PESD0542L050
ESD Protection Devices
Leiditech’ ESD line of devices help protect I/O
ports on HDMI 1.3, portable video players, LCD & plasma
TVs, USB 2.0, digital visual interface (DVI), and antenna
switches. ESD devices shunt electrostatic discharge
away from sensitive circuitry in HDTV equipment,
printers, laptops, cellular phones, and other portable
devices.
ESD devices offer many advantages over traditional
protection devices, such as multi layer varistors (MLVs),
which may degrade or distort the signal in high data rate
circuits. Compared to transient voltage suppression
(TVS) diodes and miniature gas discharge tubes (GDTs),
ESD devices provide a more compact form factor and
an economical solution for the shrinking profiles of
today’s compact information appliances.
Equivalent Circuit
Available in a range of form factors, our ESD protection
devices provide low capacitance, and meet transmission
line pulse (TLP) testing, as well as IEC61000-4-2 testing.
Benefits
Features
• RoHS compliant
• ESD protection for high frequency applications
(HDMI 1.3)
• Halogen free
• Smaller form factor for board space savings
(refers to: Brⱕ900ppm, Clⱕ900ppm, Br+Clⱕ1500ppm)
• Helps protect sensitive electronic circuits against
damage caused by electrostatic discharge (ESD)
events
•50pF(typical)capacitance
• Low-leakage current
• Low-clamping voltage
• Assists equipment to pass IEC 61000-4-2,
• Fast response time (< 1ns)
level 4 testing
• Capable of withstanding numerous ESD strikes
• Compatible with standard reflow installation
procedures
• Thick film technology
• Bi-directional protection
Applications
• HDMI 1.3 interfaces
• Printer ports
• LCD & plasma TV
• Satellite radios
• Cellular phones
• USB 2.0 and IEEE 1394 interfaces
• Antennas
• DVI
• Portable video players
• GPS systems
• Portable devices (PDA, DSC, BlueTooth)
Rev : 01.06.2014
1/6
www.leiditech.com
PESD0542L050
Electrical Characteristics(TA =25°C)
Parameter
Symbol
Test Conditions
Min.
Typ.
Max.
Units
Continuous Operating
Voltage
VDC
5
V
Trigger Voltage
VT
IEC61000-4-2 8KV
contact discharge
300
V
Clamping Voltage
VC
IEC61000-4-2 8KV
contact discharge
15.5
V
Leakage Current
IL
DC 5V shall be
applied on component
10
nA
Capacitance
CP
Measured at 10MHz
pF
ESD Pulse Withstand
Pulses
IEC61000-4-2 8KV
contact discharge
1000
50
Notes:
1. Trigger and clamping voltage are measured per IEC 61000-4-2, 8KV contact discharge method.
2. After reliability tests such as high Temp storage, Temp cycles, continuous ESD strike etc, the
maximum leakage current is less than 1uA.
Typical Device Capacitance VS. Frequency
60
Capacitance(pF)
50
40
30
1.0E+07
1.0E+08
1.0E+09
1.0E+10
Frequency(Hz)
Rev : 01.06.2014
2/6
www.leiditech.com
PESD0542L050
ESD Protection for HDMI
Package
Dimension
L
T
W
L1
DIMENSION (㎜)
CODE
L
0402
Rev : 01.06.2014
1.0±0.05
W
0.5±0.05
3/6
T
0.5±0.05
L1
0.2+0.15/-0.1
www.leiditech.com
PESD0542L050
Taping Specification
1. Tape Dimension
Unit: Millimeters
A
B
C
D
E
F
G
H
T
4.00±0.10
2.00±0.10
Ø1.55±0.10
1.90±0.05
1.0±0.05
0.48±0.05
1.75±0.10
3.50±0.05
8.00±0.30
2. Reel Dimension
Unit: Millimeters
A
B min.
C
D
E
F
G
178.0 ±2.0
50.0
13.0±0.5
13.0±1.0
9.40±1.0
2.0 ±0.5
21.0±0.8
Rev : 01.06.2014
4/6
www.leiditech.com
PESD0542L050
Soldering Parameters
260℃ max
10s
p
m
e
T
Natural
cooling
30s max
220℃ min
Preheating : 110±10sec
165 to 185℃
Land
Time(s)
Pattern
Rev : 01.06.2014
c
a
a
b
Size
a
b
c
0402
0.4~0.6
0.4~0.5
0.4~0.6
5 /6
www.leiditech.com
PESD0542L050
Leiditech Electronics are trademarks.
Information furnished is believed to be accurate and reliable. However, users should independently evaluate
the suitability of and test each product selected for their own applications. Leiditech Electronics reserves
the right to change or update, without notice, any information contained in this publication; to change,
without notice, the design, construction, processing, or specification of any product; and to discontinue or
limit production or distribution of any product. This publication supersedes and replaces all information
previously supplied. Without expressed or written consent by an officer of Leiditech Electronics, Leiditech
Electronics does not authorize the use of any of its products as components in nuclear facility applications,
aerospace, or in critical life support devices or systems. Leiditech Electronics expressly disclaims all
implied warranties regarding the information contained herein, including, but not limited to, any implied
warranties of merchantability or fitness for a particular purpose. Leiditech Electronics’ only obligations
are those in the Leiditech Electronics Standard Terms and Conditions of Sale and in no case will Leiditech
Electronics be liable for any incidental, indirect, or consequential damages.
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
6/6
www.leiditech.com
很抱歉,暂时无法提供与“PESD0542L050”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.11491
- 200+0.08877
- 600+0.07423
- 2000+0.06548
- 10000+0.05598
- 20000+0.05190
