LCDA15C-8
LCDA15C-8
    LEIDITECH(雷卯电子)
    SOP16
    ESD保护 VRWM=15 V VBR(Min)=16.7 V VC=39 V IPP=14 A Ppp=500 W SOP16
LCDA15C-8 数据手册
LCDA15C-8 LOW CAPACITANCE TVS DIODE ARRAY FOR EIGHT HIGH SPEED LINE PROTECTION Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 15V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 24A (8/20μs) RoHS Compliant Dimensions SOP-16 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOP-16 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:2,500pcs ● Reel Size:13inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 500 Unit W ±15 VESD Kv ±8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/3 www.leiditech.com LCDA15C-8 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number LCDA15C-8 Device Marking VRWM (V) VBR (V) IT (mA) VC @1A LCDA15C-8 15 16.7 1 26 (Max) 39 (@A) 14 IR μA (Max) C (Pf) (Typ.) 1 5 Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2014 2/3 www.leiditech.com LCDA15C-8 SOP-16 PACKAGE OUTLINE & DIMENSIONS * SOLDERING FOOTPRINT Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 3/3 www.leiditech.com
LCDA15C-8
物料型号:LCDA15C-8
器件简介: - 该器件具有超低漏电水平(纳安级别)和15V的工作电压。 - 符合IEC 61000-4-2(ESD)空气放电±15kV和接触放电±8kV标准。 - 符合IEC 61000-4-4(EFT)40A(5/50ns)和IEC 61000-4-5(闪电)24A(8/20μs)标准。 - 符合RoHS标准。
引脚分配:SOP-16封装,引脚配置图示在文档中。
参数特性: - 峰值脉冲功率(8/20μs):500W - ESD(空气放电):±15kV - 工作温度范围:-55°C至+125°C - 存储温度范围:-55°C至+150°C
功能详解: - 该器件适用于USB 2.0电源和数据线、机顶盒和数字电视、数字视频接口(DVI)、笔记本电脑、SIM卡端口和10/100以太网。
应用信息: - 用于高速线路的保护,如USB 2.0、DVI、以太网等。
封装信息: - 封装类型:SOP-16 - 引脚完成:无铅 - UL阻燃等级:94V-0 - 每卷数量:2,500件 - 卷径:13英寸
电气特性表格提供了部分编号、设备标记、工作电压、击穿电压、漏电流、1A时的钳位电压、最大钳位电压、最大脉冲电流、电容等参数。
特性曲线图包括8/20μs脉冲波形、IEC 61000-4-2标准的ESD脉冲波形和功率降额曲线。
LCDA15C-8 价格&库存
很抱歉,暂时无法提供与“LCDA15C-8”相匹配的价格&库存,您可以联系我们找货
