SDA3601P
SDA3601P
    LEIDITECH(雷卯电子)
    DFN2
    TVS二极管 VRWM=36 V VBR(Min)=40 V VC=72 V IPP=2 A Ppp=200 W DFN2_1.05X0.65MM
SDA3601P 数据手册
SDA3601P UNIDIRECTIONAL TVS DIODE Features ● 200 Watts Peak Pulse Power per Line (tp=8/20µs) ● Protects One Unirectional I/O Line ● Low clamping voltage ● Working voltages : 36V. ● Low leakage current ● IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) ● IEC61000-4-4 (EFT) 40A (5/50ηs) Dimensions DFN1006 Applications ● Cell Phone Handsets and Accessories ● Microprocessor based equipment ● Personal Digital Assistants (PDA’s) ● Notebooks, Desktops, and Servers ● Portable Instrumentation ● Peripherals ● Pagers Pin Configuration Mechanical Characteristics ● DFN1006 (1.0x0.6x0.5mm) Package ● Molding Compound Flammability Rating : UL 94V-O ● Weight 0.5 Millgrams (Approximate) ● Quantity Per Reel : 5,000pcs ● Reel Size : 7 inch ● Lead Finish : Lead Free Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 200 W ±15 VESD Kv ±8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2015 1/3 www.leiditech.com SDA3601P Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number SDA3601P Device Marking VRWM (V) YN 36 VBR (V) 40 IT (mA) VC @1A 1 60 (Max) 72 (@A) 2 IR μA (Max) C (Pf) (Typ.) 1 41 Characteristic Curves Rev : 01.06.2015 2/3 www.leiditech.com SDA3601P DNF1006 PACKAGE OUTLINE & DIMENSIONS * SOLDERING FOOTPRINT Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 3/3 www.leiditech.com
SDA3601P
物料型号:SDA3601P
器件简介:该器件是一款单向TVS二极管,具有200瓦特峰值脉冲功率,适用于保护单向I/O线路,具有低钳位电压和低漏电流。
引脚分配:文档中未明确列出引脚分配,但通常TVS二极管有两个引脚,一个阳极和一个阴极。
参数特性: - 峰值脉冲功率:200W(8/20μs) - ESD保护:IEC61000-4-2标准下空气放电±15kV,接触放电±8kV - IEC61000-4-4标准下EFT 40A(5/50ns) - 工作电压:36V - 工作温度范围:-55°C至+125°C - 存储温度范围:-55°C至+150°C
功能详解:SDA3601P主要用于保护电子设备免受静电放电和电气快速瞬变的影响,适用于手机、个人数字助理、笔记本电脑、服务器、便携式仪器和外围设备等。
应用信息:适用于手机、配件、基于微处理器的设备、个人数字助理、笔记本电脑、台式电脑、服务器和便携式仪器等。
封装信息:DFN1006封装,尺寸为1.0x0.6x0.5mm,重量约为0.5毫克,每卷5000片,卷径7英寸,引脚表面处理为无铅。
电气特性: - 工作电压(VRWM):36V - 击穿电压(VBR):40V - 漏电流(IR):最大1mA - 1A时的钳位电压(Vc@1A):60V - 最大钳位电压(Vc):72V - 电容(C,PF):典型值1pF
特性曲线:文档提供了ESD钳位电压的截图,展示了正负8kV接触放电时的电压波形。
SDA3601P 价格&库存
很抱歉,暂时无法提供与“SDA3601P”相匹配的价格&库存,您可以联系我们找货
