SMBJ-AT SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
For surface mounted applications in order to optimize board space
Low profile package
Built-in strain relief
Glass passivated junction
Low inductance
Excellent clamping capability
600W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 12V
High Temperature soldering: 260℃/10 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
AEC-Q101 qualified
Mechanical Data
Case: JEDEC DO-214AA. Molded plastic over glass passivated junction
Terminal: Solder plated, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Standard Packaging: 12mm tape (EIA STD RS-481)
Weight: 0.10g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 600
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
5.0
Watts
IFSM
100
Amps
TJ,TSTG
-55 to +150
RθJL
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Typical thermal resistance junction to lead
Typical thermal resistance junction to ambient
RθJA
100
℃/W
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:TVS-SMBJ-AT SERIES-001(A1)
1/7
http://brightking.pulseelectronics.com
SMBJ-AT SERIES
Dimensions (SMB/DO-214AA)
Millimeters
Cathode Band
Inches
Symbol
D1 D
Min.
Max.
Min.
Max.
L
4.06
4.57
0.160
0.180
D
3.30
3.94
0.130
0.155
D1
1.95
2.20
0.077
0.086
T
5.21
5.59
0.205
0.220
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
2.15
2.65
0.085
0.104
H1
2.13
2.47
0.084
0.097
L
H1 H
d
T1
T
Electrical Characteristics (TA=25℃)
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMBJ5.0A-AT
SMBJ5.0CA-AT
KE
AE
5.0
6.40~7.00
10
9.2
65.3
800
SMBJ6.0A-AT
SMBJ6.0CA-AT
KG
AG
6.0
6.67~7.37
10
10.3
58.3
800
SMBJ6.5A-AT
SMBJ6.5CA-AT
KK
AK
6.5
7.22~7.98
10
11.2
53.6
500
SMBJ7.0A-AT
SMBJ7.0CA-AT
KM
AM
7.0
7.78~8.60
10
12.0
50.0
200
SMBJ7.5A-AT
SMBJ7.5CA-AT
KP
AP
7.5
8.33~9.21
1
12.9
46.6
100
SMBJ8.0A-AT
SMBJ8.0CA-AT
KR
AR
8.0
8.89~9.83
1
13.6
44.2
50
SMBJ8.5A-AT
SMBJ8.5CA-AT
KT
AT
8.5
9.44~10.40
1
14.4
41.7
SMBJ9.0A-AT
SMBJ9.0CA-AT
KV
AV
9.0
10.00~11.10
1
15.4
39.0
10
SMBJ10A-AT
SMBJ10CA-AT
KX
AX
10.0
11.10~12.30
1
17.0
35.3
5
SMBJ11A-AT
SMBJ11CA-AT
KZ
AZ
11.0
12.20~13.50
1
18.2
33.0
1
SMBJ12A-AT
SMBJ12CA-AT
LE
BE
12.0
13.30~14.70
1
19.9
30.2
1
SMBJ13A-AT
SMBJ13CA-AT
LG
BG
13.0
14.40~15.90
1
21.5
28.0
1
SMBJ14A-AT
SMBJ14CA-AT
LK
BK
14.0
15.60~17.20
1
23.2
25.9
1
SMBJ15A-AT
SMBJ15CA-AT
LM
BM
15.0
16.70~18.50
1
24.4
24.6
1
SMBJ16A-AT
SMBJ16CA-AT
LP
BP
16.0
17.80~19.70
1
26.0
23.1
1
SMBJ17A-AT
SMBJ17CA-AT
LR
BR
17.0
18.90~20.90
1
27.6
21.8
1
SMBJ18A-AT
SMBJ18CA-AT
LT
BT
18.0
20.00~22.10
1
29.2
20.6
1
SMBJ20A-AT
SMBJ20CA-AT
LV
BV
20.0
22.20~24.50
1
32.4
18.6
1
SMBJ22A-AT
SMBJ22CA-AT
LX
BX
22.0
24.40~26.90
1
35.5
16.9
1
2/7
SMBJ-AT SERIES
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMBJ24A-AT
SMBJ24CA-AT
LZ
BZ
24.0
26.70~29.50
1
38.9
15.5
1
SMBJ26A-AT
SMBJ26CA-AT
ME
CE
26.0
28.90~31.90
1
42.1
14.3
1
SMBJ28A-AT
SMBJ28CA-AT
MG
CG
28.0
31.10~34.40
1
45.4
13.3
1
SMBJ30A-AT
SMBJ30CA-AT
MK
CK
30.0
33.30~36.80
1
48.4
12.4
1
SMBJ33A-AT
SMBJ33CA-AT
MM
CM
33.0
36.70~40.60
1
53.3
11.3
1
SMBJ36A-AT
SMBJ36CA-AT
MP
CP
36.0
40.00~44.20
1
58.1
10.4
1
SMBJ40A-AT
SMBJ40CA-AT
MR
CR
40.0
44.40~49.10
1
64.5
9.3
1
SMBJ43A-AT
SMBJ43CA-AT
MT
CT
43.0
47.80~52.80
1
69.4
8.7
1
SMBJ45A-AT
SMBJ45CA-AT
MV
CV
45.0
50.00~55.30
1
72.7
8.3
1
SMBJ48A-AT
SMBJ48CA-AT
MX
CX
48.0
53.30~58.90
1
77.4
7.8
1
SMBJ51A-AT
SMBJ51CA-AT
MZ
CZ
51.0
56.70~62.70
1
82.4
7.3
1
SMBJ54A-AT
SMBJ54CA-AT
NE
DE
54.0
60.00~66.30
1
87.1
6.9
1
SMBJ58A-AT
SMBJ58CA-AT
NG
DG
58.0
64.40~71.20
1
93.6
6.5
1
SMBJ60A-AT
SMBJ60CA-AT
NK
DK
60.0
