SDA2411DN
SDA2411DN
    LEIDITECH(雷卯电子)
    DFN2
    TVS二极管 VRWM=24 V VBR(Min)=27 V VC=44 V IPP=5 A Ppp=220 W DFN2_1.05X0.65MM
SDA2411DN 数据手册
SDA2411DN Features  Ultra small package: 1.0x0.6x0.5mm  Protects one data or power line  Ultra low leakage: nA level  Operating voltage: 24V  Low clamping voltage  2-pin leadless package  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 5A (8/20μs)  RoHS Compliant Dimensions DFN1006 Pin Configuration Applications  Cellular Handsets and Accessories  Personal Digital Assistants  Notebooks and Handhelds  Portable Instrumentation  Digital Cameras  Peripherals  Audio Players 1 2 Mechanical Characteristics  Package: DFN1006  Case Material: “Green” Molding Compound.  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 220 VESD ± 30 Unit W Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +150 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com SDA2411DN Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number SDA2411DN Rev : 01.06.2018 Device Marking VRWM (V) VBR (V) IT (mA) VC @1A 4P 24 27 1 33 2/4 (Max) 44 (@A) 5 IR μA (Max) 0.2 C (Pf) (Typ.) 40 www.leiditech.com SDA2411DN Typical Performance Characteristics (TA=25°C unless otherwise Specified) Peak Pulse Power vs. Pulse Time Junction Capacitance vs. Reverse Voltage Power Derating Curve Clamping Voltage vs. Peak Pulse Current Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 kV Contact per IEC61000−4−2 8 X 20μs Pulse Waveform Rev : 01.06.2018 3/4 www.leiditech.com SDA2411DN DFN1006 Package Outline Drawing A DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.45 0.50 0.55 0.018 0.020 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 SYM e 0.65 BSC 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 L1 h 0.05REF 0.07 0.12 0.002REF 0.17 0.003 0.005 0.007 Suggested Land Pattern SYM ╋ Y3 Y2 MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 Y1 Z ╋ X DIMENSIONS Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
SDA2411DN 价格&库存
很抱歉,暂时无法提供与“SDA2411DN”相匹配的价格&库存,您可以联系我们找货
