PESD2842U005
PESD2842U005
    LEIDITECH(雷卯电子)
    0402中的超低电容ESD保护二极管
PESD2842U005 数据手册
 PESD2842U005 Ultal Low Capacitance ESD Protection Diode in 0402 Features ■ ESD protection for high speed data lines to IEC61000-4-2 ■ ESD contact discharge typical 15KV, max 30KV ■ ESD air discharge typical 15KV, max 30KV ■ Surface mount 1 2 ■ Extremely low capacitance ■ Very low leakage current ■ Fast response time ■ Bi-directional ESD protection ■ Lead free solder termination ■ The best ESD protection for high frequency, low voltage applications Mechanical Data ■ Applications Case: 0402 (plastic package). ■ USB3.0, Firewire, DVI, HDMI, S-ATA Lead free; RoHS compliant ■ ■ Thunderbolt, Display Port Molding Compound Flammability Rating: ■ Mobile HDMI Link, MDDI, MIPI, SWP / NFC UL 94 V-0 ■ Terminals: High temperature soldering guaranteed: 260 °C/10 sec. at terminals Absolute Maximum Ratings Ratings at 25 °C, ambient temperature unless otherwise specified Parameter Symbol Value Unit Maximum Contact discharge voltage Per IEC61000-4-2 --- 30KV V Maximum Air discharge voltage Per IEC61000-4-2 --- 30KV V Maximum Operating temperature TOPER -40 to +125  Maximum Storage temperature TSTG -55 to +125  TL 260  Maximum lead temperature for soldering during 10s Electrical Characteristics (TA = 25 °C unless otherwise specified) Parameter Symbol Test Conditions Min -28 Typ Max Units 28 V Rated Voltage VR --- Trigger voltage VT IEC61000-4-2 8KV contact discharge 300 V Clamping voltage VC IEC61000-4-2 8KV contact discharge 35 V Leakage current IL DC 15V shall be applied on component Capacitance CP VR = 0V, f = 1MHz 0.10 uA pF 0.05 Note: 1 Trigger and clamping voltage are measured per IEC 61000-4-2, 8KV contact discharge method. 2 After reliability tests such as high temp storage, temp cycles, continuous ESD strike etc, the maximum leakage current is less than 10uA. Rev : 01.06.2018 1/3 www.leiditech.com PESD2842U005 (6'&ODPSLQJ7HVW (6'7(67(5 5= ȍ *+]',*,7$/ 5*8 ȍFRD[ î 26&,//26&23( $77(18$725 &= ȍ '87 '(9,&(81'(57(67  ,(&QHWZRUN &= S)5= ȍ ESD Clamping Test Waveforms IPP 100% 90% 10% tr = 0.7 ns to 1ns t 30 ns 60 ns Typical ESD Response (IEC 61000-4-2, 8KV contact discharge) Typical Device Capacitance VS. Frequency 0.06 450 400 0.05 Capacitance(pF) Voltage ( V ) 350 300 250 200 150 100 0.04 0.03 0.02 50 0.01 0 -50 0 10 20 30 40 50 60 70 80 0 1.0E+07 90 Time(ns) Rev : 01.06.2018 1.0E+08 1.0E+09 1.0E+10 Frequency(Hz) 2/3 www.leiditech.com PESD2842U005 ESD Protection for Signal Line The PESD is designed for the protection of one bidirectional data line from ESD damage.  Place the PESD as close to the input terminal or connector as possible.  Minimize the path length between the PESD and the protected signal line.  Use ground planes whenever possible. Signal line to be protected GND 3URGXFW'LPHQVLRQ 'LP PLOOPHWHUV PLQ PD[ $   %   &   '   ( ) * + 5()   %6&   Ordering information Order code PESD2842U005 Package Packaging option Base quantity Packaging specification  Tape and reel 1000pcs / reel EIA STD RS-481 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 3/3 www.leiditech.com
PESD2842U005 价格&库存
很抱歉,暂时无法提供与“PESD2842U005”相匹配的价格&库存,您可以联系我们找货
PESD2842U005
    • 1+0.14090
    库存:10
