).
4. Dimensions are exclusive of mold flash and metal
burrs.
Marking Codes
Part Number
BST23A052V
BST23A122V
Marking Code
5M2
BST23A152V
AB2
BM2
BST23A242V
CM2
BST23A362V
DM2
Package Information
Qty:3k/Reel
5/5
很抱歉,暂时无法提供与“BST23A052U”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.44945
- 100+0.35756
- 600+0.31161
- 1200+0.30694
- 3000+0.23781
- 国内价格
- 1+0.48807
- 200+0.31485
- 1500+0.27370
- 3000+0.24212
- 国内价格
- 10+0.49031
- 100+0.39007
- 300+0.33994
- 3000+0.25943
- 6000+0.22941
- 9000+0.21436