66.70~73.70
1
96.8
6.2
1
SMBJ64A-AT
SMBJ64CA-AT
NM
DM
64.0
71.10~78.60
1
103.0
5.9
1
SMBJ70A-AT
SMBJ70CA-AT
NP
DP
70.0
77.80~86.00
1
113.0
5.3
1
SMBJ75A-AT
SMBJ75CA-AT
NR
DR
75.0
83.30~92.10
1
121.0
5.0
1
SMBJ78A-AT
SMBJ78CA-AT
NT
DT
78.0
86.70~95.80
1
126.0
4.8
1
SMBJ85A-AT
SMBJ85CA-AT
NV
DV
85.0
94.40~104.00
1
137.0
4.4
1
SMBJ90A-AT
SMBJ90CA-AT
NX
DX
90.0
100.00~111.00
1
146.0
4.1
1
SMBJ100A-AT
SMBJ100CA-AT
NZ
DZ
100.0
111.00~123.00
1
162.0
3.7
1
SMBJ110A-AT
SMBJ110CA-AT
PE
EE
110.0
122.00~135.00
1
177.0
3.4
1
SMBJ120A-AT
SMBJ120CA-AT
PG
EG
120.0
133.00~147.00
1
193.0
3.1
1
SMBJ130A-AT
SMBJ130CA-AT
PK
EK
130.0
144.00~159.00
1
209.0
2.9
1
SMBJ150A-AT
SMBJ150CA-AT
PM
EM
150.0
167.00~185.00
1
243.0
2.5
1
SMBJ160A-AT
SMBJ160CA-AT
PP
EP
160.0
178.00~197.00
1
259.0
2.3
1
SMBJ170A-AT
SMBJ170CA-AT
PR
ER
170.0
189.00~209.00
1
275.0
2.2
1
SMBJ180A-AT
SMBJ180CA-AT
PT
ET
180.0
201.00~222.00
1
292.0
2.1
1
SMBJ190A-AT
SMBJ190CA-AT
PA
EC
190.0
211.00~233.00
1
308.0
2.0
1
SMBJ200A-AT
SMBJ200CA-AT
PV
EV
200.0
224.00~247.00
1
324.0
1.9
1
SMBJ210A-AT
SMBJ210CA-AT
PB
ED
210.0
237.00~263.00
1
340.0
1.8
1
SMBJ220A-AT
SMBJ220CA-AT
PX
EX
220.0
246.00~272.00
1
356.0
1.7
1
SMBJ250A-AT
SMBJ250CA-AT
PZ
EZ
250.0
279.00~309.00
1
405.0
1.5
1
3/7
SMBJ-AT SERIES
Device
Marking
Code
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMBJ300A-AT
SMBJ300CA-AT
QE
FE
300.0
335.00~371.00
1
486.0
1.3
1
SMBJ350A-AT
SMBJ350CA-AT
QG
FG
350.0
391.00~432.00
1
567.0
1.1
1
SMBJ400A-AT
SMBJ400CA-AT
QK
FK
400.0
447.00~494.00
1
648.0
0.9
1
SMBJ440A-AT
SMBJ440CA-AT
QM
FM
440.0
492.00~543.00
1
713.0
0.9
1
Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double.
Marking Code
Cathode Band
YXXX
YXXX
KE
AE
Logo
Date Code
Logo
Marking Code
Date Code
Marking Code
Part Number Code
SMBJ XXX C A
AT
Internal Control Code
5% VBR Voltage Tolerance
Bidirectional
VRWM Voltage
Series Code
4/7
SMBJ-AT SERIES
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
100
10
1
0.2×0.2″(5.0×5.0mm)
Copper Pad Area
0.1
1
100
10
100
80
60
40
td-Pulse Width (µs)
td
100
1
2.0
3.0
Bi-directional @VR
4.0
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
6
5
4
3
2
1
75
100
125
150
175
1000
120
100
80
60
40
10
100
Number of Cycles at 60Hz
TA-Ambient Temperature (℃)
100
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
IFSM - Peak Forward Surve Current (A)
PM(AV), Steady State Power Dissipation (W)
Figure 5. Steady State Power Dissipation Derating
Curve
25
10
VBR-Reverse Breakdown Voltage (V)
t-Time (ms)
Uni-directional V=0V
10
10/1000µs Waveform
as defined by R.E.A
1.0
150
Uni-directional @VR
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
1000
50
Bi-directional V=0V
Half Value IPPM (IPPM/2)
10000
Peak Value IPPM
100
75
Figure 4. Typical Junction Capacitance
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
50
Figure 3. Pulse Waveform
150
25
5/7
SMBJ-AT SERIES
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
6/7
SMBJ-AT SERIES
Packaging
Tape
P0
P1
P2
D0
B
T
E
F
W
B0
D1
A
A
K0
B
SECTION B-B
Symbol
Dimension (mm)
W
12.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ1.5±0.10
E
1.75±0.10
F
5.50±0.10
A0
3.86±0.15
B0
5.65±0.10
K0
2.75±0.15
T
0.25±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
16.0±2.0
A0
SECTION A-A
7” Reel
D4
D3
D2
W1
Quantity: 500PCS
13” Reel
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
16.0±2.0
Quantity: 3000PCS
7/7
很抱歉,暂时无法提供与“SMCJ24CA-AT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.82593
- 10+0.74922
- 30+0.69808
- 100+0.62137
- 500+0.58557
- 1000+0.56000
