Digital Transistors (Built-in Resistors)
DTC144EE/DTC144EUA
DTC144EKA /DTC144ECA
·Equivalent Circuit
DIGITAL TRANSISTOR (NPN)
FEATURES
Built-in bias resistors enable the configuration of an inverter circuit
without connecting external input resistors(see equivalent circuit)
The bias resistors consist of thin-film resistors with complete isolation
to allow negative biasing of the input.They also have the advantage of
almost completely eliminating parasitic effects
Only the on/off conditions need to be set for operation, making device design easy
PIN CONNENCTIONS and MARKING
DTC144EE
SOT-523
3
DTC144EUA
3
1. IN
1. IN
2. GND
2. GND
3. OUT
1
2
MARKING: 26
2
DTC144ECA
SOT-23-3L
3
3
MARKING: 26
SOT-23
1. IN
1. IN
2. GND
2. GND
3. OUT
1
3. OUT
1
MARKING: 26
DTC144EKA
SOT-323
1
2
MARKING: 26
1
3. OUT
2
G,Jul,2016
A,Jun,2014
MAXIMUM
RATINGS(Ta=25℃ unless otherwise noted)
Symbol
Limits(DTC144E□)
Parameter
VCC
Supply Voltage
VIN
Input Voltage
IO
E
Unit
CA
UA
KA
50
V
-10~+40
V
Output Current
30
mA
ICM
Peak Collector Current
100
mA
PD
Power Dissipation
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
150
200
mW
200
200
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Input voltage
Output voltage
Input current
Symbol
Conditions
Min
Typ
Max
VI(off)
VCC=5V,IO=100µA
VI(on)
VO=0.3V,IO=2mA
3
V
VO(on)
IO/II=10mA/0.5mA
0.3
V
VI=5V
0.18
mA
0.5
μA
kΩ
II
V
0.5
Output current
IO(off)
VCC=50V,VI=0
DC current gain
GI
VO=5V,IO=5mA
Input resistance
R1
32.9
47
61.1
Resistance ratio
R2/R1
0.8
1
1.2
Transition frequency
www.cj-elec.com
Unit
fT
VO=10V,IO=5mA,f=100MHz
2
68
250
MHz
G,Jul,2016
A,Jun,2014
Typical Characteristics
OFF Characteristics
ON Characteristics
100
1
VCC=5V
VO=0.3V
30
(mA)
(V)
0.3
0.1
OUTPUT CURRENT
INPUT VOLTAGE
IO
VI(ON)
10
3
Ta=25℃
Ta=100℃
1
0.3
Ta=100℃
0.03
Ta=25℃
0.01
3E-3
0.1
0.1
0.3
1
3
OUTPUT CURRENT
IO
VO(ON) ——
1E-3
0.0
30
10
0.8
1.2
INPUT VOLTAGE
VI(OFF)
0.4
(mA)
GI
IO
1000
1.6
IO
1000
IO/II=20
VO=5V
Ta=100℃
GI
300
DC CURRENT GAIN
VO(ON)
(mV)
300
OUTPUT VOLTAGE
2.0
(V)
100
Ta=100℃
Ta=25℃
30
Ta=25℃
100
30
10
3
10
0.5
1
OUTPUT CURRENT
CO
30
10
3
IO
1
0.1
50
1
PD
VR
10
3
OUTPUT CURRENT
IO
30
100
125
150
(mA)
—— Ta
400
8
f=1MHz
Ta=25℃
(mW)
350
CO
POWER DISSIPATION
PD
(pF)
6
CAPACITANCE
0.3
(mA)
4
2
300
250
DTC144EUA/CA/KA
200
DTC144EE
150
100
50
10
REVERSE BIAS VOLTAGE
www.cj-elec.com
15
VR
(V)
25
50
75
AMBIENT TEMPERATURE
3
100
Ta
G,Jul,2016
A,Jun,2014
www.cj-elec.com
4
G,Jul,2016
A,Jun,2014
SOT-323 Package Outline Dimensions
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.cj-elec.com
Dimensions In Millimeters
Max.
Min.
0.900
1.100
0.000
0.100
0.900
1.000
0.200
0.400
0.080
0.150
2.000
2.200
1.150
1.350
2.150
2.450
0.650 TYP.
1.200
1.400
0.525 REF.
0.260
0.460
0°
8°
Dimensions In Inches
Min.
Max.
0.035
0.043
0.000
0.004
0.035
0.039
0.008
0.016
0.003
0.006
0.079
0.087
0.045
0.053
0.085
0.096
0.026 TYP.
0.047
0.055
0.021 REF.
0.010
0.018
0°
8°
5
G,Jul,2016
A,Jun,2014
www.cj-elec.com
6
G,Jul,2016
A,Jun,2014
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
www.cj-elec.com
SOT-23
7
G,Jul,2016
A,Jun,2014
很抱歉,暂时无法提供与“DTC144EE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.07680
- 50+0.07104
- 200+0.06624
- 600+0.06144
- 1500+0.05760
- 3000+0.05520
- 国内价格
- 20+0.15250
- 200+0.12312
- 600+0.10682
- 3000+0.07755
- 9000+0.06902
- 21000+0.06448
- 国内价格
- 1+0.27610
- 200+0.09185
- 1500+0.05742
- 3000+0.04554
